    [Plugin] Free Rotate 4.4
    92 Posts 22 Posters 60.9k Views 22 Watching
      nada.. same thing
      Thanks any way - I'm doing some digging to find how to trap the TAB key on the MAC it's #9 on the PC...
      I think it's 0x30...
      Could you perhaps try '24' and '48' ? πŸ˜„
        Does tab work in Solid Inspector, Jeff? http://forums.sketchucation.com/viewtopic.php?f=323&t=30504
        • jeff hammondJ
          yeah, it works with solid inspector
          [edit - tab works and zooms/cycles through errors but shift+tab does nothing]
          this is the result of pressing tab with a key code finder.. i tried those numbers and none worked
          [edit- no go with 24 either]
          • EarthMoverE
            EarthMover
            TIG,
            Also appears axial rotate along the red axis is not working. Just brings up a construction line, but no rotate gizmo.
            Content Creator at Skapeup
            • kenK
              ken
              The TAB key does not work, PC with Window Vista, if I chose 'constrained' Axial-Rotate and try to select the red axis. The 'Gizmo' appears if you choice is the green axis, or the blue axis. However, if the choice is the red axis, the 'Gizmo' does not appear. It will appear if the choice is more than a 1/4 degree off the red Axis, but will not appear if the choice is exactly the red axis.
              Hope this helps
              Ken
              Darn, guess I should have waited.
                I uses ASCII code 9 for TAB - which is what I thought OSX also used...
                  hm... ok I made it use the combo of Tab and the constraint modifier key - so it'd be the one you use to lock inference...
                  • EarthMoverE
                    EarthMover
                    Ken, I think you mean the TAB key is working for you? Just not the red axis? TAB works for me on PC - Vista.
                    • jeff hammondJ
                      i somewhat found the thread about the problem with tab on mac..
                      i'm pretty sure fredo had a mac specific thread asking about this but i can't find it.
                      404 Not Found
                      (forums.sketchucation.com)
                      he was confused because he used 9 as he did with JPP, which works.. but it wasn't working with freescale.
                      maybe he'll see this thread.
                        After a flurry ... a recap...
                        TAB works with key code 9, 15?, 30??, 48??? - on PC and Mac ??
                        On the separate issue - I thought I'd trapped for all of the 'exactly axial' axis glitches - obviously NOT πŸ˜’
                        That is fixable...
                        EDIT: simple typo that broke it - fixed... now waiting for Tab issue to resolve...
                        • jeff hammondJ
                          That is fixable...
                          no, tab doesn't work with any of those numbers (on mac)
                          out of curiosity, i used 121 (for 'y'.. as i don't have anything assigned to that key in SU)
                          and it did work.. i was able to get into axial_rotate.
                            From some research...
                            TAB is keycode 9 on PC and MAC [or 0x09 hex] - i.e. ASCII.
                            With some locale keyboards TAB is keycode 15 [Thai?]
                            TAB is also 0x30 hex which is 48 in some locale keyboards [FR?] - as in [k]VK_Tab...
                            I'll trap for 9, 15 and 48 for now and reissue v4.1 will the axis glitch fixed... πŸ˜’
                              Here's v4.1 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                              A typo has been fixed with the Axis on the X_AXIS which glitched unexpectedly. πŸ˜’
                              The 'Tab' press for MAC key code adjusted to 9, 15 and 48 to try and trap all platforms/locales. πŸ˜•
                              Menu 'Windows > Instructor' help added...
                              [Note: this is [i]not working (yet) - so for now open ../FreeRotate/index.html in your web-browser untill this is fixed...][/i] πŸ€“
                              • jeff hammondJ
                                sorry TIG.. tab key still not working in v4.1 on mac.
                                  BUM! 😑
                                  ANY Mac user's getting it to work ??
                                  I can't see why not... as it now accepts keycode 9, 15 or 48 as a TAB key press...
                                  Any ideas, 'team' ? πŸ˜’
                                  • jeff hammondJ
                                    BUM! 😑
                                    I can't see why not as it now accepts keycode 9, 15 or 48 as the TAB key press...
                                    fwiw, i tried 2D tools tab key (which i haven't needed before) and i think it's broken also.
                                    but yeah, i'm thinking it's something other than which # to use.. i've checked a few different scripts which have tab key functionality in them, which work, and they use 9
                                      Jeff
                                      I know 2D Tools uses the same code - I'll have to fix that when I know for sure what the problem is... πŸ˜’
                                      I've attached a short 'keycode' script.keycode.rb Can you put it into your Plugins folder and open a SKP.
                                      In the Ruby Console type keycode and activate the main window and follow the simple instructions.
                                      Press the 'Tab' key and report what keycode it says [on a PC it says '9'].
                                      You can try pressing other non-shortcut 'modifier' keys to get there keycodes too.
                                      As soon as you press a shortcut key it exits...
                                      Thanks for your help.
                                      PS: Change the tool's suffix to .rb.txt after testing so it no longer loads... πŸ€“
                                      • jeff hammondJ
                                        here's a little variety pack πŸ˜„
                                        shift-- You Pressed Keycode = 131072
                                        control-- 262144
                                        option/alt-- 524288
                                        command-- 1048576
                                        return(enter)-- 13
                                        Y -- 121
                                        (shift)Y -- 89
                                        I -- 105
                                        down arrow -- 63233
                                        left arrow -- 63234
                                        / -- 47
                                        tab -- does nothing
                                        • jeff hammondJ
                                          hey TIG
                                          i did a little investigating and think i found what's causing the problem..
                                          with keycode.rb, i changed line#9 to
                                          def onKeyUp(key, repeat, flags, view) ..(instead of onKeyDown)
                                          it's now returning 9 when i push the tab key
                                          i was digging through some fredoscale v1 files and found a version where tab was broken on mac then found what it looks like after he fixed it..
                                          broken:
                                          #Handle key down events
                                          def onKeyDown(key, rpt, flags, view)
                                          	key = Traductor.check_key key, flags, false
                                          	case key
                                          	when CONSTRAIN_MODIFIER_KEY		#Shift key Uniform vs. non-uniform
                                          		@shift_down = true
                                          		change_free_uniform()
                                          		return
                                          	when COPY_MODIFIER_KEY			#Ctrl key - Center vs. Opposite
                                          		@ctrl_down = true
                                          		change_from_center()
                                          		return
                                          	when 13
                                          		return
                                          	when 9							#TAB - Ask dimensions
                                          		ask_dimensions() unless @post_validate
                                          		return
                                          	@vcb_return = false
                                          	#Function Key options
                                          	return if check_function_key(key, rpt, flags, view)
                                          	#trapping the arrow keys for imposed direction or plane
                                          	unless @dragging
                                          		vecdir = nil
                                          		normal = nil
                                          		[[VK_UP, Z_AXIS], [VK_RIGHT, X_AXIS], [VK_LEFT, Y_AXIS], [VK_DOWN, @NUL_AXIS]].each do |kv|
                                          			if key == kv[0]
                                          				vecdir = kv[1]
                                          				break
                                          		if vecdir && !already_in_box?(vecdir)
                                          			@pk_vecdir = vecdir
                                          			execute_by_mode view
                                          fixed:
                                          #Handle key up events
                                          def onKeyUp(key, rpt, flags, view)
                                          	key = Traductor.check_key key, flags, true
                                          	case key
                                          		@shift_down = false
                                          		@ctrl_down = false
                                          		onMouseMove 0, @x, @y, view if @x
                                          	when 13
                                          		execute_by_mode view unless @vcb_return
                                          		@vcb_return = false
                                          	else
                                          		@from_center = ! @from_center if @ctrl_down
                                          (sorry, i don't know if i copy/pasted too much or too little of that script for it to be helpful 😳 πŸ˜„ ..but hopefully the answer is in there somewhere)
                                            Please could you try changing your version of FreeRotate.rb.
                                            from the TAB code being under
                                            def **onKeyDown**(key, repeat, flags, view)
                                            to it being under
                                            def **onKeyUp**(key, repeat, flags, view)
                                            if key==9 or key==15 or key==48 ### TAB =9 for PC, MAC 15/48 for some locales ?
                                                  if @tab
                                                    self.make_disk()if @state>2
                                                    if @state==0
                                                      @msg=@msgAXIALPIVOT
                                                    elsif @state==1
                                                      @msg=@msgAXIALAXIS
                                                    else
                                                      @state=2
                                                      @msg=@msgAXIALHANDLE
                                                    end#if
                                                    @tab=false ### axial
                                                  else
                                                    self.make_globe()if @state>2
                                                    if @state==0
                                                      @msg=@msgFREEPIVOT
                                                    elsif @state==1
                                                      @msg=@msgFREEAXIS
                                                    else
                                                      @state=4
                                                      @msg=@msgFREE
                                                    end#if
                                                    @tab=true ### free
                                                  end#if
                                                  view.invalidate if @ip.display? or @ip1.display?
                                                end#if
                                            It's only in the one line, save and open a SKP...
                                            Retry FreeRotate and see if the TAB key now works on your MAC and you toggle between 'Free' and 'Axial' modes...
                                            Keep the Ruby Console open to see any errors etc...
                                            For some reason TAB 'down' is plain flaky on the Mac - but perhaps TAB 'up' isn't !?
                                            If it then works on the PC too I'll change it around... otherwise I'll do both - one test for PC one for MAC ...
                                            I think we are getting near to a solution here...
                                            I'll issue an updated version soonest...
                                            Then I need to fix ALL tools for MAC with the same issue... πŸ€“
                                            PS: by the way here's a new version of keycode.rb that reports key-pressed and key-released events...keycode.rb
                                            • 3 / 5
