    SU 9 Wishlist
    436 Posts 99 Posters 94.4k Views 99 Watching
      tfdesign
      @thomthom said:
      I think there'll be a 8.1 before 9.0 - SU6 and SU7 both had interim releases. And 7.1 was a big one.
      Yes, I agree. I would have also said that 8 was released because of deadlines (and all those silly rumours about SU being abandoned). FWIW, there have been some very big announcements recently in the world of CAD, including that biggy from Autodesk. I would imagine Google/@Last are just trying to hold on to their customer base?
      Tom
      • PixeroP Offline
        Pixero
        Then why don't they listen to what their paying customers want?
        It's almost like they WANT us to leave them.
          Serge.N
          Which announcements? I've seen some including Autodesk products able to read buildings of the 3dWarehouse. But from your point of view, which are the most important announcement or features recently added in CADs?
            tfdesign
            This one.
            But I guess being a Windows user, you probably would have missed that? 😄
              Serge.N
              Yes, I did. Well I'd rather write that I didn't realized that's such a big achievement. And what about Revit? Indeed, I imagine Autodesk still have Autocad on Windows due to legacy issue. If they could they would have made everybody switch for Revit or Inventor.
              • mitcorbM Offline
                mitcorb
                Remus said: "Thought id get in there nice and early 😆 "
                Frederick said: "Was thinking about posting this yesterday evening - but didn't dare... 😳"
                😆 Shear hubris 😆
                • BurkhardB Offline
                  Burkhard
                  http://forums.sketchucation.com/viewtopic.php?f=10&t=14234
                  You can completly copy and paste....
                  http://www.ia-plus.de
                  • jeff hammondJ Offline
                    basically, i just wish for better performance in certain areas.
                    i did an intersect operation last night which took 3.5 hours to complete (about 800 low poly spheres intersecting with a triangulated mesh)..
                    of course, higher poly count.. i personally don't need 2 million in a model but i'm occasionally up in the 150,000 range and i wish it performed the same as say 20,000.
                    UV mapping upgrades (even if it's opening up more of the API to the scripters and let them make it happen).. [and even then, i'm not quite sure what i mean by better UV.. i just know that if i texture a curved surface, i'd rather it not be divided up the way it currently is.]
                    and on that note, i actually wouldn't wish for much of a change at all to sketchup except root level performance.. i'd like to be able to customize through plugins instead of having a gazillion options that i don't need in the main app.. (assuming, for every 1 feature or tool i want/need, there would have to be 20 others to accommodate everyone else's wishes)
                    so yeah, i'm sure the ruby writer's have plenty of wishes so i'm actually going to hand all of my remaining wishes to them and they can use them as they please 😄
                      Ruturaj
                      Hello,
                      I think add rotate tool in to the material >> edit
                      see below .......
                      Thanks,
                      RuturaJ
                      • boofredlayB Offline
                        boofredlay
                        "Folder organization for the "In Model" material tab. Ex: grouping materials by component, allowing manual creation of folders within the "In Model" tab or when you create or import a group or component, have the option to create or choose a folder."
                        I posted the above on the Google Moderator that everyone has access to here:
                        https://www.google.com/moderator/#16/e=24a7a
                        • kenK Offline
                          ken
                          My wish for Sketchup 9.
                          I get three types of CAD drawings. The first is the original cad drawings, which I can use without any problems. The second is a PDF scanned drawing of an older hand drawing, that never was a CAD drawing. Which, I can import into Adobe Elements and turn parts of the drawing into PNG files which I can use, with some difficulty. And the third type is a PDF drawing either saved or printed from a CAD drawing.
                          With the last drawing type, I have a program, PFD2DFX, which helps, and give me the opportunity to work with the drawing.
                          So my wish is to have a native PDF to Sketchup importer, such that I don’t need to use another program to convert the PDF to a workable Sketchup drawing. This importer would only work on PDF files made from CAD drawing by the process of either exporting or printing from the CAD program to a PDF drawing.
                          It would also be nice if one could import a scanned PDF drawing into Sketchup, like you can do now with a PNG or JPG file.
                          Thanks for listening and the great Basecamp.
                          Ken
                          Ken
                            tfdesign
                            That's odd. Can't you do this? I can do it here- I just tried. Perhaps it's a Windows thing?
                            • kenK Offline
                              ken
                              No, I believe that the Mac's can, but not the windows.
                              Ken
                                something that i think would be interesting, helpful, as well as just plain cool (and something i feel google might be into) is a web version of sketchup.
                                i upload a model then other people can join in and watch, navigate, edit, voice conference, etc..
                                this is already happening in basic form but google seems to be one of the best companies to really make something like this work properly.
                                  d12dozr
                                  ...or even just a web-based Sketchup viewer so a client doesn't have to download anything...make it have the ability to support scenes for easier navigation.
                                  http://goo.gl/f7ooYh
                                    biff
                                    How about the ability to incorporate equations into the measurements box, a la revit type equations. E.G. move command, then in box
                                    =3000+(1000/3)
                                    and the object moves 3333 mm.
                                    I so miss that function in SU.
                                      still wishing for the ability to rotate with snapping/inferencing..
                                      [wished for it last year too 😄 http://forums.sketchucation.com/viewtopic.php?p=192332#p192332 ]
                                      it's not even 11am yet and i already needed that ability 3 times today!
                                        Try my Free Rotate Tool v3 ?
                                        • EscapeArtistE Offline
                                          EscapeArtist
                                          Something that's driving me nuts lately is the ability to do a proper bevel job on sharp edges. IMO the SU folks probably view SU as primarily an architectural type program with a built in render solution and sharp edges aren't a concern, but when I model something that I'm going to export to an external render solution it isn't generally a house. In fact, I've never exported a house; my models all been real-world objects that don't have sharp edges. To be honest, I have yet to find a renderer that does a decent job of beveling. The bevel and bevel by bezier scripts work ok, but I'm forever chasing down mis-matched edges, holes, and surfaces that have shot past the object's edge in order to repair them (no matter the model size). It'd be great to be able to model something and have a simple, reliable bevel ability.
                                            tfdesign
                                            My wish for 9 is that the mouse zooming is just as effective over blank space as it is over a space that contains vector information (solid). It drives me crazy sometimes trying to zoom like mad, and just not to get very far.
                                            Anyone else suffer from this? (Or has TIG made a plugin to remedy the situation?)
                                            • 21
                                            • 22
                                            • 7 / 22
