    Is there A plugin like this(updata)
    19 Posts 12 Posters 2.1k Views 12 Watching
    • MarianM Offline
      Marian
      No we won't because there isn't, and that's final. 😄
      • charly2008C Offline
        charly2008
        I am looking for a plugin that does not exist. It can do everything and nothing.
        Charly
        • BoxB Offline
          I'm not certain but isn't it one of Heisenberg's plug-ins?
            d12dozr
            Charly and others, please see the attached ruby.
            http://goo.gl/f7ooYh
            • V Offline
              Vicspa
              @charly2008 said:
              Charly
              I heard this plugin is coming out with Sketchup8 😍
              • ely862meE Offline
                ely862me
                What a gem!! I can't believe it!!! This simplifies things a lot! Thank you!
                Elisei (sketchupper)
                Come and See EliseiDesign
                  charly2008
                  Here is the attached Ruby
                  new 2.rb
                    Curious this "new one 2" is also invisible at the end of the download 😮
                      A picture paints a thousand words... but then a few words of explanation also help!
                      You want a plugin that lets you draw a shape in 2D and then extrude it in 3D...
                      Incidentally the 'movie' you supplied looks like it already exists ???
                      The built-in tools do that relatively seamlessly anyway ?
                      Draw a Rectangle and PushPull it - only one more key-press, if you use shortcuts...
                      There are several example scripts for drawing 3D primitives that are 'parametric' - these could be easily adapted to picked points rather than dialog entries...
                        the.pjt
                        there is ! .... SKETCHY PHYSICS has a sketchy solid toolbar where you can find a Cube maker exactly like this video ... it drows a Rotated rectangle and then pushpul and then make group . ...
                        Sketchy Physics
                          Dema
                          I think you need draw 3D directly like:cube,corn,sphere with just only input their value dimention, 😒
