    [Plugin] 2D Tools
    791 Posts 178 Posters 690.4k Views 177 Watching
      grim
      tig
      is it posible to get these 2d tools working in the layout portion of sketchup?
      they would be a great help when preparing documentation drawings
      regards
      grim
        @grim said:
        tig
        regards
        grim
        Sorry, but SUp's .rb isn't transferable to LO - there are lots of useful tools inside LO though ??
        • kenK Offline
          ken
          On the 2D Text tool would it be possible to limit the color selection to just 8 colors. Right now the end of the list is off screen's bottom and this makes it impossible to select yellow or any other color that is be at the bottom.
          Again thanks for the plugin.
          Ken
            Ken
            You CANselect off any list that goes off the screen...
            Select that list option...
            Type the first letter of the color you want - say W for 'White'
            The list jumps to 'Wheat' - because it's the first item starting with W...
            Now use the down-arrow key to scroll through the list until you have 'White' selected
            If you wanted 'Violet' use the up-arrow key to scroll up to that etc...
            In your example pressing 'Y' would jump to 'Yellow' directly as that is the first item it finds...
            The clunky 'inputbox' methods are not great but you can work through them...
            A web-dialog based interface with proper-scrolling is on the to-do-list... πŸ˜’
            • kenK Offline
              ken
              Thanks. That works for me. I was unaware of this feature.
              Again, thanks for your plugins.
              Onto another note, will you be at 3D Basecamp?
              Ken
                Ken
                Unfortunately, it's a no.
                Google arranged 3D Basecamp a verybad time...
                I have a sick relative coming to live with us around then... AND I have to get things ready [like finish the new ground-floor bedroom/bathroom etc]... AND also it's aloooong way... AND it's a lot of money for a few days' junket AND... it starts on my wife's birthday AND it ends on our wedding-anniversary πŸ˜•
                So all in all a resounding 'no' - though I would have loved to have gone πŸ˜’
                • utilerU Offline
                  utiler
                  Ken
                  Excuses, excuses, TIG.... πŸ˜‰
                  Just Curious...
                    gcp310
                    does this plugin only work for SU porfessional, or will it work with the free version.
                    i cant get it to load up.
                    Glenn
                      It works on SU Free. Have you extracted the zipped folder into your plugins directory? Making sure to keep the folder/file structure intact.
                        Glenn, it works with both pro and free versions of SU. Perhaps you could be a little more specific about what you've done and what's happening.
                          Also it's not to be found in the Plugins Menu... See Menu > Draw > 2D Tools > sub-menu items... AND you will need to activate the 2D Tools toolbar from Views > Toolbar > 2D Tools to see that too...
                          Please read the instructions in the Help file...
                            gcp310
                            i feel like such an idiot, yes, they have been there all along.
                            sorry, i had been so engrossed in trying to get them to appear in the plugins section.
                            thanks for the info
                            Glenn
                            • W Offline
                              wyatt
                              TIG,
                              The 2D tools don't seem to work in v8. I get the following error (3 pages actually - just copying one as they are all similar).
                              Error Loading File 2D#.rb
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DlineTool.rb:33: syntax error, unexpected ',', expecting kEND
                              Sketchup::set_status_text ("Length"), SB_VCB_LABEL
                              I don't have an urgent need for this plug-in right now but I thought you'd like to know that it may need to be updated.
                              Wyatt
                                Wyatt, I don't want to speak for TIG but I'm not having any problem with the 2D Tools on either my Mac or my PC. In fact I just used it a few minutes ago on my PC here at work. Could it be an install problem?
                                  His error indicate a syntax error.
                                  Sketchup::set_status_text ("Length"), SB_VCB_LABEL instead which Ruby 1.8.6 throws an error at now that it's stricter than previous version.
                                  Possible he has used different tools than you?
                                  @Wyatt: exactly when you do get these errors? What tools/operations are you doing?
                                    I don't know, Thomas. I've gone through all of the 2D tools just now and didn't get any errors.
                                    • W Offline
                                      wyatt
                                      Ok, figured it out. The 2D tools that don't work for me are these:
                                      http://forums.sketchucation.com/viewtopic.php?t=21445
                                      v4.6 works fine. Are the plugins on the other thread an earlier build?
                                        As Thomthom says v8 is more unforgiving of having only part of the arguments parenthesized - I will check my code and reissue to suit... B U T . . .
                                        However, there is no occurrence of the text Sketchup::set_status_text ("Length"), SB_VCB_LABEL ANYWHERE in the current 2DlineTool.rb - it's always the correctly syntaxed Sketchup::set_status_text((db"Length"),SB_VCB_LABEL) ??? πŸ˜•
                                        So I am a bit mystified - do you have the correct version downloaded from the main page zip file...
                                          o_O
                                          Peculiar. Though, I did find the syntax alien to be TIG's...
                                            @thomthom said:
                                            o_O
                                            It was 'wrong' in some older versions.... BUT not in the more recent ones - and they coincidentally suits v8 too............
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 39
                                            • 40
                                            • 14 / 40
