    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 122.9k Views 34 Watching
      And one existential question with the Cpoint at Arcs Center! 🤓
      (of course from a same circle trimed) 😉
        Very Romantic yes 😄
        But there is a little problem 😮
        That works not with that! 😲
        (I have also tried with explode Circle, convert, erase..., not better) !
        Good result must be 5 CPpoints !
        Else of course your plug if very fun (and useful) for this sort of thing 😉
        CPoint at Circle Center
        Insert Components at CPoints 👍
        And of course Selection Toys for Select CPoints 😉
        http://forums.sketchucation.com/download/file.php?id=56417
          Very Romantic yes 😄
          [attachment=0:26fwmhk5]<!-- ia0 -->worksnot1.jpg<!-- ia0 -->[/attachment:26fwmhk5]
          Are these edges that's split each other?
          From your original request I thought you wanted cpoints at edge crossings if the edge where not part of a face.
          Maybe it should just not check if edges are connected to faces?
          Should it only place a cpoint for overlapping edges (but does not split each other? )
          [attachment=0:26fwmhk5]<!-- ia0 -->existential.png<!-- ia0 -->[/attachment:26fwmhk5]
          I don't understand the question...
            In fact just put a CPoint at any real intersections of a selection of lines and/or circles, arc circle and /or curves
            on faces or in the space
            (i don't know if it's an hard work or not) 😳
            for the existential question 😄
            an Arc Circle A has a Cpoint CPA, xa , ya, za
            an Arc Circle B has a Cpoint CPB xb, yb, zb
            but of course as you can see on my previous image
            because arc are from a same circle
            xa = xb, ya = yb, za = zb
            So my question what about this "double CPoint"?
            is there 2 Cpoints or you merge it in only one?
              Where edges are split where they intersect? Or where they overlap - like they often do in SU6 and older?
              Doesn't check for existing CPoints.
                I don't know, on the face I suppose 😳
                In any case we have solution to move them out the face (when existing)
                call the plug, and re put on the face 😄
                So there are 2CPoint overlaped
                or they are automatical merged as one by SU as having same coordinates ?
                (same than you draw 2 lines ovelapped)
                  Something is lost in translation here - I mean should there be a CPoint only when two edges cross each other but doesn't split each other?
                  I don't know - I haven't tested it. The plugin just adds a CPoint blindly.
                    I have just tested seems there are really 2 CPoints! 😮
                    Maybe some annoyous 😉
                    click image if scrool bar!
                      I think Pilou's issue with 'duplicated Cpoints' - i.e. at the same location in 3D space - is if they are used to place Instances later it will duplicate the Instances etc.
                      When adding the new Cpoints it'd be relatively easy to test to see if there was a Cpoint already there.
                      First make a collection of Cpoints in the current context [entities] and make an array of the 'position' of each one: then only add the new Cpoint if it's not already there - code-example...
                      there=false
                      cpoint_positions.each{|p|(there=true;break)if p==new_point}
                      entities.add_cpoint(new_point) if not there
                      You should still add coincident Cpoints if they are in different contexts [entities-sets]...
                        Slightly trimmed variant:
                        entities.add_cpoint(new_point) unless cpoint_positions.any?{|pt|pt==new_point}
                          In fact that must be 6 points! 😒
                          1 Center of circle
                          1 Intersection of lines
                          4 Intersection Lines Circle
                          Here I have a lot of more 😉
                          I have made Intersection before launch the plug Edge/edge (V 6)
                          Edit I have found a Process
                          General Intersection
                          Hide Circle
                          Call the Plug Guides Tool - Edge/edge
                          Show Circle
                          Select Circle
                          Call ad Cpoint to Circle
                          I have my six points 😎
                          Easy for not numerous circles but for many ? 😉
                          Ok I can use Selection Toys Circles ☀ 😉
                            Why do you hide and show the circle?
                              Yes see my edit text 😉
                              In fact that must be Selection Toys "Arcs"
                              Hide
                              because the interections are made before 😉
                              Process must be
                              Ad CP Circle(s)
                              Hide
                              Add CPoint Edge /Edge
                              Show Hidden
                              When Edge / Edge Cpoints are they "Doubled" between 2 segments of a same lines or not? (like my lines above after the intersection)
                              (at the commune extremities)
                              Seems not! 😎 (I have verified with the outliner) ☀
                              You have just the problem of same arc centers of my previous old post 😉
                              • W
                                watkins
                                Dear Thomas,
                                Could the following be added to the suite of cpoint functions?
                                To place a construction point at the intersection of three orthogonal planes.
                                Thanks,
                                Bob
                                  @watkins said:
                                  Dear Thomas,
                                  Thanks,
                                  Bob
                                  Should be straightforward...
                                  Get line of the intersection of two of the planes.
                                  get the intersection of the third plane and the line.
                                  Add a cpoint...
                                    @ Thomthom
                                    Does it possible to have an option for DWG export?
                                    Problem is: Tocad don't import CP POINT !!! 😮
                                    So circle center oe arc circle center info are losted!
                                    So a possibility is to replace CPoints by 2 or 3 lines crossed.(3 axis)
                                    (as "component" even Tocad lost the "component" it draw the lines! ☀
                                    And each circle is tranformed in disc by ToCad.
                                    So Replace CPoints by crossed lines will be fine for DWG export 😄
                                    Of course the replacement can be made by Selection Cpoint/Put Component at Cpoints.
                                    (problem of mutiple same CPoints must be also resolved) 😄
                                      Version 1.3.0
                                      CPoint at Camera Eye - Adds a construction point at the Camera eye.
                                      • utilerU
                                        utiler
                                        Great addition Thom! All your work with rubies are very much appreciated!!!
                                        Just Curious...
                                        • L
                                          lapx
                                          Tom,
                                          Thanks! I've been searching for this for a while.
                                          Best, Lapx.
                                          • Bob JamesB
                                            Bob James
                                            Drilling Milling[/url] by Menfin (French and English version) ☀
                                            This looks like it would be very handy, but the forum is in French (only) and doesn't allow download without being a member of the forum. 😞
                                            • 3 / 5
