    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 40.3k Views 21 Watching
      tfdesign
      But hey, so far, so good! 😎
      • BurkhardB Offline
        Burkhard
        Just a question. The whole thing does not make really sense when there is no way to stop starting the toolbars while starting Sketchup.
        When I disabled the tools in the preferences, the toolbars in the ribbon does'nt work. If they are enabled the toolbars floating my window again ( on Mac ) so I have to enable all Toolbars manually.
        Is there a way to force the Toolbars to disappear/quit at once?
        http://www.ia-plus.de
        • majidM Offline
          majid
          thanx for your job, but still nothing is happenig at my side!!! plz help
          full screen view
          • KrisidiousK Offline
            Krisidious
            what seems to be the issue Majid?
            By: Kristoff Rand
              Majid: it looks as though you have maximized the toolbar window - just resize to back to a fitting size.
              • majidM Offline
                majid
                almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue πŸ˜„
                  Krisidious
                  Majid,
                  the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
                  let's see which one's you have that are not working?
                  By: Kristoff Rand
                    Krisidious
                    hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
                    do you have organizer.rb running?
                    have you checked to see that you have the
                    /caleidos4d
                    Caleidos4D_Ribbon.rb
                    in the plugins folder?
                    By: Kristoff Rand
                    • I Offline
                      iwanwidjaja
                      Hi Caleidos4D,
                      Its a great plug in, thanks for share it
                      Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active πŸ˜†
                      Regards'
                      Iwan
                      • majidM Offline
                        majid
                        thanxs mates for your kind helps πŸ˜„ .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
                        • EarthMoverE Offline
                          EarthMover
                          Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
                          Content Creator at Skapeup
                          • majidM Offline
                            majid
                            thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars... 😞 (as I saw a black screen on some screenshots above) . maybe it could be an option for next update ,plz . πŸ˜„ it workes fine in way you described. thanx again
                              caleidos4d
                              thank to all friends for help in topic πŸ†™ my english is very bad....
                              this is a .gif for usage and preview features in next release
                              http://www.caleidos4d.it
                              • troyhomeT Offline
                                troyhome
                                [attachment=0:8asf8rxq]<!-- ia0 -->Usage_and_Preview.gif<!-- ia0 -->[/attachment:8asf8rxq]
                                can't wait to try this out- in English πŸ˜„
                                IOviz.com
                                SU Pro 2024 PC
                                  Jim
                                  For translate:
                                  in the next version, I will translate the tooltips in English but I also accept suggestions πŸ˜„
                                  Well, I appreciate this because I only know English; but I was also trying to come up with a language translation strategy in order to provide translations to any language.
                                  I think JavaScript can be used to iterate over the tooltips, and set the Text according to the tooltip id (for example.)
                                  • Bob JamesB Offline
                                    Bob James
                                    @troyhome said:
                                    @khai said:
                                    all I'm getting at the link is
                                    "alterVista
                                    La risorsa richiesta Γ¨ accessibile qui
                                    you have to click "qui"
                                    I'm afraid I can't even find "La risorsa richiesta è accessibile qui so I can click on "qui" 😞 😳
                                    Update
                                    I got it by pasting in "http://caleidos.altervista.org/Download/caleidos4d_Ribbon.zip" and it automatically downloaded.
                                      caleidos4d
                                      Update: 1.1 πŸ˜‰
                                        EarthMover
                                        Nice update. English tooltips are perfect! Any plans to add FredoScale?
                                          caleidos4d
                                          I wanted insert SfedoScale and BezierSpline, already in this release, but I can not find the call for the plugins in various fredo's libraries ...
                                            tony bombata
                                            renderplus rpedits copy selection tool bug splatted EVERY time i ran the command - so i started removing my most recent plugins - and caledios was the culprit 😞
                                            • 2 / 3
