    (Wanted) Plugin Auto Create Face
    26 Posts 10 Posters 7.7k Views 10 Watching
      kyyu
      How about this? I had some code that did something close and did a quick mod. The thickness, you will have to manually change in the ruby at the top. You start with 2D faces, select all and then use the plugin.
      ky_Group_PushPull_2DFaces.rb
        razer
        [attachment=1:2fqccdeh]<!-- ia1 -->blocks.gif<!-- ia1 -->[/attachment:2fqccdeh]
        [attachment=0:2fqccdeh]<!-- ia0 -->ky_Group_PushPull_2DFaces.rb<!-- ia0 -->[/attachment:2fqccdeh]
        Thank you! Kyyu! that works wonders! Also like to thank you all for helping with this! great forum great people!
          @Kyyu
          Cool plug πŸ‘
          and use after Radial Move by C.Plassais...and me πŸ˜‰
          (Explode in 3D x,y,z here only x,y πŸ˜„
            kyyu
            Cool Pilou! β˜€ I just grabed Radial Move and the english version of your Eclate_Deplace plugin. I had the orginal in French, which I don't speak. 😳 Tried mine and your plugin with a box. I will start a new thread with my plugin, so it will be put in the index and people can find it.
              Sure and have another plugs? β˜€
                kyyu
                I'm going to have to steal you picture, for the plugin thread. Hope you don't mind. It's a really good example. πŸ‘
                  kazmej
                  Great job kyyu.
                  Is the a possibility to modify yours plugin that i'll be able to change the push/pull value in the Sketchup window?
                    kyyu
                    @kazmej said:
                    Great job kyyu.
                    Hi kazme,
                    I started a seperate thread for my plugin, if you want to check it out http://forums.sketchucation.com/viewtopic.php?t=31279. This question has been addressed there.
                    Basically, I plan to integrate this feature into my Pushpull & Group plugin. That plugin already has the ability to enter the pushpush value.
                    -Kwok
                      kazmej
                      Very useful plugin for transforming brushwork made in SketchUp into Source Hammer Editor.
                        kyyu
                        What if I gave you a input box? Would that be useful? When the plugin is run, a input box opens up. You would hit "ok" to use the default thickness value. Or you could enter a new value.
                        -Kwok
                          kazmej
                          Kwok, implementing input box for push/pull value would be of great help 4 me.
                            kyyu
                            Here you go. Get the new version here: http://forums.sketchucation.com/viewtopic.php?f=323&t=31279&p=279346
                              kazmej
                              Thanks Kwok. It's exactly what I wanted.
                              • 2 / 2
