    Is there A plugin like this(updata)
    19 Posts 12 Posters 2.2k Views 12 Watching
    • ely862meE
      ely862me
      It definitely, is! 🤓
      Elisei (sketchupper)
      Come and See EliseiDesign
      • V
        Vicspa
        there isn't?????????? 😞
        • ely862meE
          ely862me
          @tig said:
          I disagree - there isn't - I challenge you to prove that there is... 😉
          See what u've done..now we ll have mass panic attack. 😐
          • MarianM
            Marian
            No we won't because there isn't, and that's final. 😄
            • charly2008C
              charly2008
              I am looking for a plugin that does not exist. It can do everything and nothing.
              Charly
              • BoxB
                I'm not certain but isn't it one of Heisenberg's plug-ins?
                  d12dozr
                  Charly and others, please see the attached ruby.
                  http://goo.gl/f7ooYh
                  • V
                    Vicspa
                    @charly2008 said:
                    Charly
                    I heard this plugin is coming out with Sketchup8 😍
                    • ely862meE
                      ely862me
                      What a gem!! I can't believe it!!! This simplifies things a lot! Thank you!
                      • charly2008C
                        charly2008
                        Here is the attached Ruby
                        new 2.rb
                          Curious this "new one 2" is also invisible at the end of the download 😮
                            A picture paints a thousand words... but then a few words of explanation also help!
                            You want a plugin that lets you draw a shape in 2D and then extrude it in 3D...
                            Incidentally the 'movie' you supplied looks like it already exists ???
                            The built-in tools do that relatively seamlessly anyway ?
                            Draw a Rectangle and PushPull it - only one more key-press, if you use shortcuts...
                            There are several example scripts for drawing 3D primitives that are 'parametric' - these could be easily adapted to picked points rather than dialog entries...
                            • T
                              the.pjt
                              there is ! .... SKETCHY PHYSICS has a sketchy solid toolbar where you can find a Cube maker exactly like this video ... it drows a Rotated rectangle and then pushpul and then make group . ...
                              Sketchy Physics
                                Dema
                                I think you need draw 3D directly like:cube,corn,sphere with just only input their value dimention, 😒
