    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 517.1k Views 75 Watching
    • spenceS
      spence
      thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE!
      Spence
      • david_hD
        david_h
        Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. πŸ’š
        • T
          thohan
          Thank you for this great plugin. πŸ˜„
          I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
          I think with some more effort, one can achieve much better results.
          http://img43.imageshack.us/img43/8434/smalltest.png
          It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
          • jamalitoJ
            jamalito
            wow wow wow
            where have you been ? man
            I looking for such as plug-in
            thank you so so much thomthom
            you helped me
            because I have a lot pictures I want to do it
            Albert Einstein:
            ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
              Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
              Nice coin by the way. πŸ˜„
                marcomartim
                This plugin is great!
                I use Sketchup with Phlatscript plugin to generate code G (2.5 D) to use on my CNC Router, lack a 3D plugin for editing G code on Sketchup.
                For 3D and 4D, still use the Artcam,; Now with this plugin can create 3D models from photos, right in Sketchup.
                Thank you.
                • C
                  Christmended
                  Thanks for the awesome plugin!
                  Here is a test result I did.
                    Shaun, that almost looks like a lithophane. Cool.
                    • H
                      Heven7_floor
                      Great Plug-in, thank your gift to make SU plugin to display the thing happen πŸ‘ πŸ‘ πŸ‘
                      • P
                        pichuneke
                        The plugin works with bump mapping. I have no idea about what I am saying, but could it work with normal and displacement maps?
                        I have no idea about programming, except an unfinished Interactive Fiction game 5 years ago in the "popular" inform 6 language 😲 πŸ˜† πŸ˜†
                        Forgive my spanglish...
                          Displacement maps are the same as bump maps - grayscale heightmaps. As for normal maps, I don't really know how they work...
                          • P
                            pichuneke
                            I have found a lot about normal maps here:
                            http://www.google.com/search?hl=es&q=+site:gamedev.net+normal+map+algorithm&sa=X&ei=zwXHTLXUK4WO4Aa2yNXtDw&ved=0CBsQrQIwAA
                            but it's written in chinese, or C++ ... πŸ˜† I don't know if it may interest you, I was spending my time a bit (as I don't understand a single word πŸ˜„ )
                            • arquitectomaracuchoA
                              arquitectomaracucho
                              excuse my English, Greetings πŸ‘Š
                              Thomtom greetings, very good tool for many functions πŸ‘ . be possible to add option mesh, giving a percentage between simple and complex mesh, thanks πŸ‘
                                That would be simply resizing the bitmap down - which is much more efficient to do in your favourite image editor than via a Ruby plugin.
                                  Scott M
                                  Just downloaded the plugin an gave it a try.I folowed the promp but nothing is showing up it is saying generating mesh but continues to thnink as if unresponsive.Is my system just too slow or am I doing something wrong. Could someone outline the process.The images you guys posted look great.I allso operate a cnc and would lke very much to use this plugin.
                                  https://www.youtube.com/user/ecabinetstips
                                    What image are you feeding it?
                                    How large?
                                    If you keep the Ruby Console open, do you get error messages?
                                      Scott M
                                      How large?
                                      I am using a jepg emage that I exported as a bmp. emage. It is 395x640px.I set the width at 6 5/8" and typed in the depth at 1/8". The ruby console showes Bitmap to mesh.
                                      processing data took:4.6175s
                                      After a few min. console goes blank with a white screen and the curser turns to a hour glass. This is the way it stays.
                                        For how long?
                                        Can you post the image you're using?
                                          Scott M
                                          @thomthom said:
                                          For how long?
                                          Sorry it took so long to reply.It will stay that way as long as sketchup is up. I let it run for about 1 hour. I will attach the image.
                                          • FletchF
                                            Fletch
                                            😲 Impressive plugin ThomThom! Wow!
                                            (I obviously need a better displacement map for this tile now.) πŸ˜†
                                            Fletch
                                            • 13
                                            • 14
                                            • 5 / 14
