    Only certain parts of material is render, please help!
    renderpluginsextensions
    16 Posts 3 Posters 3.0k Views 3 Watching
      kken
      Hello guys, I am currently having some tough problem with rendering brickworks in my scene. As you can see from the picture, the top part of my brickworks are rendered accordingly with the bumps and displacement but the bottom part of the material is not rendered accordingly. Been trying to solve this problem for nearly a day but with little success.
      Anyway, do comment on the brick render if someone could tip me to make a more realistic brick render. Lastly, for the bump and displacement maps, I am just using the same file that I used for the material, would that be okay? if not, how and what should I do? please advise as the tutorial manual that come with vray is not as comprehensive as it should be. I am still a new user in this software. Anyway, thank you for any replies, thanks!
      http://y6i92a.bay.livefilestore.com/y1psbLuUhCxW6WWG2BdSQuLYTQwYpLSLQxjk_nWj-Pz3wn-FFW5m7MObXnHJZsqwRMjxHy3mRftNl5SXkNOucq-c3ffLMbGBEf3/testing brickwork.jpg?psid=1
      http://y6i92a.bay.livefilestore.com/y1psbLuUhCxW6V_4xS_4Ud-TwCaJ_0TXfTHwzq3Zi3noWgCwIYmo4-Oug8eePHTPe5zUc_fytwXwoPCMJw5HM57WQ2pb0Dj9GKe/Testing brickwork 2.jpg?psid=1
      http://y6i92a.bay.livefilestore.com/y1pKI43phO875Sgmgrfh96IqjTMJ6kB1wF0rgfA2dqyzk9nO0RCNQM8Te7f7sQxmaz3Q-t53TqYcTtRFF0Tl5vLFcD1NWPSW3HA/Capture.PNG?psid=1
      ps: my vray version is 1.48.89 and i am using sketchup pro 7
        What's the question? Displacements not working?
        If so: geometry that you want displaced needs to be grouped so it is not connected in any way with any geometry with any other material. (that includes edge and backside materials.)
        • Al HartA Offline
          Al Hart
          It is not correct to use a realistic image of a stone or brick wall to create bump maps or displacement maps, but many people do it just to get a different look.
          Check out this page on the SketchUp Sage site: Bump Maps
          True Bump Maps
          Sample of "true" bump map rendered to create a stone effect:
          https://docs.google.com/File?id=dchvmk87_44fn8hrbdt_b
          This is the "bump map image" used to create this effect:
          http://wiki.renderplus.com/images/thumb/0/07/Stone-bump.jpg/250px-Stone-bump.jpg
          Bump Map from color image
          Here are two images. The second uses the first image as an "not technically correct" bump map:
          http://wiki.renderplus.com/images/thumb/6/63/No-bump-map.jpg/400px-No-bump-map.jpg
          http://wiki.renderplus.com/images/thumb/d/d3/Bump-map.jpg/400px-Bump-map.jpg
          Al Hart
          IRender nXt from Render Plus
            kken
            thanks for the reply! Sorry but I still do not understand how it suppose to be done. Is it means that I should isolate the group of object that are using the bricks texture from the rest of the materials? sorry, I am still pretty new to this software and hopefully you would pardon my ignorance in using certain feature of this software.
              kken
              True Bump Maps
              thank you for the thorough explanation on the bump map. That's a very detailed explanation. For my current render, I am re-using the original images of the textures but convert them to black and white in PS5. Then, I increase the contrast between the dark and white to create greater depth, in hope that the bump map would produce a more apparent bump.
                You control the strength of the bump by adjusting the Multiplier value to for the bump texture.
                  kken
                  Thanks, i try to regroup the texture of the bricks from sketctup, re-create the new material; bricks. However, the bump and displacement are still not working. Sorry but wonder if you could spend some time to explain about the group thing so that I may able to render the texture accordngly? perhaps a link that could explain my situation would be nice as well.
                  Anyway, really appreciate the time that you are spending to reply me.
                    Sounds like there are multiple issues here.
                    Bump mapping does not require you to isolate the materials.
                    Only for displacements do you need to make sure the geometry is not connected to any other materials.
                    Could you provide a simple example model of what you try to do?
                      kken
                      Sorry, I must have typed wrongly. Earlier you suggest that I isolate the materials or something along the line because apparently my displacement setup is not right, but I wasn't too sure how to do it. So, i thought probably I could just separate the brickworks material (it consists of several blocks of the same material) and paint them again with a newly created paint of the brickworks. However, it still doesn't work. Anyway, I would show an image to explain the bits where the material is consist of several blocks of the same material. notice how one face of the brickworks are selected and the other small bit (lower right) is not - what I am trying to say is that the wall has a few sections where they need to be of the same texture.
                      http://y6i92a.bay.livefilestore.com/y1p0GrtWqYHE9j_2_t7faVOPWrkOlq1hmFp4EnVsXV60K0840UG3TGRRjS1_QlIEf1JYd0Lnc46rjiItGp-6LcdGNhFhKrVBnjg/Capture again.PNG?psid=1
                      Anyway, both bits of bump and displacement doesn't seem to be working despite that the preview in the material editor show otherwise. Anyway, what do you mean by a simpler model? probably uploading my model for testing would be better? however, my model is quite ridiculously big; 40mb. Let me know if you need it. Anyway, so sorry for causing all these ruckus but I have been stuck for one week doing the render but is still achieving very little success, but I really appreciate whatever that you could advise me to solve my render problem. Maybe the setting that I did or the way I applied the texture is not in the proper manner. Anyway, looking forward to hear from you again!
                        The preview in the material window is a very small model - so when you see strong effects there, there will be little effect on a big architectural model.
                        That is ok - you have have several connected faces grouped - as long as they do not connect to anything with a different material.
                        That's why I'd be good with a small model - so it's not so large to download. And it avoids the distraction of everything else.
                        Do you purge your models? If you do not purge you will end up with lots of unused data in the .skp file. You can purge from Window > Model Info > Statistics > Purge Unused.
                        Can you copy just parts of your model to a new file, with some of your walls - and include the bump map and displacement map you use?
                          kken
                          okay, thanks a lot! here is the link to the model, looking forward to hear what you could advise! thanks ya!
                          https://www.dropbox.com/home#/Vray:::
                            That link is not working.
                              kken
                              sorry, I would resend again.
                              https://www.dropbox.com/home#/Public/Vray:::
                                That is just a link for yourself.
                                Refer to these page on how to share Dropbox files:
                                https://www.dropbox.com/help/16
                                https://www.dropbox.com/help/167
                                  kken
                                  sorry, here is the link to the sketchup file:
                                  http://dl.dropbox.com/u/4088775/Vray/testing%20model.skp
                                  here are the brick texture and its bit map
                                  http://dl.dropbox.com/u/4088775/Vray/brick002%20-%20Bump%20Map.jpg
                                  http://dl.dropbox.com/u/4088775/Vray/brick002.jpg
                                  thanks once again!
                                    kken
                                    hello just to check if links are working.. let me know, thanks!
