    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 62.9k Views 23 Watching
      And the GPU?
      • soloS
        Geforce 280
        • T
          tomasz
          @thomthom said:
          And the GPU?
          Just for a record - GPU is not being utilized in Thea yet.
          • soloS
            6 minutes, DOF, IR unbiased, glare in Thea studio
            • N
              notareal
              A tutorial describing interactive render functionality is now available:
              http://www.thearender.com/resources/Thea_interactive_render_web/index.html
              Created by: Patrick Nieborg
              Our technology announcement contains also some key info about interactive render:
              http://www.thearender.com/forum/viewtopic.php?f=17&t=3435
              • CadFatherC
                CadFather
                Thea IR is really amazing...
                • boofredlayB
                  boofredlay
                  The license that came with my copy of Thea is not being recognized.
                  notareal, I sent you a PM on the Thea forum.
                  • N
                    notareal
                    @Boofredlay looking on it.
                    • N
                      notareal
                      Just a note, Thea Render (IR) beta download is available from public web site, so there is no registration process anymore. Feedback is much appreciated, so if possible register on forum for detailed discussion.
                      • N
                        notareal
                        Thea Render academic license is introduced (for plugins too)
                        http://www.thearender.com/forum/viewtopic.php?f=16&t=3730
                        • simon le bonS
                          simon le bon
                          @solo said:
                          Lets not forget to mention the new 'shadow catcher'.
                          5 minute render test.
                          Hi Solo 😉
                          Just a little stupid question 😳
                          Is it possible to manage the real scene which is around the cars into Thea itself or do you do a sticking work into Photoshop or some else ?
                          http://forums.sketchucation.com/download/file.php?id=54149&t=1
                            • simon
                              Ps: very nice scene!
                          • soloS
                            Simon, I'm not sure I understand the question.
                            • EarthMoverE
                              EarthMover
                              Pete, I think he's asking if you can control the position and look of the HDRI image within Thea, or did you do it externally. Probably because of the seamless way that the tonal qualities match between the IBL and the Geometry. Also the CFR in there is helping sell the illusion that it's all one photograph. Hard to achieve that in other engines.
                              Stunning render...I must say!! 👍 👍
                              Content Creator at Skapeup
                              • soloS
                                Ah, yes and yes.
                                You can move the HDRi around as well as camera and objects, then as mentioned using CRF's you can pretty much blend them like I did above.
                                • simon le bonS
                                  simon le bon
                                  @Earthmover, 😉
                                  thanks! , You have perfectly translated my interrogations 👍=
                                  @Solo
                                  @solo said:
                                  Ah, yes and yes.
                                  How do you import this HDRI into a Thea scene? I have searched this option without find it.
                                  And also: Is it possible to include a HDRI into a SketchUp model and export the model into Thea?
                                  Very simple questions, sorry for disturbing..
                                  ++simon
                                  • GaieusG
                                    At the top right, go to Environment > IBL (Image Based Lighting I presume). Enable the feature you want (there are options to open different resolution images of the same file for performance reasons) and import your hdr image.
                                    If you are not planning to do any fancy stuff, Background mapping is enough (that should be a full resolution image however). For simple reflections in windows for instance, you may also wish to enable the reflection channel at least if I am not mistaken.
                                    • soloS
                                      here
                                      • simon le bonS
                                        simon le bon
                                        Thank you sirs!! 👍 😎
                                        • N
                                          notareal
                                          Thea Render RV425 Beta1.6.3 is available. Interactive render is now much faster when tweaking image-based lighting settings (IBL panel), also some network rendering & packing related bugs are fixed.
                                          • GaieusG
                                            Already downloaded!
                                            (and first time ever used an own model to post a note in TDC 😉 )
                                            • 1 / 8
