    [Plugin] 2D Tools
    791 Posts 178 Posters 770.8k Views 177 Watching
      Thanks. That works for me. I was unaware of this feature.
      Again, thanks for your plugins.
      Onto another note, will you be at 3D Basecamp?
      Ken
      Unfortunately, it's a no.
      Google arranged 3D Basecamp a verybad time...
      I have a sick relative coming to live with us around then... AND I have to get things ready [like finish the new ground-floor bedroom/bathroom etc]... AND also it's aloooong way... AND it's a lot of money for a few days' junket AND... it starts on my wife's birthday AND it ends on our wedding-anniversary πŸ˜•
      So all in all a resounding 'no' - though I would have loved to have gone πŸ˜’
      • utilerU
        utiler
        Ken
        Excuses, excuses, TIG.... πŸ˜‰
        Just Curious...
        • G
          gcp310
          does this plugin only work for SU porfessional, or will it work with the free version.
          i cant get it to load up.
          Glenn
            It works on SU Free. Have you extracted the zipped folder into your plugins directory? Making sure to keep the folder/file structure intact.
              Glenn, it works with both pro and free versions of SU. Perhaps you could be a little more specific about what you've done and what's happening.
                Also it's not to be found in the Plugins Menu... See Menu > Draw > 2D Tools > sub-menu items... AND you will need to activate the 2D Tools toolbar from Views > Toolbar > 2D Tools to see that too...
                Please read the instructions in the Help file...
                • G
                  gcp310
                  i feel like such an idiot, yes, they have been there all along.
                  sorry, i had been so engrossed in trying to get them to appear in the plugins section.
                  thanks for the info
                  Glenn
                  • W
                    wyatt
                    TIG,
                    The 2D tools don't seem to work in v8. I get the following error (3 pages actually - just copying one as they are all similar).
                    Error Loading File 2D#.rb
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DlineTool.rb:33: syntax error, unexpected ',', expecting kEND
                    Sketchup::set_status_text ("Length"), SB_VCB_LABEL
                    I don't have an urgent need for this plug-in right now but I thought you'd like to know that it may need to be updated.
                    Wyatt
                      Wyatt, I don't want to speak for TIG but I'm not having any problem with the 2D Tools on either my Mac or my PC. In fact I just used it a few minutes ago on my PC here at work. Could it be an install problem?
                        His error indicate a syntax error.
                        Sketchup::set_status_text ("Length"), SB_VCB_LABEL instead which Ruby 1.8.6 throws an error at now that it's stricter than previous version.
                        Possible he has used different tools than you?
                        @Wyatt: exactly when you do get these errors? What tools/operations are you doing?
                          I don't know, Thomas. I've gone through all of the 2D tools just now and didn't get any errors.
                          • W
                            wyatt
                            Ok, figured it out. The 2D tools that don't work for me are these:
                            http://forums.sketchucation.com/viewtopic.php?t=21445
                            v4.6 works fine. Are the plugins on the other thread an earlier build?
                              As Thomthom says v8 is more unforgiving of having only part of the arguments parenthesized - I will check my code and reissue to suit... B U T . . .
                              However, there is no occurrence of the text Sketchup::set_status_text ("Length"), SB_VCB_LABEL ANYWHERE in the current 2DlineTool.rb - it's always the correctly syntaxed Sketchup::set_status_text((db"Length"),SB_VCB_LABEL) ??? πŸ˜•
                              So I am a bit mystified - do you have the correct version downloaded from the main page zip file...
                                o_O
                                Peculiar. Though, I did find the syntax alien to be TIG's...
                                  @thomthom said:
                                  o_O
                                  It was 'wrong' in some older versions.... BUT not in the more recent ones - and they coincidentally suits v8 too............
                                  • F
                                    Fredquentin
                                    Thank's a lot
                                    Reg@rds Fred
                                      Here's v4.7 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                      The MAC TAB-key press glitch is trapped using key-up check instead of key-down in 2DlineTool.
                                      MAC 'help' openURL glitch fixed.
                                      • kenK
                                        ken
                                        Some how I don't think this is what you wanted.
                                        And thanks.
                                        Ken
                                          And thanks.
                                          Ken
                                          Ken - somehow the zip got messed up! 😳
                                          I'll post v4.7 again!
                                            😳 v4.7 zip was messed up!
                                            It's now fixed http://forums.sketchucation.com/viewtopic.php?p=185760#p185760 - please re-download...
                                            I know that it has been downloaded a few times in the corrupted form.
                                            If you have it then either don't install it or if you already have done so, then please remove all of the 'wrong' files from the Plugins folder...
                                            Otherwise you'll get multiple toolbar-buttons etc...
                                            In the Plugins folder you should only have just two related files - deBableizer.rb and 2D#.rb - AND also a 2DTools folder containing lots of things.
                                            Everything else with '2d' is their name [files (~22nr) and folders (2nr)] is wrong and needs removing.
                                            The CadFathersIcons.zip file is also wrongly located and needs removing to tidy up.
                                            Also there will be a folder called Icons that unfortunately might have merged with other tools' folder of the same name - it does no harm to have the extra image files in there... BUT to tidy up remove any files in it with '2D' in their name - if that empties the folder then you can also delete that.
                                            Similarly the Hatching folder has been misplaced - it's unlikely to have merged - but check if it only contains image files starting with 'PATT' and a ReadMe.txt file - if so the whole folder can go...
                                            Sorry for this mess up... 😳
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 39
                                            • 40
                                            • 14 / 40
