    [Plugin] Selection Toys
    594 Posts 121 Posters 565.6k Views 121 Watching
      stonebreaker
      yeah...i look in both menues.
      su8 is the only sketchup app on my pc^^
        And there are no errors at all when you start SU?
        If you open Ruby Console, what output do you get when you type:
        Select_Toys
        load 'tt_selection_toys.rb'
        TT_Lib::VERSION
          stonebreaker
          Select_Toys
          --Select_Toys
          --true
          TT_Lib::VERSION
          --1.2.0
          i use the german su8 version.^^
            I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
            I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
            Can you post a screenshot of your Tools menu?
              stonebreaker
              hi
              now it runs...i reinstall su8 and copy the plugin seperatly in before i add my "backup-plugin" folder.^^
              ...for whatever reason...^^
                hm... I heard some people talk about not getting any startup errors in SU8. Maybe you experienced that and did not get any notification about any errors that prevented the plugin to load.
                Whatever it was, I'm glad it work for you now. πŸ˜„
                  stonebreaker
                  btw. thx for the help. πŸ˜„
                  i don't want to miss your really great plugin which makes work so much easier.^^
                  • Dan RathbunD
                    Dan Rathbun
                    I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
                    These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
                    I'm not here much anymore.
                      Jim
                      Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
                      Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. 😠
                      • Dan RathbunD
                        Dan Rathbun
                        It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
                        • K
                          Khai
                          can someone give me a step by step idiots guide on how to actually use this?
                          I can get it to light an edge up orange. that's all. how do you select things with it?
                          • Dan RathbunD
                            Dan Rathbun
                            See the first post for basic use.
                            Thomas has a link to a Command Cheatsheet also in the first post.
                            (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
                            • K
                              Khai
                              erm. I did?
                              and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
                              this is what I mean by step by step and ... be patient? I asked once and waited...?
                                d12dozr
                                Khai, what are you trying to select? What function are you trying to use?
                                http://goo.gl/f7ooYh
                                • K
                                  Khai
                                  well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
                                  I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
                                  just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
                                    d12dozr
                                    Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
                                    HTH
                                    [flash=853,505:3vn20087]http://www.youtube.com/v/bemMh3gpLVI&fs=1[/flash:3vn20087]
                                      Thanks Marcus! Great video - I should put that in the original post.
                                      Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar Tools->Selection Toys->Enable Toolbar
                                        d12dozr
                                        Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
                                        http://www.youtube.com/watch?v=bemMh3gpLVI
                                        • K
                                          Khai
                                          thank you that really helps πŸ˜„
                                          tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 29
                                            • 30
                                            • 14 / 30
