    [request] Polygon count plugin
    14 Posts 8 Posters 7.4k Views 8 Watching
    • ken28875K Offline
      ken28875
      Hi there Masters of Plugins,
      Does anyone know if there is a plugin that shows me the polygon count (quad and triangle faces) when clicking on the model? If not, could someone please write it for me?
      Thank you very much,
      _KN
      Follow Your Dreams.
      • TIGT Online
        I'm sure there is one somewhere...
        If not it's relatively easy to iterate all of the model.definitions.entities faces [*definition.instances.length] and all of the model's faces - using each face.vertices.length-vertices-2...
        ๐Ÿค“
          Doesn't MeshLab provide this info? If you've the ability to export to it's supported file types?
          Where Pilou when you need him? ๐Ÿ˜Ž
          • jeff hammondJ Offline
            ๐Ÿค“
            haha.. i love when the coders talk to the plebs.. 'ah, it's simple' etc.. that sentence above might as well look like this to me:
            If not it's relatively easy to ้ๆญทๆ‰€ๆœ‰็š„ๆจกๅž‹ๅฎš็พฉๅฏฆ้ซ”ๆ‰€้ข่‡จ็š„ๅฎš็พฉๅฏฆไพ‹็š„้•ทๅบฆๅ’Œๆ‰€ๆœ‰ๆจกๅž‹็š„่‡‰ - ็”จๆฏๅ€‹้ข้ ‚้ปž้•ทๅบฆ้ ‚้ปž -2
            ๐Ÿ˜† ๐Ÿ˜†
            • ken28875K Offline
              ken28875
              Hello guys,
              @ TIG: What the hell are you talking about??? โ“ LOL
              @ Rich: I want to see the polygon count right in Sketchup so I don't have to export back and forth between 2 programs.
              @ Jeff: I agree with you. LOL ๐Ÿ˜„
              Thanks,
              _KN
              Follow Your Dreams.
              • Chris FullmerC Offline
                Currently you can get a full face and edge count. But you want a little more than that, is that what your asking? You would like too see specifically tri faces and quad faces only? What about faces that are mor than quad faces?
                • ken28875K Offline
                  ken28875
                  Hi Chris,
                  Yes, something similar to this in Maya:
                  http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/Maya_polycount.jpg
                  You said we currently are able to see a full face and edge count. How do you do it?
                  Thank you,
                  _KN
                  Follow Your Dreams.
                  • TIGT Online
                    Copy+paste this into a file called facecount.rb in the Plugins folder
                    def facecount()
                      num=0
                      model=Sketchup.active_model
                      ss=model.selection
                      if ss[0]
                        ents=ss.to_a
                      else
                        ents=model.entities.to_a
                      end#if
                      defs=model.definitions
                      ents.each{|e|num=num+(1)if e.class==Sketchup;;Face}
                      defs.each{|d|
                        d.entities.each{|e|
                          n=d.instances.length
                          num=num+(1*n)if e.class==Sketchup;;Face
                      if ss[0]
                        puts "Faces in Selection ="
                      else
                        puts "Faces in Model+Definitions ="
                      end#if
                      return num
                    end#def
                    To run type facecount in the Ruby Console - it prints the count of faces.
                    Copy+paste this into a file called tricount.rb in the Plugins folder
                    def tricount()
                      num=0
                      ss=model.selection
                      if ss[0]
                        ents=ss.to_a
                      else
                      end#if
                      ents.each{|e|num=num+(e.vertices.length-2)if e.class==Sketchup;;Face}
                      defs.each{|d|
                        d.entities.each{|e|
                          num=num+((e.vertices.length-2)*n)if e.class==Sketchup;;Face
                      if ss[0]
                        puts "Potential Triangular-Faces in Selection ="
                      else
                        puts "Potential Triangular-Faces in Model+Definitions ="
                      end#if
                      return num
                    end#def
                    To run type tricount in the Ruby Console -
                    it prints the count of potential triangulated-faces [even if they currently have more vertices].
                    These count all faces in the model and in instances, groups and images...
                      You can open the Model Info dialog box and it shows edge and face count. Go to Window > Model Info and click on the "statistics" tab. Then make sure you have the statistics set to "Entire Model" and turn on the "Show Nested Components" checkbox. Then it will show you a good bit of info.
                      • ken28875K Offline
                        ken28875
                        Thanks TIG and Chris.
                        Have a good weekend.
                        _KN
                        Follow Your Dreams.
                          The Plugin Index is your friend: http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                          Counttriangles.rb by Eleandor
                          http://forums.sketchucation.com/viewtopic.php?t=16843
                          • TIGT Online
                            Knew I'd see it somewhere! ๐Ÿ˜’
                            • ArisA Offline
                              Aris
                              Hi all,
                              on a similar topic, it would be great to be able to select a group or component and be able to see statistics just for this specific object.
                              I am working with heavy scenes and cooperating with other people, and sometimes I have to deal with garbage models within the scene
                              (it is not uncommon to have a flower pot in some obscure corner that takes up half of the scene's file size)
                              Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                              • srxS Offline
                                srx
                                Even more, it would be nice to have a plugin which helps in optimizing SU model by marking groups and components with colors according to their polygon count. ๐Ÿ’š
                                and than gives an option to reduce them ๐Ÿ˜„ (useful for making proxies also) ๐Ÿ’š
                                www.saurus.rs
