    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 38.5k Views 21 Watching
      Did you resize the window?
        caleidos4d
        @dizain said:
        Ciao Caleidos4D,
        Ti ringrazio per il tuo lavoro,
        ho istallato il plugin ma non riesco a farlo funzionare come dovrebbe.
        Puoi aiutarmi?
        Allego immagine della schermata dove non si vede l'area del disegno.
        Ciao e di nuovo grazie.
        David
        Hello Caleidos4D,
        Thank you for your work,
        I installed the plugin but I can not get it working as it should.
        Can you help?
        I attach a screen shot where you see the drawing area.
        Hello and thanks again.
        David
        Hi πŸ˜„
        you have to resize the ribbon and the SketchUp window, to match your monitor πŸ˜‰
        http://www.caleidos4d.it
          caleidos4d
          Work in progress:
          in next release I will fix it the size of monitors in 1024 and the iframe, They will also be floating πŸ˜‰
          • charly2008C Offline
            charly2008
            I wanted to try out as a precaution in Sketchup 8. But can not find this plugin. Am I doing something wrong?
            Charly
              charly2008
              Solved, found it in the plugin menu. It is very interesting extension. Many thanks to Caleidos4D.
              Charly
                caleidos4d
                @charly2008 said:
                Charly
                πŸ‘ πŸ˜„
                  tfdesign
                  @solo said:
                  One reason I'll never switch to Windows is
                  .... You like shiny things? πŸ’š
                  Like this?
                  http://www.cytechstore.com/images/THERMALTAKE Soprano VB1000SWS.jpg
                  πŸ˜›
                  Is that a handle on the front, to remove the beer? 😲
                    tfdesign
                    But hey, so far, so good! 😎
                    • BurkhardB Offline
                      Burkhard
                      Just a question. The whole thing does not make really sense when there is no way to stop starting the toolbars while starting Sketchup.
                      When I disabled the tools in the preferences, the toolbars in the ribbon does'nt work. If they are enabled the toolbars floating my window again ( on Mac ) so I have to enable all Toolbars manually.
                      Is there a way to force the Toolbars to disappear/quit at once?
                      [http://www.ia-plus.de(http://www.ia-plus.de)]
                      • majidM Offline
                        majid
                        thanx for your job, but still nothing is happenig at my side!!! plz help
                        full screen view
                        • KrisidiousK Offline
                          Krisidious
                          what seems to be the issue Majid?
                          By: Kristoff Rand
                            Majid: it looks as though you have maximized the toolbar window - just resize to back to a fitting size.
                            • majidM Offline
                              majid
                              almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue πŸ˜„
                                Krisidious
                                Majid,
                                the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
                                let's see which one's you have that are not working?
                                By: Kristoff Rand
                                  Krisidious
                                  hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
                                  do you have organizer.rb running?
                                  have you checked to see that you have the
                                  /caleidos4d
                                  Caleidos4D_Ribbon.rb
                                  in the plugins folder?
                                  By: Kristoff Rand
                                  • I Offline
                                    iwanwidjaja
                                    Hi Caleidos4D,
                                    Its a great plug in, thanks for share it
                                    Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active πŸ˜†
                                    Regards'
                                    Iwan
                                    • majidM Offline
                                      majid
                                      thanxs mates for your kind helps πŸ˜„ .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
                                      • EarthMoverE Offline
                                        EarthMover
                                        Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
                                        Content Creator at Skapeup
                                        • majidM Offline
                                          majid
                                          thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars... 😞 (as I saw a black screen on some screenshots above) . maybe it could be an option for next update ,plz . πŸ˜„ it workes fine in way you described. thanx again
                                            caleidos4d
                                            thank to all friends for help in topic πŸ†™ my english is very bad....
                                            this is a .gif for usage and preview features in next release
                                            • 2 / 3
