    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 36.4k Views 23 Watching
      sepo
      Looks good.
      • soloS Offline
        Thanks.
        5 minutes, 5 cars. 💚
          What hardware specs you got Pere?
          • soloS Offline
            i7 940, 12GB ram, Win 64, Thea 64
              And the GPU?
              • soloS Offline
                Geforce 280
                  tomasz
                  @thomthom said:
                  And the GPU?
                  Just for a record - GPU is not being utilized in Thea yet.
                  Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                  • soloS Offline
                    6 minutes, DOF, IR unbiased, glare in Thea studio
                    • N Offline
                      notareal
                      A tutorial describing interactive render functionality is now available:
                      http://www.thearender.com/resources/Thea_interactive_render_web/index.html
                      Created by: Patrick Nieborg
                      Our technology announcement contains also some key info about interactive render:
                      http://www.thearender.com/forum/viewtopic.php?f=17&t=3435
                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                      • CadFatherC Offline
                        CadFather
                        Thea IR is really amazing...
                        • boofredlayB Offline
                          boofredlay
                          The license that came with my copy of Thea is not being recognized.
                          notareal, I sent you a PM on the Thea forum.
                          • N Offline
                            notareal
                            @Boofredlay looking on it.
                            • N Offline
                              notareal
                              Just a note, Thea Render (IR) beta download is available from public web site, so there is no registration process anymore. Feedback is much appreciated, so if possible register on forum for detailed discussion.
                              • N Offline
                                notareal
                                Thea Render academic license is introduced (for plugins too)
                                http://www.thearender.com/forum/viewtopic.php?f=16&t=3730
                                • simon le bonS Offline
                                  simon le bon
                                  @solo said:
                                  Lets not forget to mention the new 'shadow catcher'.
                                  5 minute render test.
                                  Hi Solo 😉
                                  Just a little stupid question 😳
                                  Is it possible to manage the real scene which is around the cars into Thea itself or do you do a sticking work into Photoshop or some else ?
                                  http://forums.sketchucation.com/download/file.php?id=54149&t=1
                                    • simon
                                      Ps: very nice scene!
                                  • soloS Offline
                                    Simon, I'm not sure I understand the question.
                                    • EarthMoverE Offline
                                      EarthMover
                                      Pete, I think he's asking if you can control the position and look of the HDRI image within Thea, or did you do it externally. Probably because of the seamless way that the tonal qualities match between the IBL and the Geometry. Also the CFR in there is helping sell the illusion that it's all one photograph. Hard to achieve that in other engines.
                                      Stunning render...I must say!! 👍 👍
                                      Content Creator at Skapeup
                                      • soloS Offline
                                        Ah, yes and yes.
                                        You can move the HDRi around as well as camera and objects, then as mentioned using CRF's you can pretty much blend them like I did above.
                                          simon le bon
                                          @Earthmover, 😉
                                          thanks! , You have perfectly translated my interrogations 👍=
                                          @Solo
                                          @solo said:
                                          Ah, yes and yes.
                                          How do you import this HDRI into a Thea scene? I have searched this option without find it.
                                          And also: Is it possible to include a HDRI into a SketchUp model and export the model into Thea?
                                          Very simple questions, sorry for disturbing..
                                          ++simon
                                            At the top right, go to Environment > IBL (Image Based Lighting I presume). Enable the feature you want (there are options to open different resolution images of the same file for performance reasons) and import your hdr image.
                                            If you are not planning to do any fancy stuff, Background mapping is enough (that should be a full resolution image however). For simple reflections in windows for instance, you may also wish to enable the reflection channel at least if I am not mistaken.
                                            • 4 / 8
