    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 122.9k Views 34 Watching
      Where edges are split where they intersect? Or where they overlap - like they often do in SU6 and older?
      I don't know, on the face I suppose 😳
      Something is lost in translation here - I mean should there be a CPoint only when two edges cross each other but doesn't split each other?
      So there are 2CPoint overlaped
      or they are automatical merged as one by SU as having same coordinates ?
      (same than you draw 2 lines ovelapped)
      I don't know - I haven't tested it. The plugin just adds a CPoint blindly.
        I have just tested seems there are really 2 CPoints! 😮
        Maybe some annoyous 😉
        click image if scrool bar!
          I think Pilou's issue with 'duplicated Cpoints' - i.e. at the same location in 3D space - is if they are used to place Instances later it will duplicate the Instances etc.
          When adding the new Cpoints it'd be relatively easy to test to see if there was a Cpoint already there.
          First make a collection of Cpoints in the current context [entities] and make an array of the 'position' of each one: then only add the new Cpoint if it's not already there - code-example...
          there=false
          cpoint_positions.each{|p|(there=true;break)if p==new_point}
          entities.add_cpoint(new_point) if not there
          You should still add coincident Cpoints if they are in different contexts [entities-sets]...
            Slightly trimmed variant:
            entities.add_cpoint(new_point) unless cpoint_positions.any?{|pt|pt==new_point}
              In fact that must be 6 points! 😒
              1 Center of circle
              1 Intersection of lines
              4 Intersection Lines Circle
              Here I have a lot of more 😉
              I have made Intersection before launch the plug Edge/edge (V 6)
              Edit I have found a Process
              General Intersection
              Hide Circle
              Call the Plug Guides Tool - Edge/edge
              Show Circle
              Select Circle
              Call ad Cpoint to Circle
              I have my six points 😎
              Easy for not numerous circles but for many ? 😉
              Ok I can use Selection Toys Circles ☀ 😉
                Why do you hide and show the circle?
                  Yes see my edit text 😉
                  In fact that must be Selection Toys "Arcs"
                  Hide
                  because the interections are made before 😉
                  Process must be
                  Ad CP Circle(s)
                  Hide
                  Add CPoint Edge /Edge
                  Show Hidden
                  When Edge / Edge Cpoints are they "Doubled" between 2 segments of a same lines or not? (like my lines above after the intersection)
                  (at the commune extremities)
                  Seems not! 😎 (I have verified with the outliner) ☀
                  You have just the problem of same arc centers of my previous old post 😉
                  • W
                    watkins
                    Dear Thomas,
                    Could the following be added to the suite of cpoint functions?
                    To place a construction point at the intersection of three orthogonal planes.
                    Thanks,
                    Bob
                      @watkins said:
                      Dear Thomas,
                      Thanks,
                      Bob
                      Should be straightforward...
                      Get line of the intersection of two of the planes.
                      get the intersection of the third plane and the line.
                      Add a cpoint...
                        @ Thomthom
                        Does it possible to have an option for DWG export?
                        Problem is: Tocad don't import CP POINT !!! 😮
                        So circle center oe arc circle center info are losted!
                        So a possibility is to replace CPoints by 2 or 3 lines crossed.(3 axis)
                        (as "component" even Tocad lost the "component" it draw the lines! ☀
                        And each circle is tranformed in disc by ToCad.
                        So Replace CPoints by crossed lines will be fine for DWG export 😄
                        Of course the replacement can be made by Selection Cpoint/Put Component at Cpoints.
                        (problem of mutiple same CPoints must be also resolved) 😄
                          Version 1.3.0
                          CPoint at Camera Eye - Adds a construction point at the Camera eye.
                          • utilerU
                            utiler
                            Great addition Thom! All your work with rubies are very much appreciated!!!
                            Just Curious...
                            • L
                              lapx
                              Tom,
                              Thanks! I've been searching for this for a while.
                              Best, Lapx.
                              • Bob JamesB
                                Bob James
                                Drilling Milling[/url] by Menfin (French and English version) ☀
                                This looks like it would be very handy, but the forum is in French (only) and doesn't allow download without being a member of the forum. 😞
                                  dedmin
                                  Is it possible to add "CPoint at Insertion Point" for groups also?
                                    I'll add it to the list.
                                      dedmin
                                      • L
                                        Larsen
                                        Amazing tools!
                                        Thanks thomthom for your generosity.
                                        [Every form of thinking perish by excess of its basic principles.
                                        • B
                                          baiduaiya
                                          thank you very much.
                                            matt.gordon320
                                            Thank you so much! Amazing Tools as always...
                                            • 3 / 5
