    [Plugins]$ Create image(rotate)
    32 Posts 16 Posters 30.7k Views 16 Watching
    • jeff hammondJ Offline
      fwiw, i'm getting a consistent bug splat with OS X.
      all seems to go well until i click 'start' then splat.. everytime.
        sahi
        There are mistakes, I'll work on them.
        Use the button "Undo" and not "Pause"
          stonebreaker
          is it possible to "animate" something like a drawer comes out of a cabinet or a door opens?
            sahi
            You can open the box, (like open, click on the "Pause") then close the box, click on the "Start" as it will click on the "Pause"
            • H Offline
              hebeijianke
              Thank you for your work
              When the plugin running I used the orbit tool of the Skethup
              Then it stopped running
              Why?
                i'm not sure if that was a reply to me or not but undo and pause make no difference whatsoever..
                to rephrase my previous post-- this plugin does not work on macs
                  sahi
                  Why?
                  So it should be.
                  You can not work in SketchUp two instruments simultaneously
                  I do not have macs
                  So I could not set it up under the macs
                  I'll try to fix it ..
                    sahi
                    Updated plug-in in the first message. http://forums.sketchucation.com/viewtopic.php?f=323&t=30131
                    Fixed bugs
                      kevinski
                      sorry but i still dont understand how to use it.
                      I want to rotate my model on Blue Axis and i dont know what to do next.
                      I klick on start an then on stop and nothing happens. Same problem with "Save" i click on it and the window opens but after that there is no saved fiel
                        sahi
                        [flash=750,550:2fj0fcm8]http://www.youtube.com/v/pjgenKahoA0[/flash:2fj0fcm8]
                          blueman2
                          Is this plug in still supported in sketchup 8? I don't see any recent posts and I'm considering purchasing it.
                            In the above post Sahi says he updated the plugin. That was in November when SU 8 had been out for 2 months already.
                              blueman2
                              I just purchased it and it is very easy to use to create an animated rotation. Thank you. I can see where you can easily create an animated gif but I'm a little confused about creating an animated movie either by exporting as an avi (which I'm having problems with anyway) or exporting the rotation animation as part of a more involved animation which is being exported as still frames, to be converted after . This is the way I've been creating animations using "Proper Animation" Can someone clarify how to do this for me please. Thanks
                                blueman2
                                On a separate question: I noticed in the instruction video in the beginning of this post that when Create Image is first opened, points become visible on the rectangular blocks from which the animation path is drawn. What are these points and how do I place them on the group/component?
                                • 2 / 2
