    [request] Polygon count plugin
    14 Posts 8 Posters 7.3k Views 8 Watching
      I'm sure there is one somewhere...
      If not it's relatively easy to iterate all of the model.definitions.entities faces [*definition.instances.length] and all of the model's faces - using each face.vertices.length-vertices-2...
      ๐Ÿค“
        Doesn't MeshLab provide this info? If you've the ability to export to it's supported file types?
        Where Pilou when you need him? ๐Ÿ˜Ž
        • jeff hammondJ Offline
          ๐Ÿค“
          haha.. i love when the coders talk to the plebs.. 'ah, it's simple' etc.. that sentence above might as well look like this to me:
          If not it's relatively easy to ้ๆญทๆ‰€ๆœ‰็š„ๆจกๅž‹ๅฎš็พฉๅฏฆ้ซ”ๆ‰€้ข่‡จ็š„ๅฎš็พฉๅฏฆไพ‹็š„้•ทๅบฆๅ’Œๆ‰€ๆœ‰ๆจกๅž‹็š„่‡‰ - ็”จๆฏๅ€‹้ข้ ‚้ปž้•ทๅบฆ้ ‚้ปž -2
          ๐Ÿ˜† ๐Ÿ˜†
          • ken28875K Offline
            ken28875
            Hello guys,
            @ TIG: What the hell are you talking about??? โ“ LOL
            @ Rich: I want to see the polygon count right in Sketchup so I don't have to export back and forth between 2 programs.
            @ Jeff: I agree with you. LOL ๐Ÿ˜„
            Thanks,
            _KN
            Follow Your Dreams.
            • Chris FullmerC Offline
              Currently you can get a full face and edge count. But you want a little more than that, is that what your asking? You would like too see specifically tri faces and quad faces only? What about faces that are mor than quad faces?
              • ken28875K Offline
                ken28875
                Hi Chris,
                Yes, something similar to this in Maya:
                http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/Maya_polycount.jpg
                You said we currently are able to see a full face and edge count. How do you do it?
                Thank you,
                _KN
                Follow Your Dreams.
                  Copy+paste this into a file called facecount.rb in the Plugins folder
                  def facecount()
                    num=0
                    model=Sketchup.active_model
                    ss=model.selection
                    if ss[0]
                      ents=ss.to_a
                    else
                      ents=model.entities.to_a
                    end#if
                    defs=model.definitions
                    ents.each{|e|num=num+(1)if e.class==Sketchup;;Face}
                    defs.each{|d|
                      d.entities.each{|e|
                        n=d.instances.length
                        num=num+(1*n)if e.class==Sketchup;;Face
                    if ss[0]
                      puts "Faces in Selection ="
                    else
                      puts "Faces in Model+Definitions ="
                    end#if
                    return num
                  end#def
                  To run type facecount in the Ruby Console - it prints the count of faces.
                  Copy+paste this into a file called tricount.rb in the Plugins folder
                  def tricount()
                    num=0
                    ss=model.selection
                    if ss[0]
                      ents=ss.to_a
                    else
                    end#if
                    ents.each{|e|num=num+(e.vertices.length-2)if e.class==Sketchup;;Face}
                    defs.each{|d|
                      d.entities.each{|e|
                        num=num+((e.vertices.length-2)*n)if e.class==Sketchup;;Face
                    if ss[0]
                      puts "Potential Triangular-Faces in Selection ="
                    else
                      puts "Potential Triangular-Faces in Model+Definitions ="
                    end#if
                    return num
                  end#def
                  To run type tricount in the Ruby Console -
                  it prints the count of potential triangulated-faces [even if they currently have more vertices].
                  These count all faces in the model and in instances, groups and images...
                    You can open the Model Info dialog box and it shows edge and face count. Go to Window > Model Info and click on the "statistics" tab. Then make sure you have the statistics set to "Entire Model" and turn on the "Show Nested Components" checkbox. Then it will show you a good bit of info.
                    • ken28875K Offline
                      ken28875
                      Thanks TIG and Chris.
                      Have a good weekend.
                      _KN
                      Follow Your Dreams.
                        The Plugin Index is your friend: http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                        Counttriangles.rb by Eleandor
                        http://forums.sketchucation.com/viewtopic.php?t=16843
                          Knew I'd see it somewhere! ๐Ÿ˜’
                          • ArisA Offline
                            Aris
                            Hi all,
                            on a similar topic, it would be great to be able to select a group or component and be able to see statistics just for this specific object.
                            I am working with heavy scenes and cooperating with other people, and sometimes I have to deal with garbage models within the scene
                            (it is not uncommon to have a flower pot in some obscure corner that takes up half of the scene's file size)
                            Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                            • srxS Offline
                              srx
                              Even more, it would be nice to have a plugin which helps in optimizing SU model by marking groups and components with colors according to their polygon count. ๐Ÿ’š
                              and than gives an option to reduce them ๐Ÿ˜„ (useful for making proxies also) ๐Ÿ’š
                              www.saurus.rs
