    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
      tmanoso
      Hey Fredo6,
      i recently downloaded this and i cannot get it to work attached is the image of message box. 😳
      This is the message that i got when i tried to use the plugin...
      • utilerU Offline
        utiler
        Hi Fredo, Just having a bit of a problem with TOS. I'm trying to draw an arc on a curved vertical surface but it seems to be playing up a bit.... see attached short screen movie.
        Any ideas?
        Thanks in advance.
        Andrew
        TOS-ArcIssue.swf
        Just Curious...
        • Z Offline
          zilvinasz
          😍 DUDEEE!!!! your just bringin Sketchup alive!!!
          Thanks!!!
            rachmatrf
            YOU'RE THE MAN FREDO!!
              Daniel S
              There is a small problem with the polygon of 3 segments on the red axis working on 2D.
              It creates the triangle but in the other direction. On a surface works right.
              Daniel S
                derweissi
                After installing this great Plugin - I unzipped it in the plugin folder - I only get following message when starting sketchup and can't use it now. Whats wrong ? Did i make a mistake?
                Fehler beim Laden der Datei __loader.rb
                uninitialized constant TraductorFehler beim Laden der Datei EraserOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreehandOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreeScale_Common.rb
                uninitialized constant FreeScale::T6Fehler beim Laden der Datei FreeScale_Tool.rb
                uninitialized constant FreeScale::SU_MAJOR_VERSIONFehler beim Laden der Datei LibOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LineOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LoaderOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetAlgoOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PaletteOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PolylineOnSurface.rb
                uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei ShapeOnSurface.rb
                • W Offline
                  walpurgisnacht
                  I cant get fredo6 colllection to show up in my tools menu. the plugin is installed and i have it enabled in preferences but dosnt appear otherwise
                    melissa11
                    hi,
                    doesnt seem to appear under the toolbars menu. It is turned on under preferences> extensions but I dont no where it is πŸ˜•
                    new to this!
                    thanks
                      melissa11
                      Hi, Did you find out the answer to your question - I have the same problem and havent figured it out yet. πŸ˜•
                        the first post doesnt make any references to libfredo...
                        • H Offline
                          hassanykb
                          😍 this is a life saver man!!!
                          you rock Fredo!
                            Banjo
                            Hey! I'm new member at Sketchucation. Wonder how I can get the plugin "Tools on surface"
                            regards /Banjo
                            @hassanykb said:
                            :ecstatic: this is a life saver man!!!
                            you rock Fredo!
                              Hi Banjo,
                              Download it from the first post of this topic.
                                potatochips
                                why does it say there's an error???
                                http://i56.tinypic.com/23j4ltd.gif
                                Error Loading File ZLoader__OnSurface.rb
                                no such file to load -- LibFredo6.rb
                                  Hi Potatochips,
                                  Have you also installed the LibFredo library as advised in the first post?
                                    potatochips
                                    @gaieus said:
                                    Hi Potatochips,
                                    i got it to work now, thanks!
                                      Ruturaj
                                      Hello sir,
                                      your new version is working on google-sketchup pro 8 ...... ?
                                      Thank you,
                                      Ruturaj
                                      Thanks,
                                      RuturaJ
                                        yes - it work with SU8
                                          Ruturaj
                                          Thank you ,..... πŸ˜„
                                          Thanks,
                                          RuturaJ
                                            You can assume that most plugins work in SU8 if they worked in earlier versions. Just install and try.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 31
                                            • 32
                                            • 16 / 32
