    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • fredo6F
      @kylebc86 said:
      I am just wondering if anyone can help me. I have installed both lib fredo file and the round corner plugins as instructed, however when i launch sketchup, i get a warning message that says
      *"Cannot load plugin Round Corner because the script cannot create DEFPARAM_Dir folder in: Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
      Please create it manually respecting the case"*
      Anybody have any idea what i need to do. Thanks in advance
      Kyle
      Kyle,
      Just as the message says, create a folder named DEFPARAM_Dir in the directory Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
      The script cannot create it by itself, probably because of some security settings on your Mac.
      • K
        kylebc86
        Brilliant, thanks Fredo, had a feeling it was something as simple as that.
        • O
          OZX
          Salut,
          C'est très très lent sur ma machine. Une solution ?
          • JujuSKPJ
            JujuSKP Extension Creator
            Dear All,
            I recently update to sketchup 8, get the last fredo lib (3.4c) and the last roundcorner plugin.
            I also change windows to mac os.
            I have tried roundcorner plugin on sketchup 7 on windows (work fine), sketchup 7 and 8 on Mac (just crash or really lagy).
            Any idea for this problem?
            I am using Mac os 10.6
            Thank for reply,
            • fredo6F
              Dear All,
              Thank for reply,
              Juju,
              Can you be more explicit:
              • when is it slow: when you luanch it, when you select edges, when you generate the round geometry?
              • when does the crash on Mac happen?
              • is it slow for complex models or regradless?
              • JujuSKPJ
                Hi Fredo,
                First congratulation for this plugin (very usefull).
                I will try to explain my problem clearly in English (i am french native)
                To be more explicit:
                I have made some tries with complex and very simple models (simple cube), the problem is exactly the same.
                (I might think that the problem come from the ToolBar display, but I am not expert).
                • When I launch the tool, sketchup became lagy (almost freezing) and the toolbar make long time to appear (minimum 20 seconds).
                • It is mostly impossible to change the parameters on the tool bar (take 1, 2, 3 minutes to respond). I also try to change the settings with the Sketchup toolbar (the one at the right bottom) and the problem is still the same.
                • The probleme is the same if I want to select an edge.
                • If i do not change parameters (avoiding me 5 to 10 minutes of waiting), I can validate the action and Sketchup does the round corner. But it is also very laggy (2 to 3 minutes between my click and the corner drawing).
                To resume, Sketchup become really lagy as soon as I launch the round corner tools.
                The strangest thing is that when I use the round corner, not only sketchup freeze but my whole mac interface.
                I hope my explanations are clear.
                Thanks for your help,
                Julien
                • fredo6F
                  Julien,
                  1. Do you notice the same lagy behavior when you use my other plugins using the button palette interface (such as Curvilft or Tools On Surface)?
                  2. When you execute the operation (click with green check mark), do you see the progressbar immediately and then progressing slowly, or do you see it appearing only at the end briefly? This will tell me if the problem is in the GUI refresh or in the global execution of the ruby code.
                  3. Also, do you have a real crash on your Mac, or is it just álmost freezing'?
                    To Mac users: Do you have the same bad experience with RoundCorner?
                  • JujuSKPJ
                    Fredo,
                    1. Your other plugin such as Tools On Surface work fine (I just download and test the last version of Tools on Surface)
                    2. Yes, the progress bar is working normally (As soon as I execute the operation, progress bar works and quickly). The difficult and laggy thing is to launch the operation.
                    3. Not a real crash, my commands doesn't respond until sketchup come back to normal.
                    Hope it helps
                    thanks
                    • JujuSKPJ
                      If it can help, here is an extract of my ruby console for One operation:
                      /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1186: warning: Object#id will be deprecated; use Object#object_id
                      /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1187: warning: Object#id will be deprecated; use Object#object_id
                      • fredo6F
                        This one is known (and now in SU8 Windows). It will be fixed in the next release of the plugins, but it is harmless.
                        Do you have the performance problem on Windows too?
                        Also, Can you download and install Curviloft. It includes LibFredo6 3.5, and it is better to see if the problems also occurs with this more recent version (the issues seems to be with the GUI).
                        • JujuSKPJ
                          Ok, so I have to wait for the next release?
                          I am sorry but I am not using Windows anymore -)
                          I was used to work with sketchup 7 and the round corner plugin without any problems.
                          I have download and install curviloft, it works really fine and quick.
                          I have retry roundcorner, still having the same problem.
                          thanks fredo
                          • fredo6F
                            thanks fredo
                            Then, it would be helpful if other Mac users could tell if they have similar performance issues.
                            • C
                              CST
                              Fredo:
                              I use Mac OS 10.6 and SketchUp 8.
                              I have dropped RoundCorner%202 & LibFredo6%203 into the
                              plugins folder which is nested in the
                              Sketchup folder which is nested in the
                              Google SketchUp 8 folder which nested in the
                              Application Support folder which is nested in the
                              Library folder which is nested in the
                              Hard Drive icon
                              When I start up SketchUp 8 I see no new tools in the Tools drop-down menu.
                              Please tell me what I've done wrong.
                              Thank you
                              Cliff
                              • GaieusG
                                Hi Cliff,
                                You may need to activate it under Preferences (Sketchup menu on the Mac) > Extensions first.
                                • jeff hammondJ
                                  @cst said:
                                  Fredo:
                                  Hard Drive icon
                                  Thank you
                                  Cliff
                                  cliff, those are the folders you're left with upon unzipping.. you have to open those folders to get to these files:
                                  %(#FF0000)[ROUNDCORNER_Dir_21
                                  ZLoader__RoundCorner.rb]
                                  and
                                  %(#FF0000)[LIBFREDO6_Dir_34
                                  LibFredo6.rb]
                                  those four items go in the plugins folder at the same path you stated in your post.
                                  that aside, i'm wondering if it's ok to upload an installer when someone on the forum has a question such as this..
                                  packagemaker comes with osx developer tools and it's pretty easy and fast to make an osx .pkg
                                    Got a quick tutorial for this?
                                    And it let the user install to the correct SU version if he/she has multiple?
                                    • jeff hammondJ
                                      this is the reference i've used:
                                      http://developer.apple.com/library/mac/#documentation/DeveloperTools/Conceptual/PackageMakerUserGuide/Introduction/Introduction.html
                                      i've tested quite a few different plugins with it on 4 different macs and haven't encountered any problems or bad installs..
                                      your second question though, no, i haven't tried doing that yet as i've always just done it out of personal curiosity.. i made the installers version specific but i'm pretty sure they can be done as one installer for multiple versions.. i haven't really explored it any further but i might get into it again and figure out some more options.
                                      • B
                                        boon
                                        Hi Fredo,
                                        Julien
                                        I use mac too and I did have exactly the same problem with Julien.
                                        • JujuSKPJ
                                          Hi all,
                                          Any upadte on this topic? Still have the same problem.
                                          Thanks julien
                                          • jeff hammondJ
                                            Hi all,
                                            Thanks julien
                                            I'm a bit confused because I use the plugin on three different macs (with various SU versions and operating systems) and have never had a problem with it.
                                            Fredo, can you think of any reasons why this may be happening to some people and not others such as conflicting plugins?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 74
                                            • 75
                                            • 15 / 75
