    Is there A plugin like this(updata)
    19 Posts 12 Posters 2.2k Views 12 Watching
    • V
      Vicspa
      there isn't?????????? 😞
      • ely862meE
        ely862me
        @tig said:
        I disagree - there isn't - I challenge you to prove that there is... 😉
        See what u've done..now we ll have mass panic attack. 😐
        Elisei (sketchupper)
        Come and See EliseiDesign
        • MarianM
          Marian
          No we won't because there isn't, and that's final. 😄
          • charly2008C
            charly2008
            I am looking for a plugin that does not exist. It can do everything and nothing.
            Charly
            • BoxB
              I'm not certain but isn't it one of Heisenberg's plug-ins?
                d12dozr
                Charly and others, please see the attached ruby.
                http://goo.gl/f7ooYh
                • V
                  Vicspa
                  @charly2008 said:
                  Charly
                  I heard this plugin is coming out with Sketchup8 😍
                  • ely862meE
                    ely862me
                    What a gem!! I can't believe it!!! This simplifies things a lot! Thank you!
                    • charly2008C
                      charly2008
                      Here is the attached Ruby
                      new 2.rb
                        Curious this "new one 2" is also invisible at the end of the download 😮
                          A picture paints a thousand words... but then a few words of explanation also help!
                          You want a plugin that lets you draw a shape in 2D and then extrude it in 3D...
                          Incidentally the 'movie' you supplied looks like it already exists ???
                          The built-in tools do that relatively seamlessly anyway ?
                          Draw a Rectangle and PushPull it - only one more key-press, if you use shortcuts...
                          There are several example scripts for drawing 3D primitives that are 'parametric' - these could be easily adapted to picked points rather than dialog entries...
                          • T
                            the.pjt
                            there is ! .... SKETCHY PHYSICS has a sketchy solid toolbar where you can find a Cube maker exactly like this video ... it drows a Rotated rectangle and then pushpul and then make group . ...
                            Sketchy Physics
                              Dema
                              I think you need draw 3D directly like:cube,corn,sphere with just only input their value dimention, 😒
