    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • fredo6F
      [Important Upgrade version 1.6c, 15 May 10]
      I just realized that in v1.6b, I have introduced a ennoying bug in the inferencing of the tool LineOnSurface.
      This is fixed in this new release 1.6c.
      See main post for download: http://forums.sketchucation.com/viewtopic.php?p=76625#p76625
      • C
        chouaibcl65
        thank youuuuuu
        • keea1111K
          keea1111
          HI,
          I am trying to get this to install on my new computer and it isn't coming up for me. I have dropped both rb file as well as the tools file into the plugins folder, open sketchup and am not finding it. Is there a companion plug in needed for this, or am I missing something else. thanks so much for the help..Keea
          KEEA
          • massimoM
            massimo Moderator
            Hi Keea, have you installed LibFredo as well? Btw have you read the PDF quickcard (2. installation and configuration)?
              mavie
              After reading his installation notes and carefully loading all the components for Fredo's great Tools on Surface plugin (about 4 times), I got my error messages down to just this one upon opening SketchUp after install:
              Error Loading File Zloader_OnSurface.rb unititialized constant Traductor:Plugin
              I reinstalled Zloader (the freshest version, I believe) and have the latest version of his plugin, but I would love to find out what I'm doing wrong. MacBookPro, Snow Leopard, and I cleaned out all the bits of Fredo's older versions, etc.
              Thanks in advance for any advice,
              Mave
                mavie
                Okay, yes. Woke up fresh, tried another 2 installs and I'm good to go! Such a cool plugin. Merci bien Fredo!
                • H
                  hgdn
                  Is anyone please pointing it out for me of what is not right as I have tried a lot of times to install but still not get it? I got files LIBFREDO6_Dir_34, FREDOSCALE_Dir_20, TOS_Dir_16 and 3 rb(s) LibFredo6.rb, ZLoader__FredoScale.rb, ZLoader__OnSurface.rb located in Program Files\Google\Google SketchUp 7-pro\Plugins.. . The Fredoscale is fine and working icons shown but Tools on Surface icon(s) is not and in Preferences I saw it there and I checked that box and restart computer but still not shown. Oh one more thing that I never had installed any of those files before (3 files) so is there any relation of old and new files installed that makes it does not work or any missing things I don't know??? please tell me as I am tired of trying so many times...Thanks!
                  • fredo6F
                    Your set up seems OK. You only need these 3 folders and 3 files at the level of the Skethcup Plugin directory.
                    However, I can't judge if you have other files that would conflict and if the contnet of these folder are right. Please check the documentation, as it gives the footprint.
                    Also, you do not need to "restart the computer" to enable the plugins. Just restart Sketchup.
                    Finally, can you check the menu Tools > Fredo6 Collection and see if you have Tools on Surface submenus.
                    • H
                      hgdn
                      Hello Fredo,
                      I am glad it okay now as I deleted/installed it again and it works fine now and I have no idea why! Your design plugin stuffs are truly amazing and provide more choices in different languages around the world...very eager to try it soon!
                      Thanks for spending time of looking over the problem! 😆
                      • T
                        tmanoso
                        Hey Fredo6,
                        i recently downloaded this and i cannot get it to work attached is the image of message box. 😳
                        This is the message that i got when i tried to use the plugin...
                        • utilerU
                          utiler
                          Hi Fredo, Just having a bit of a problem with TOS. I'm trying to draw an arc on a curved vertical surface but it seems to be playing up a bit.... see attached short screen movie.
                          Any ideas?
                          Thanks in advance.
                          Andrew
                          TOS-ArcIssue.swf
                          Just Curious...
                          • Z
                            zilvinasz
                            😍 DUDEEE!!!! your just bringin Sketchup alive!!!
                            Thanks!!!
                              rachmatrf
                              YOU'RE THE MAN FREDO!!
                                Daniel S
                                There is a small problem with the polygon of 3 segments on the red axis working on 2D.
                                It creates the triangle but in the other direction. On a surface works right.
                                Daniel S
                                  derweissi
                                  After installing this great Plugin - I unzipped it in the plugin folder - I only get following message when starting sketchup and can't use it now. Whats wrong ? Did i make a mistake?
                                  Fehler beim Laden der Datei __loader.rb
                                  uninitialized constant TraductorFehler beim Laden der Datei EraserOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreehandOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreeScale_Common.rb
                                  uninitialized constant FreeScale::T6Fehler beim Laden der Datei FreeScale_Tool.rb
                                  uninitialized constant FreeScale::SU_MAJOR_VERSIONFehler beim Laden der Datei LibOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LineOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LoaderOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetAlgoOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PaletteOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PolylineOnSurface.rb
                                  uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei ShapeOnSurface.rb
                                  • W
                                    walpurgisnacht
                                    I cant get fredo6 colllection to show up in my tools menu. the plugin is installed and i have it enabled in preferences but dosnt appear otherwise
                                      melissa11
                                      hi,
                                      doesnt seem to appear under the toolbars menu. It is turned on under preferences> extensions but I dont no where it is 😕
                                      new to this!
                                      thanks
                                        melissa11
                                        Hi, Did you find out the answer to your question - I have the same problem and havent figured it out yet. 😕
                                          the first post doesnt make any references to libfredo...
                                          • H
                                            hassanykb
                                            😍 this is a life saver man!!!
                                            you rock Fredo!
