    SketchUP 8
    345 Posts 101 Posters 69.2k Views 101 Watching
      I guess my main question about this is
      Does and update such as this usually include more options for the ruby writers?
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      We upgraded our API's Ruby interpreter from version 1.8.0 to 1.8.6, which is a better supported, more stable version. This gives API users the benefits of hundreds of Ruby bug fixes, but version 1.8.6 is also more strict on Ruby syntax. If a script is broken, you may need to contact the script's original author to get an upgraded version.
        More expanded changelog for SU8: http://sketchup.google.com/support/bin/answer.py?answer=115424
          drewpoeppel
          Looks like they removed the solar orientation setting in the geolocation area for manually setting the north angle in you model, along with dwg/dfx import, in the free version. ๐Ÿ‘Ž I wish they wouldn't take away features.
          • jeff hammondJ Offline
            Solid volume display in entity info is much welcomed.
            though it'd be nice to be able to change the units.. i draw in feet&inches but volume (for me at least) is always cubic yards..(concrete)
            /27 for now.
              Just installed the free version
              I see only Pro version! ๐Ÿ˜ฎ
              Have you a link?
                Khai
                Have you a link?
                  /27 for now.
                  Yea - we use mm - but area and volume in m.
                  Good thing is that total area for materials are now calculated correct for skewed groups/components.
                    Khai
                    YAY and bugsplatted it first run ๐Ÿ˜„
                    • EarthMoverE Offline
                      EarthMover
                      Wow, solid tools are super fast! Toolbar fix is also huge. So far so good! Ruby calculations seem faster as well.
                      Content Creator at Skapeup
                        From what I've heard, Ruby 1.8.6 is faster than 1.8.0 - though I've yet to run any number on this.
                          remus
                          Thom, i have recollections of jim running some tests after changing to 1.8.6 and finding it was indeed faster.
                          • FrederikF Offline
                            Frederik
                            You guys are so un-grateful... ๐Ÿ˜
                            I like "Susan"... ๐Ÿ˜‰
                            Cheers
                            Kim Frederik
                              EarthMover
                              I ran Make Fur on a sphere and it calculated over 200K polygons in 28 seconds clean. Ran the same test in SU 7.1 and the screen went white and I got the spinning circle for over two minutes.
                              • HieruH Offline
                                Hieru
                                @tridem said:
                                Just installed the free version, it seems I can run both the new one and the old 7.08, this is great to discover the new features "safely" ๐Ÿ˜
                                How do you do that, as it would be good to keep the old version for dwg imports?
                                Do you simply set it up in a different folder, or is this an automatic new feature?
                                www.davidhier.co.uk
                                  remus
                                  It should just install in its own folder without you having to do anything.
                                    Each major SU version will install into a separate folder.
                                    You can have SU6 and SU7 and S8 side by side.
                                    But you can not have SU7.0 and SU7.1 side by side.
                                    • IdahoJI Offline
                                      IdahoJ
                                      Just downloaded and installed SU8 free into it's own directory. No conflicts so far with my pre-existing SU7 install (didn't think there would be but you can never tell when something messes with the Windows registry file).
                                      Now to start moving and testing the 7.x plugins and scripts ... ๐Ÿ˜‰
                                      Cheers.
                                      "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
                                      • HieruH Offline
                                        Hieru
                                        Thanks Remus & thomthom ๐Ÿ‘ .
                                        www.davidhier.co.uk
                                          rickgraham
                                          Sorry - but just about every other major upgrade that I have used (vX to vX) had visual differences. Sadly, v8 FREE visually looks EXACTLY like v7. No new visual improvements. It may be faster, speed-wise but I would have preferred to have some visual differences. It looks like a Win 95 interface for 2010 and beyond. Heck, even some betas that I've been involved in look radically different form Beta to beta.
                                          As someone else pointed out, you don't take away features and it should have been v7.2. I think I'll stick with 7.1 for now.
                                          Sorry - just disappointed.
                                          Rick
                                          • H Offline
                                            HFM
                                            I think the tremendous update from 'Style Builder' to 'Style Builder 2' says is all and gives a pretty good impression what Google thinks of its customers.
                                            On a more optimistic note: Blender 2.5 has gone beta! [about half a month now] and it rocks!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 13 / 18
