    1.5k Posts 477 Posters 4.1m Views 477 Watching
    • fredo6F
      Dear All,
      I recently update to sketchup 8, get the last fredo lib (3.4c) and the last roundcorner plugin.
      I also change windows to mac os.
      I have tried roundcorner plugin on sketchup 7 on windows (work fine), sketchup 7 and 8 on Mac (just crash or really lagy).
      Any idea for this problem?
      I am using Mac os 10.6
      Thank for reply,
      Juju,
      Can you be more explicit:
      • when is it slow: when you luanch it, when you select edges, when you generate the round geometry?
      • when does the crash on Mac happen?
      • is it slow for complex models or regradless?
      • JujuSKPJ
        JujuSKP Extension Creator
        Hi Fredo,
        First congratulation for this plugin (very usefull).
        I will try to explain my problem clearly in English (i am french native)
        To be more explicit:
        I have made some tries with complex and very simple models (simple cube), the problem is exactly the same.
        (I might think that the problem come from the ToolBar display, but I am not expert).
        • When I launch the tool, sketchup became lagy (almost freezing) and the toolbar make long time to appear (minimum 20 seconds).
        • It is mostly impossible to change the parameters on the tool bar (take 1, 2, 3 minutes to respond). I also try to change the settings with the Sketchup toolbar (the one at the right bottom) and the problem is still the same.
        • The probleme is the same if I want to select an edge.
        • If i do not change parameters (avoiding me 5 to 10 minutes of waiting), I can validate the action and Sketchup does the round corner. But it is also very laggy (2 to 3 minutes between my click and the corner drawing).
        To resume, Sketchup become really lagy as soon as I launch the round corner tools.
        The strangest thing is that when I use the round corner, not only sketchup freeze but my whole mac interface.
        I hope my explanations are clear.
        Thanks for your help,
        Julien
        • fredo6F
          Julien,
          1. Do you notice the same lagy behavior when you use my other plugins using the button palette interface (such as Curvilft or Tools On Surface)?
          2. When you execute the operation (click with green check mark), do you see the progressbar immediately and then progressing slowly, or do you see it appearing only at the end briefly? This will tell me if the problem is in the GUI refresh or in the global execution of the ruby code.
          3. Also, do you have a real crash on your Mac, or is it just álmost freezing'?
            To Mac users: Do you have the same bad experience with RoundCorner?
          • JujuSKPJ
            Fredo,
            1. Your other plugin such as Tools On Surface work fine (I just download and test the last version of Tools on Surface)
            2. Yes, the progress bar is working normally (As soon as I execute the operation, progress bar works and quickly). The difficult and laggy thing is to launch the operation.
            3. Not a real crash, my commands doesn't respond until sketchup come back to normal.
            Hope it helps
            thanks
            • JujuSKPJ
              If it can help, here is an extract of my ruby console for One operation:
              /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1186: warning: Object#id will be deprecated; use Object#object_id
              /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1187: warning: Object#id will be deprecated; use Object#object_id
              • fredo6F
                This one is known (and now in SU8 Windows). It will be fixed in the next release of the plugins, but it is harmless.
                Do you have the performance problem on Windows too?
                Also, Can you download and install Curviloft. It includes LibFredo6 3.5, and it is better to see if the problems also occurs with this more recent version (the issues seems to be with the GUI).
                • JujuSKPJ
                  Ok, so I have to wait for the next release?
                  I am sorry but I am not using Windows anymore -)
                  I was used to work with sketchup 7 and the round corner plugin without any problems.
                  I have download and install curviloft, it works really fine and quick.
                  I have retry roundcorner, still having the same problem.
                  thanks fredo
                  • fredo6F
                    thanks fredo
                    Then, it would be helpful if other Mac users could tell if they have similar performance issues.
                    • C
                      CST
                      Fredo:
                      I use Mac OS 10.6 and SketchUp 8.
                      I have dropped RoundCorner%202 & LibFredo6%203 into the
                      plugins folder which is nested in the
                      Sketchup folder which is nested in the
                      Google SketchUp 8 folder which nested in the
                      Application Support folder which is nested in the
                      Library folder which is nested in the
                      Hard Drive icon
                      When I start up SketchUp 8 I see no new tools in the Tools drop-down menu.
                      Please tell me what I've done wrong.
                      Thank you
                      Cliff
                      • GaieusG
                        Hi Cliff,
                        You may need to activate it under Preferences (Sketchup menu on the Mac) > Extensions first.
                        • jeff hammondJ
                          @cst said:
                          Fredo:
                          Hard Drive icon
                          Thank you
                          Cliff
                          cliff, those are the folders you're left with upon unzipping.. you have to open those folders to get to these files:
                          %(#FF0000)[ROUNDCORNER_Dir_21
                          ZLoader__RoundCorner.rb]
                          and
                          %(#FF0000)[LIBFREDO6_Dir_34
                          LibFredo6.rb]
                          those four items go in the plugins folder at the same path you stated in your post.
                          that aside, i'm wondering if it's ok to upload an installer when someone on the forum has a question such as this..
                          packagemaker comes with osx developer tools and it's pretty easy and fast to make an osx .pkg
                            Got a quick tutorial for this?
                            And it let the user install to the correct SU version if he/she has multiple?
                            • jeff hammondJ
                              this is the reference i've used:
                              http://developer.apple.com/library/mac/#documentation/DeveloperTools/Conceptual/PackageMakerUserGuide/Introduction/Introduction.html
                              i've tested quite a few different plugins with it on 4 different macs and haven't encountered any problems or bad installs..
                              your second question though, no, i haven't tried doing that yet as i've always just done it out of personal curiosity.. i made the installers version specific but i'm pretty sure they can be done as one installer for multiple versions.. i haven't really explored it any further but i might get into it again and figure out some more options.
                              • B
                                boon
                                Hi Fredo,
                                Julien
                                I use mac too and I did have exactly the same problem with Julien.
                                • JujuSKPJ
                                  Hi all,
                                  Any upadte on this topic? Still have the same problem.
                                  Thanks julien
                                  • jeff hammondJ
                                    Hi all,
                                    Thanks julien
                                    I'm a bit confused because I use the plugin on three different macs (with various SU versions and operating systems) and have never had a problem with it.
                                    Fredo, can you think of any reasons why this may be happening to some people and not others such as conflicting plugins?
                                    • jeff hammondJ
                                      hey julien.
                                      i do notice a slight delay in response with RoundCorner (though it's very slight.. nothing like you describe)
                                      as shown in this screenshot:
                                      does that speed things up for you? (you can still access the RoundCorner parameters with the palette closed by pushing the tab key)
                                      also:
                                      i noticed in your ruby warning that you're installing plugins in your user library..
                                      this used to cause a lot of problems on macs but most of the plugin writers have done something to fix it (there are still a few problem rubies out there)
                                      google instructs to install rubies in the system library:
                                      http://code.google.com/apis/sketchup/docs/loading.html
                                      that's where their sample rubies etc are upon a fresh SU install (did you create the user/plugin folder on your own?)
                                      here's a little automator app that will fix your install location:
                                      su7 and su8 version included..
                                      just double click the specific version(s) you have on your machine.
                                      it simply moves all the files out of your User/Library/Application Support/Google SketchUp 8/SketchUp/plugins folder ...
                                      and into the proper location of
                                      Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins ...then deletes the empty user plugin folder..
                                      you can do this manually if you choose but it should be done.. i don't necessarily think it will fix your RoundCorner problems but it will prevent problems down the road..
                                      • JujuSKPJ
                                        Hi Jeff,
                                        Thanks for your reply, I'll check that and come back to you.
                                        Julien
                                        • fredo6F
                                          Hi Jeff,
                                          Julien
                                          Julien,
                                          What I can do is to prepare a file with traces that you can run. The issue seems to be in the Palette drawing, but I don't see why it can take so long.
                                          • JujuSKPJ
                                            Jeff,
                                            I have try to shrink the palette, but does respond for me (still same problem).
                                            However, I change the plugins folder as mention, and try out the roundcorner plugin. I still have the problem, but it responds a little more better.
                                            First improvement, we are on the good way -)
                                            Thanks julien
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 74
                                            • 75
                                            • 15 / 75
