    Is there A plugin like this(updata)
    19 Posts 12 Posters 2.2k Views 12 Watching
    • ely862meE
      ely862me
      @tig said:
      I disagree - there isn't - I challenge you to prove that there is... 😉
      there isn't?????????? 😞
      See what u've done..now we ll have mass panic attack. 😐
      Elisei (sketchupper)
      Come and See EliseiDesign
      • MarianM
        Marian
        No we won't because there isn't, and that's final. 😄
        • charly2008C
          charly2008
          I am looking for a plugin that does not exist. It can do everything and nothing.
          Charly
          • BoxB
            I'm not certain but isn't it one of Heisenberg's plug-ins?
              d12dozr
              Charly and others, please see the attached ruby.
              http://goo.gl/f7ooYh
              • V
                Vicspa
                @charly2008 said:
                Charly
                I heard this plugin is coming out with Sketchup8 😍
                • ely862meE
                  ely862me
                  What a gem!! I can't believe it!!! This simplifies things a lot! Thank you!
                  • charly2008C
                    charly2008
                    Here is the attached Ruby
                    new 2.rb
                      Curious this "new one 2" is also invisible at the end of the download 😮
                        A picture paints a thousand words... but then a few words of explanation also help!
                        You want a plugin that lets you draw a shape in 2D and then extrude it in 3D...
                        Incidentally the 'movie' you supplied looks like it already exists ???
                        The built-in tools do that relatively seamlessly anyway ?
                        Draw a Rectangle and PushPull it - only one more key-press, if you use shortcuts...
                        There are several example scripts for drawing 3D primitives that are 'parametric' - these could be easily adapted to picked points rather than dialog entries...
                        • T
                          the.pjt
                          there is ! .... SKETCHY PHYSICS has a sketchy solid toolbar where you can find a Cube maker exactly like this video ... it drows a Rotated rectangle and then pushpul and then make group . ...
                          Sketchy Physics
                            Dema
                            I think you need draw 3D directly like:cube,corn,sphere with just only input their value dimention, 😒
