    [Plugin] 2D Tools
    791 Posts 178 Posters 690.4k Views 177 Watching
    • kenK Offline
      ken
      Some how I don't think this is what you wanted.
      And thanks.
      Ken
        And thanks.
        Ken
        Ken - somehow the zip got messed up! 😳
        I'll post v4.7 again!
          😳 v4.7 zip was messed up!
          It's now fixed http://forums.sketchucation.com/viewtopic.php?p=185760#p185760 - please re-download...
          I know that it has been downloaded a few times in the corrupted form.
          If you have it then either don't install it or if you already have done so, then please remove all of the 'wrong' files from the Plugins folder...
          Otherwise you'll get multiple toolbar-buttons etc...
          In the Plugins folder you should only have just two related files - deBableizer.rb and 2D#.rb - AND also a 2DTools folder containing lots of things.
          Everything else with '2d' is their name [files (~22nr) and folders (2nr)] is wrong and needs removing.
          The CadFathersIcons.zip file is also wrongly located and needs removing to tidy up.
          Also there will be a folder called Icons that unfortunately might have merged with other tools' folder of the same name - it does no harm to have the extra image files in there... BUT to tidy up remove any files in it with '2D' in their name - if that empties the folder then you can also delete that.
          Similarly the Hatching folder has been misplaced - it's unlikely to have merged - but check if it only contains image files starting with 'PATT' and a ReadMe.txt file - if so the whole folder can go...
          Sorry for this mess up... 😳
          • jeff hammondJ Offline
            confirmed, tab now works on mac.
            i didn't know that's what tab was supposed to do. ha
            that makes 2D tools even more awesome β˜€
            thank you
              Brett McAllister
              Hi Tig
              I noticed the edit 2d text function no longer works in version 8.
              The option to edit the text shows up in the context menu but doesn't pop up a dialog box.
              This is the error I got.
              Error: #<NameError: undefined local variable or method db' for TextTool2D:Class> 2DtextTool.rb:379:in edit'
              Running windows xp sp2
              Cheers
              Brett
                dedmin
                When trying to use Edit 2D text I got this:
                Error; #<NoMethodError; undefined method `db' for TextTool2D;Class>
                C;/Program Files/Google/Google SketchUp 8/Plugins/2Dtools/2DtextTool.rb;379;in `edit'
                C;/Program Files/Google/Google SketchUp 8/Plugins/2Dtools/2D#loader.rb;186;in `activate'
                C;/Program Files/Google/Google SketchUp 8/Plugins/SectionCutFace.rb;437;in `call'
                WinXP SP3
                  @brett mcallister said:
                  Hi Tig
                  Cheers
                  Brett
                  You should have deBabelizer.rb in the Plugins folder. It's in the main zip file?
                    WinXP SP3
                    Not sure about the SectionCut error ???
                      v4,7 error... However, I have now managed to reproduce the glitch πŸ˜’ with v8 ... and v4.8 will be issued shortly πŸ˜’ ...
                        dedmin
                        WinXP SP3
                        Reinstalled the 4.7 and now the error is this:
                          I've now got these new v8 errors trapped in '2D Text' and '2D Line Style' "edit" modes - see v4.8 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                          Double checking that no other methods are rubbished by the less forgiving PC-Ruby in v8... πŸ˜’
                          EDIT: There shouldn't be any others - but that's not to say you lot won't find something that's broken... keep looking πŸ˜•
                            dedmin
                            Thanks,TIG! πŸ‘ πŸ‘
                            • Didier BurD Offline
                              Didier Bur
                              Hi TIG,
                              I'm always having this error too, even with the latest version. When setting the Z plane altitude for instance:
                              C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DzplaneTool.rb;59;in `onMouseMove'
                              Error; #<NoMethodError; undefined method `db' for #<Zplane2D;0x1285ba60>>
                              DB
                                Thanks Didier...
                                I just knew that someone would have another problem!
                                It was a stupid typo on my part that hadn't been reported before... 😳
                                Here's v4.9 that fixes the 'db' glitch in the 'Set Z-Plane' tool.! πŸ€“
                                  Didier Bur
                                  Cool !
                                  So reactive πŸ˜‰
                                  DB
                                  • CadFatherC Offline
                                    CadFather
                                    icons updated as well (thanks TIG)
                                    Icons.zip
                                      Thanks - I'll include them for the next update - meanwhile anyone who wants them now... please replace the original Icons with these...
                                        Here's v5.0 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                        The db arguments etc are parenthesized in (). Various minor glitches in text etc have been addressed. The ES lingvo & help files have also been updated etc - many thanks to Defisto for his nit-picking that goaded me into the update! CadFather's new toolbar button icon set is also include if you want to swap over to that...
                                          define
                                          @tig said:
                                          Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                          πŸ€“
                                          hello TIG, thx for your 2d-toolset...I'm using it all the time and would'nt know how to get along without it.
                                          But I have to second ThomThom with his question, if one 'sotospeak' could make the 2dtools work with
                                          your 'work-planes' too? This would make it into something even more versatile.
                                          You answered ThomThom with a link - I can't however figure out what you are pointing at.
                                          If there's already a means to switch the 2dtools z-axis to any 'temporarily active one' please
                                          give me a hint.
                                          thx a lot for the 2dtools and the 'workplane-plug' and all the other plugs as well
                                            Ben Ritter
                                            I can use the hatching option only once, thereafter, I the hatch selection window doesn't open. Tried it with SU7 and SU8, same issue.
                                            Any suggestions?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 39
                                            • 40
                                            • 15 / 40
