    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 38.5k Views 21 Watching
      @jim said:
      Do you have a plan for providing language translations? I'm not sure how best to implement them in a WebDialog - I know Fredo, TIG, and ThomThom have code for this, so maybe someone could make a suggestion.
      I'll be porting VertexTools' translation system to TT_Lib2 - at the moment it has some bits locking it to VT only, but it's not hard to decouple it.
      • troyhomeT Offline
        troyhome
        @khai said:
        all I'm getting at the link is
        "alterVista
        La risorsa richiesta Γ¨ accessibile qui
        you have to click "qui"
        IOviz.com
        SU Pro 2024 PC
          Khai
          aha thank you.
            tfdesign
            @jim said:
            @tfdesign said:
            So that leads me to ask, will Caleidos4D work on Mac OSX? πŸ˜„
            I don't know since I haven't tried, but there is nothing that would prevent it from working.
            I know the answer to that! πŸ˜†
            I'll try it. πŸ˜„
            • soloS Offline
              One reason I'll never switch to Windows is
              .... You like shiny things? πŸ’š
              • 1 Offline
                123zxy
                sorry for my bad English, but would you be so kind to explain how to use? The interface looks interesting but I can not do anything with it
                Thank you very much
                • KrisidiousK Offline
                  Krisidious
                  will this mount up in a side monitor? I have three and don't like losing space on top.
                  By: Kristoff Rand
                    Khai
                    yup, works on a 2nd monitor.
                    had some java errors.. but it's a beta so...
                      Krisidious
                      Thank you...
                      one of my biggest problems is that I don't remember all of my plugins... I do work I don't need to be doing because I forget I don't have to do it any more. toolbars help me remember... a ribbon that's grouping the plugins might be even better. can't wait to try it.
                      By: Kristoff Rand
                        Krisidious
                        the hover tips are in Italian? French?
                        is there a way to change the resolution size of the ribbon? mine doesn't fit inside of 1024?
                        is there a way to make your own ribbon preset?
                        By: Kristoff Rand
                          caleidos4d
                          @jim said:
                          Caleidos4D ,
                          Nice interface, well done and thanks. Do you have a plan for providing language translations? I'm not sure how best to implement them in a WebDialog - I know Fredo, TIG, and ThomThom have code for this, so maybe someone could make a suggestion.
                          Thank you Jim, I am honored to know that you liked my work,
                          And thanks to you and Mover2 if My ribbon is born πŸ‘
                          For translate:
                          in the next version, I will translate the tooltips in English but I also accept suggestions πŸ˜„
                          http://www.caleidos4d.it
                            caleidos4d
                            Italian πŸ˜„ in the next release, all tooltips in English πŸ˜„
                              dizain
                              Ciao Caleidos4D,
                              Ti ringrazio per il tuo lavoro,
                              ho istallato il plugin ma non riesco a farlo funzionare come dovrebbe.
                              Puoi aiutarmi?
                              Allego immagine della schermata dove non si vede l'area del disegno.
                              Ciao e di nuovo grazie.
                              David
                              Hello Caleidos4D,
                              Thank you for your work,
                              I installed the plugin but I can not get it working as it should.
                              Can you help?
                              I attach a screen shot where you see the drawing area.
                              Hello and thanks again.
                              David
                                Did you resize the window?
                                  caleidos4d
                                  @dizain said:
                                  Ciao Caleidos4D,
                                  Puoi aiutarmi?
                                  David
                                  Hello Caleidos4D,
                                  Can you help?
                                  David
                                  Hi πŸ˜„
                                  you have to resize the ribbon and the SketchUp window, to match your monitor πŸ˜‰
                                    caleidos4d
                                    Work in progress:
                                    in next release I will fix it the size of monitors in 1024 and the iframe, They will also be floating πŸ˜‰
                                    • charly2008C Offline
                                      charly2008
                                      I wanted to try out as a precaution in Sketchup 8. But can not find this plugin. Am I doing something wrong?
                                      Charly
                                        charly2008
                                        Solved, found it in the plugin menu. It is very interesting extension. Many thanks to Caleidos4D.
                                        Charly
                                          caleidos4d
                                          @charly2008 said:
                                          Charly
                                          πŸ‘ πŸ˜„
                                            tfdesign
                                            Like this?
                                            http://www.cytechstore.com/images/THERMALTAKE Soprano VB1000SWS.jpg
                                            πŸ˜›
                                            Is that a handle on the front, to remove the beer? 😲
                                            • 1 / 3
