    SU 9 Wishlist
    436 Posts 99 Posters 151.9k Views 99 Watching
      I find the zooming over blank space to be too aggressive - too big jump. Troublesome when I'm working on just edges - like imported DWG data. I have to constantly keep aiming the cursor to be over an edge to avoid SU from zooming too far.
        tfdesign
        Oh yes, fix the bl**dy layers management!! Why is it that within a grouped object, several entities can co-exist on different layers all at the same time? This is utterly crazy! I can understand for whole objects, but single little things? It's silly. Perhaps I'm missing something here? πŸ˜•
          tfdesign
          Really?? Maybe we're both missing something? Is there a missing variable somewhere, that can change this? Mine is painfully slow. πŸ˜•
            I find it useful to have fine control of the entities like that. Let me toggle on/off edges for parts of the mesh for instance - which is useful to control the object's presentation.
              When you zoom while the mouse if over an entity to goes slower - and I wonder if the speed depends on how close it is to the camera - so when you get closer it goes slower.
              Zoom in while the mouse if over empty space and the zoom goes into hyperdrive.
              • EscapeArtistE Offline
                EscapeArtist
                Ability to sort and file Plugins!
                  tfdesign
                  Thom, I've just tried again, and I get the problem when I'm zoomed right in (something I do a lot). I can't seem to replicate what you are getting. There however doesn't seem to be a problem for me when I'm zoomed out. I also never use the zoom tool. Always the wheel on my Logitech Trackball Marble.
                  Tom
                    Yea - I always use the mouse scroll wheel as well.
                    • kenK Offline
                      ken
                      Sketchup 9. I wish to have a set of tab, similar to the scenes tabs, but for layers. This way I could pass my model to co-workers and I could have a set of layer Tabs across the top along with the scene tabs. They could select a scene tab, and then make selections of the layer tabs to add more less to the model in that particular scene. Unlike scenes, where you could only have one tab on at a time, the layer tab you would be able to have more than one on at a time. And the layer tabs could be all the layers or just a select few.
                      Ken
                        remus
                        Ken, what would be the difference between that and having the layers manager open?
                        • kenK Offline
                          ken
                          Well, I model with multiple layers, and I would want only the upper layers, that would be completed parts in the layer tab. To me it would just make it easier to send to people who have a limited knowledge of how Sketchup operates.
                          Ken
                            sir.sanio
                            I would also like multiple core support.
                            You can't even buy a computer anymore that does not at least have two cores anyways.
                            I really would like SU to be able to utilize my machines resources!
                            And yes, 64 bit please!
                              tfdesign
                              I think we've already been over this subject enough already. SCF had SketchUp Central here over the last couple of weeks assuring us that apart from rendering (which SU doesn't possess- apart from in plugins- which work independently from SU anyway), a 64 bit boost will achieve very little. Having a dual (or more) processor, believe it or not, has very little influence over speed as well.
                                remus
                                you can read about it here, if your so inclined: http://forums.sketchucation.com/viewtopic.php?f=15&t=30490
                                • HieruH Offline
                                  Hieru
                                  The impression I got from the discussion is that the current SU architecture won't benefit from multi-core or X64.
                                  The implication being that SU would have to be rebuilt from the ground up to take advantage of multi-core and X64?
                                  www.davidhier.co.uk
                                    for 64bit yes - for multi-core it's not possible for many of the tasks.
                                    Most of the other modelling packages the claim multi-core support are the ones with render engines and multiple cores are used only for the rendering process.
                                    • HieruH Offline
                                      Hieru
                                      In theory could SU be rebuilt so that it uses the CPU for its real-time rendering of models? Or even a CPU & GPU combo?
                                      If so, then presumably multi-core support would be of some benefit and allow for better handling of high poly models?
                                      I don't really understand that much about software, so I'm probably talking a load of nonsense.
                                      www.davidhier.co.uk
                                        In theory - but it'd be a completely different application.
                                        Using multi-core for rendering doesn't mean it'll handle more polygons for a smooth navigation in the viewport.
                                        SU renders a sketchy view of the model in real time - as oppose to most other modelling application that reply on some render system. Because of that design difference it can't be directly compared to other apps. SU is a WYSIWYG kind of modeller - most other modelling applications aren't - they diaply simplified proxies of what you get when you eventually render.
                                        Comparison of SU vs Max/Maya etc is an apple vs oranges comparison.
                                        • HieruH Offline
                                          Hieru
                                          That's what I thought.
                                          I appreciate that. I was just throwing ideas out there and wondering how SU could be modified to better handle high poly models.
                                          A lot of people seem to think (I know I used to) that moving to 64 bit and multi-core would be a simple measure that would provide a magic bullet to deal with all the demands/requests people have for SU. Since it appears that this isn't the case, it does beg the question, how exactly can SU be changed to greatly improve performance? Is it even possible without starting again from scratch?
                                          More importantly, would all the things we love about SU go out the window if the entire focus of redevelopment focused on better performance with high poly models etc?
                                          www.davidhier.co.uk
                                            sir.sanio
                                            Thanks for bashing my wishes.
                                            I disagree with you, having built massive models which would have profited from more processing power and ram. They still tend to crash a lot. Lack of ram also prohibits me from exporting any still image above a 7000 pixel resolution, even though the magical number of 10000 appears in the export dialog.
                                            Disagreements aside, this is a wish list, i can wish for whatever i want.
                                            So beside 64bit, multiple processor support and the obligatory pony, i also wish for a time counter that tells me how much time i have spent on the model.
                                            Best regards,
                                            sanio
                                            • 21
                                            • 22
                                            • 2 / 22
