    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 35.9k Views 21 Watching
      Khai
      @krisidious said:
      will this mount up in a side monitor? I have three and don't like losing space on top.
      yup, works on a 2nd monitor.
      had some java errors.. but it's a beta so...
      • KrisidiousK Offline
        Krisidious
        Thank you...
        one of my biggest problems is that I don't remember all of my plugins... I do work I don't need to be doing because I forget I don't have to do it any more. toolbars help me remember... a ribbon that's grouping the plugins might be even better. can't wait to try it.
        By: Kristoff Rand
          Krisidious
          the hover tips are in Italian? French?
          is there a way to change the resolution size of the ribbon? mine doesn't fit inside of 1024?
          is there a way to make your own ribbon preset?
          By: Kristoff Rand
            caleidos4d
            @jim said:
            Caleidos4D ,
            Nice interface, well done and thanks. Do you have a plan for providing language translations? I'm not sure how best to implement them in a WebDialog - I know Fredo, TIG, and ThomThom have code for this, so maybe someone could make a suggestion.
            Thank you Jim, I am honored to know that you liked my work,
            And thanks to you and Mover2 if My ribbon is born πŸ‘
            For translate:
            in the next version, I will translate the tooltips in English but I also accept suggestions πŸ˜„
            http://www.caleidos4d.it
              caleidos4d
              Italian πŸ˜„ in the next release, all tooltips in English πŸ˜„
                dizain
                Ciao Caleidos4D,
                Ti ringrazio per il tuo lavoro,
                ho istallato il plugin ma non riesco a farlo funzionare come dovrebbe.
                Puoi aiutarmi?
                Allego immagine della schermata dove non si vede l'area del disegno.
                Ciao e di nuovo grazie.
                David
                Hello Caleidos4D,
                Thank you for your work,
                I installed the plugin but I can not get it working as it should.
                Can you help?
                I attach a screen shot where you see the drawing area.
                Hello and thanks again.
                David
                  Did you resize the window?
                    caleidos4d
                    @dizain said:
                    Ciao Caleidos4D,
                    Puoi aiutarmi?
                    David
                    Hello Caleidos4D,
                    Can you help?
                    David
                    Hi πŸ˜„
                    you have to resize the ribbon and the SketchUp window, to match your monitor πŸ˜‰
                      caleidos4d
                      Work in progress:
                      in next release I will fix it the size of monitors in 1024 and the iframe, They will also be floating πŸ˜‰
                      • charly2008C Offline
                        charly2008
                        I wanted to try out as a precaution in Sketchup 8. But can not find this plugin. Am I doing something wrong?
                        Charly
                          charly2008
                          Solved, found it in the plugin menu. It is very interesting extension. Many thanks to Caleidos4D.
                          Charly
                            caleidos4d
                            @charly2008 said:
                            Charly
                            πŸ‘ πŸ˜„
                              tfdesign
                              @solo said:
                              One reason I'll never switch to Windows is
                              .... You like shiny things? πŸ’š
                              Like this?
                              http://www.cytechstore.com/images/THERMALTAKE Soprano VB1000SWS.jpg
                              πŸ˜›
                              Is that a handle on the front, to remove the beer? 😲
                                tfdesign
                                But hey, so far, so good! 😎
                                • BurkhardB Offline
                                  Burkhard
                                  Just a question. The whole thing does not make really sense when there is no way to stop starting the toolbars while starting Sketchup.
                                  When I disabled the tools in the preferences, the toolbars in the ribbon does'nt work. If they are enabled the toolbars floating my window again ( on Mac ) so I have to enable all Toolbars manually.
                                  Is there a way to force the Toolbars to disappear/quit at once?
                                  [http://www.ia-plus.de(http://www.ia-plus.de)]
                                  • majidM Offline
                                    majid
                                    thanx for your job, but still nothing is happenig at my side!!! plz help
                                    full screen view
                                      Krisidious
                                      what seems to be the issue Majid?
                                      By: Kristoff Rand
                                        Majid: it looks as though you have maximized the toolbar window - just resize to back to a fitting size.
                                        • majidM Offline
                                          majid
                                          almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue πŸ˜„
                                            Krisidious
                                            Majid,
                                            the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
                                            let's see which one's you have that are not working?
                                            By: Kristoff Rand
                                            • 2 / 3
