    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 36.6k Views 21 Watching
      caleidos4d
      @jim said:
      Caleidos4D ,
      Nice interface, well done and thanks. Do you have a plan for providing language translations? I'm not sure how best to implement them in a WebDialog - I know Fredo, TIG, and ThomThom have code for this, so maybe someone could make a suggestion.
      Thank you Jim, I am honored to know that you liked my work,
      And thanks to you and Mover2 if My ribbon is born πŸ‘
      For translate:
      in the next version, I will translate the tooltips in English but I also accept suggestions πŸ˜„
      http://www.caleidos4d.it
        caleidos4d
        @krisidious said:
        the hover tips are in Italian? French?
        is there a way to change the resolution size of the ribbon? mine doesn't fit inside of 1024?
        is there a way to make your own ribbon preset?
        Italian πŸ˜„ in the next release, all tooltips in English πŸ˜„
          dizain
          Ciao Caleidos4D,
          Ti ringrazio per il tuo lavoro,
          ho istallato il plugin ma non riesco a farlo funzionare come dovrebbe.
          Puoi aiutarmi?
          Allego immagine della schermata dove non si vede l'area del disegno.
          Ciao e di nuovo grazie.
          David
          Hello Caleidos4D,
          Thank you for your work,
          I installed the plugin but I can not get it working as it should.
          Can you help?
          I attach a screen shot where you see the drawing area.
          Hello and thanks again.
          David
            Did you resize the window?
              caleidos4d
              @dizain said:
              Ciao Caleidos4D,
              Puoi aiutarmi?
              David
              Hello Caleidos4D,
              Can you help?
              David
              Hi πŸ˜„
              you have to resize the ribbon and the SketchUp window, to match your monitor πŸ˜‰
                caleidos4d
                Work in progress:
                in next release I will fix it the size of monitors in 1024 and the iframe, They will also be floating πŸ˜‰
                • charly2008C Offline
                  charly2008
                  I wanted to try out as a precaution in Sketchup 8. But can not find this plugin. Am I doing something wrong?
                  Charly
                    charly2008
                    Solved, found it in the plugin menu. It is very interesting extension. Many thanks to Caleidos4D.
                    Charly
                      caleidos4d
                      @charly2008 said:
                      Charly
                      πŸ‘ πŸ˜„
                        tfdesign
                        @solo said:
                        One reason I'll never switch to Windows is
                        .... You like shiny things? πŸ’š
                        Like this?
                        http://www.cytechstore.com/images/THERMALTAKE Soprano VB1000SWS.jpg
                        πŸ˜›
                        Is that a handle on the front, to remove the beer? 😲
                          tfdesign
                          But hey, so far, so good! 😎
                          • BurkhardB Offline
                            Burkhard
                            Just a question. The whole thing does not make really sense when there is no way to stop starting the toolbars while starting Sketchup.
                            When I disabled the tools in the preferences, the toolbars in the ribbon does'nt work. If they are enabled the toolbars floating my window again ( on Mac ) so I have to enable all Toolbars manually.
                            Is there a way to force the Toolbars to disappear/quit at once?
                            http://www.ia-plus.de
                            • majidM Online
                              majid
                              thanx for your job, but still nothing is happenig at my side!!! plz help
                              full screen view
                              • KrisidiousK Offline
                                Krisidious
                                what seems to be the issue Majid?
                                By: Kristoff Rand
                                  Majid: it looks as though you have maximized the toolbar window - just resize to back to a fitting size.
                                  • majidM Online
                                    majid
                                    almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue πŸ˜„
                                      Krisidious
                                      Majid,
                                      the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
                                      let's see which one's you have that are not working?
                                      By: Kristoff Rand
                                        Krisidious
                                        hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
                                        do you have organizer.rb running?
                                        have you checked to see that you have the
                                        /caleidos4d
                                        Caleidos4D_Ribbon.rb
                                        in the plugins folder?
                                        By: Kristoff Rand
                                        • I Offline
                                          iwanwidjaja
                                          Hi Caleidos4D,
                                          Its a great plug in, thanks for share it
                                          Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active πŸ˜†
                                          Regards'
                                          Iwan
                                          • majidM Online
                                            majid
                                            thanxs mates for your kind helps πŸ˜„ .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
                                            • 2 / 3
