    [Plugin] Selection Toys
    594 Posts 121 Posters 397.0k Views 121 Watching
      @thomthom said:
      That is both Image Opacity and Plan Tools that require TT_Lib2. Nothing to do with Selection Toys.
      That's the only way I can recreate the error is to move the Lib2 folder... Other tools load OK... We need a screen-shot of the error-message - our psychic powers are not that powerful... πŸ˜‰
      • EscapeArtistE Offline
        EscapeArtist
        My error message:
          That is the same as what TIG showed - it's not Selection Toys, it's Guide Tools and Image Opacity that both require TT_Lib2. Note the 2 digit here.
          Selection Toys require TT_Lib 1.2.0
          The two other plugins require TT_Lib 2.0.0
            stonebreaker
            SU 8 issue:
            i put the required files in the plugin folder but it doesn't appear in the app.
              @stonebreaker said:
              SU 8 issue:
              Please post a screenshot of the Plugins folder with the files where you placed them.
                stonebreaker
                Hi thomthom.
                here is the content of my plugin folger:
                #extrusionToolbar.rb
                2D#.rb
                2DTools
                bezierspline.rb
                BoolTools
                booltools.rbs
                BZ_Dir_14
                ChrisP_RadialMove_EN.rb
                clf_scale_rotate_multiple
                clf_select_outer_edges.rb
                clf_shape_bender
                clf_shape_bender_loader.r
                crvsmth.rb
                ctrlpnts.rb
                CURVILOFT_Dir_10
                CurviShear.rb
                deBabelizer.rb
                DEFPARAM_Dir
                Eclate_Deplace.3.0.2_EN.r
                Examples
                examples.rb
                extrudeEdgesByEdges.rb
                extrudeEdgesByFace.rb
                extrudeEdgesByFaces.rb
                extrudeEdgesByLathe.rb
                extrudeEdgesByLoft.rb
                extrudeEdgesByRails.rb
                extrudeEdgesByRailsByFace
                extrudeEdgesByRailsToLatt
                extrudeEdgesByVector.rb
                FREDOSCALE_Dir_20
                FredoScale_ZH.lang
                FreeRotate.rb
                fur_en
                fur_en.rb
                jointpushpull.rb
                JPP_Dir
                LibFredo6.rb
                LIBFREDO6_Dir_35
                LibTraductor.rb
                lss_tb_icons
                lss_toolbar.rb
                maxwell
                maxwell.rb
                mshstick.rb
                Ocean
                ocean_extension.rb
                offset.rb
                pathface.rb
                pb_loader.rb
                pnts2mesh.rb
                ProfileBuilder
                progressbar.rb
                proper_animation_1.07.rbs
                protrude
                protrude.rb
                ROUNDCORNER_Dir_21
                RubyWinFunc.so
                sample
                SketchyBevel.rb
                SketchyPhysics
                sketchyphysics.rb
                SketchyPhysics3
                sketchysolids.rb
                skin
                skin.rb
                SliceModeler.rb
                SoapSkinBubble
                SoapSkinBubbleTools.rb
                sublend.rb
                Subsmooth
                subsmooth_loader.rb
                surface_plotter.rb
                TheaExporter.rbs
                TheaExporter_files
                TIGtools
                TOS_Dir_16
                tt_edgetools.rb
                tt_image_opacity.rb
                TT_Lib
                TT_Lib2
                tt_plan_tools.rb
                tt_selection_toys.rb
                TT_Select_Toys
                tt_solid_inspector.rb
                Twilight
                twilight.rb
                unins000.dat
                unins000.exe
                Utilities
                utilities.rb
                win32api.so
                wudworx
                wudworx.rb
                WxSU
                ZLoader__Curviloft.rb
                ZLoader__FredoScale.rb
                ZLoader__OnSurface.rb
                ZLoader__RoundCorner.rb
                  hmm... I see no reason why it would not load.
                  Are you looking for the menus in the Tools menu and the context menu?
                  There was another user that had problems with not seeing the menus of a plugin he'd installed - turned out that the plugins was correctly installed in SU8, but the user was launching SU7. (when you doubleclick .skp files Windows will launch the last SU version you used.)
                    stonebreaker
                    yeah...i look in both menues.
                    su8 is the only sketchup app on my pc^^
                      And there are no errors at all when you start SU?
                      If you open Ruby Console, what output do you get when you type:
                      Select_Toys
                      load 'tt_selection_toys.rb'
                      TT_Lib::VERSION
                        stonebreaker
                        Select_Toys
                        --Select_Toys
                        --true
                        TT_Lib::VERSION
                        --1.2.0
                        i use the german su8 version.^^
                          I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
                          I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
                          Can you post a screenshot of your Tools menu?
                            stonebreaker
                            hi
                            now it runs...i reinstall su8 and copy the plugin seperatly in before i add my "backup-plugin" folder.^^
                            ...for whatever reason...^^
                              hm... I heard some people talk about not getting any startup errors in SU8. Maybe you experienced that and did not get any notification about any errors that prevented the plugin to load.
                              Whatever it was, I'm glad it work for you now. πŸ˜„
                                stonebreaker
                                btw. thx for the help. πŸ˜„
                                i don't want to miss your really great plugin which makes work so much easier.^^
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
                                  These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
                                  I'm not here much anymore.
                                    Jim
                                    Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
                                    Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. 😠
                                      Dan Rathbun
                                      It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
                                        Khai
                                        can someone give me a step by step idiots guide on how to actually use this?
                                        I can get it to light an edge up orange. that's all. how do you select things with it?
                                          Dan Rathbun
                                          See the first post for basic use.
                                          Thomas has a link to a Command Cheatsheet also in the first post.
                                          (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
                                            Khai
                                            erm. I did?
                                            and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
                                            this is what I mean by step by step and ... be patient? I asked once and waited...?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 29
                                            • 30
                                            • 20 / 30
