    (Wanted) Plugin Auto Create Face
    26 Posts 10 Posters 7.8k Views 10 Watching
    • jeff hammondJ Offline
      @chris fullmer said:
      Hey Razr, i'm afraid you example did not help. I'm more confused now.
      yeah, me too.
      what exactly are you trying to draw razr?
        Here's another approach that could be done with any version of SketchUp.
        [flash=400,375:13dfcjea]http://blip.tv/play/gYhbgf_wRwI[/flash:13dfcjea]
        http://blip.tv/file/4173434
        Probably didn't get the embedding done right. [EDIT: I fixed it for you... TIG πŸ˜‰ ]
        • EarthMoverE Offline
          EarthMover
          I think he wants to find a tool to split a single solid into multiple solids in order to have a game engine process the model, as it doesn't read just a hole in a wall.
          Solid tools does it but it's tedious and changing everything to groups. I think he wants to slice or cube up a component by drawing edges on the face, selecting the edges and running a plugin. There is nothing like this that I know of, but it would be handy.
          Content Creator at Skapeup
            razer
            Yea that is correct 😞 sorry if I cant explain it right guys. never could explain things 😞 πŸ˜› Will have to give this one a go it may be tedious but will work. Thanks again for the videos will love for a plugin like this!
              kyyu
              How about this? I had some code that did something close and did a quick mod. The thickness, you will have to manually change in the ruby at the top. You start with 2D faces, select all and then use the plugin.
              ky_Group_PushPull_2DFaces.rb
                razer
                [attachment=1:2fqccdeh]<!-- ia1 -->blocks.gif<!-- ia1 -->[/attachment:2fqccdeh]
                [attachment=0:2fqccdeh]<!-- ia0 -->ky_Group_PushPull_2DFaces.rb<!-- ia0 -->[/attachment:2fqccdeh]
                Thank you! Kyyu! that works wonders! Also like to thank you all for helping with this! great forum great people!
                  @Kyyu
                  Cool plug πŸ‘
                  and use after Radial Move by C.Plassais...and me πŸ˜‰
                  (Explode in 3D x,y,z here only x,y πŸ˜„
                    kyyu
                    Cool Pilou! β˜€ I just grabed Radial Move and the english version of your Eclate_Deplace plugin. I had the orginal in French, which I don't speak. 😳 Tried mine and your plugin with a box. I will start a new thread with my plugin, so it will be put in the index and people can find it.
                      Sure and have another plugs? β˜€
                        kyyu
                        I'm going to have to steal you picture, for the plugin thread. Hope you don't mind. It's a really good example. πŸ‘
                          kazmej
                          Great job kyyu.
                          Is the a possibility to modify yours plugin that i'll be able to change the push/pull value in the Sketchup window?
                            kyyu
                            @kazmej said:
                            Great job kyyu.
                            Hi kazme,
                            I started a seperate thread for my plugin, if you want to check it out http://forums.sketchucation.com/viewtopic.php?t=31279. This question has been addressed there.
                            Basically, I plan to integrate this feature into my Pushpull & Group plugin. That plugin already has the ability to enter the pushpush value.
                            -Kwok
                              kazmej
                              Very useful plugin for transforming brushwork made in SketchUp into Source Hammer Editor.
                                kyyu
                                What if I gave you a input box? Would that be useful? When the plugin is run, a input box opens up. You would hit "ok" to use the default thickness value. Or you could enter a new value.
                                -Kwok
                                  kazmej
                                  Kwok, implementing input box for push/pull value would be of great help 4 me.
                                    kyyu
                                    Here you go. Get the new version here: http://forums.sketchucation.com/viewtopic.php?f=323&t=31279&p=279346
                                      kazmej
                                      Thanks Kwok. It's exactly what I wanted.
