    [Plugin] Google's Bezier
    31 Posts 10 Posters 97.0k Views 10 Watching
      hm... my face only triggered three letters... 😲
      • mitcorbM Offline
        mitcorb
        Whoa, boy. Sit down. Relax. Get away from the stimulant drinks. πŸ˜†
          Did it leave a mark on your forehead?
            A Punchuation Mark?
            • KrisidiousK Offline
              Krisidious
              Imagine how fast you'll be at this stuff when you don't have to actually type. You'll be able to think what you want and your fingers won't have to be the go-between.
              http://www.newegg.com/Product/Product.aspx?Item=N82E16826100006
              OCZ OCZMSNIA Neural Impulse Actuator $99.99
              "There are a number of sensors installed in the headband to read your brain wave signal, and convert them into control signals. Working with the nia’s calibration program, the Actuator captures a variety of signals, such as facial muscle movement, eye movement, brain Alpha waves and Beta waves to control the game. So you can launch the desired behavior and shoot with the "blink of an eye", without lifting a finger."
              By: Kristoff Rand
                Sorry what is the "Google's Bezier" ? 😳
                  It's the one that ThomThom fixed. πŸ˜„
                    Or the one Google broke.... πŸ˜•
                      Surely but... πŸ’š
                      • jeff hammondJ Offline
                        it's one of google's sample ruby scripts:
                        http://sketchup.google.com/intl/en/download/rubyscripts.html
                          AAAAAAh ! Ok but that was not "Google Bezier" but "Bezier" short πŸ’š
                          Yes - but since there was other bezier tools out there I added "Google's" to the title, so there would be no confusion... πŸ˜’
                          • EdsonE Offline
                            Edson
                            thomas,
                            would you mind explaining a bit more what this is all about? what google bezier plugin? where is it? what is the problem with it? etc.
                            thanks.
                            EDIT: sorry, I jumped from the first page to here without looking at the intervening posts. is this "official" plugin any good?
                            http://www.mahfuz.arq.br
                              @edson said:
                              thom,
                              thanks.
                              One of the plugins Google has had available for download is a Bezier tool - let you draw Bezier curves. It came before Fredo made his excellent collection of Spline tools.
                              Googles plugin is availible from the link Jeff linked to: http://forums.sketchucation.com/viewtopic.php?f=323&t=30973&start=15#p274374
                              The problem was that due to a SU8 bug in the API you could not edit the curves any more. I simply added a small workaround to make it function again.
                                Never used from Beziers by Fredo 6 exist πŸ˜‰
                                here Pierre BΓ©zier the French guy who create the Bezier curves πŸ˜‰
                                It was a very cool guy! 😎
                                http://nonifier.ovh.org/stuff/Pierre_Bezier.jpg
                                @ Jeff Look this file . (you can use Google Translator if you want πŸ˜„
                                You will see some affinity with your drawing πŸ˜‰
                                Here ch 4.1 two letters in Englih πŸ˜‰On Pierre BΓ©zier's life and motivations πŸ€“
                                http://www-gmm.insa-toulouse.fr/~rabut/bezier/DocumentsBezier/ArtsEtMetiers/Imagique/img018.jpg
                                • EdsonE Offline
                                  Edson
                                  thanks, thomas. but what is the correct procedure: to have both installed or just your fix?
                                    Overwrite the old file - if you have it.
                                    Though only needed if you are using SU8. (And not using Fredo's power pack... πŸ˜’ )
                                      Thomas, I apologize for creating such a mess for you. I didn't realize there were so many people who had no idea of Bezier.rb. I've had it for so long I don't remember where I downloaded it from. I still use it along with Fredo's excellent BZ tools.
                                        No worries!
                                          Jim
                                          I think the bug which caused the original bezier.rb to fail has been fixed in the SketchUp 8 M1 (8.0.4811) release.
                                          Although this (Thom's) version will still work in version 8 M1, and the original should work again.
                                            Although this version, as well as the original should both work now.
                                            Correct.
