    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • mariochaM Offline
      mariocha
      Thanks TIG,
      So I tried it on the PC side of my MAC, and it worked just fine.
      frustrated me 😒
      Strange, cause other curves were ok.
      %(#008000)[Mario C.
      • fredo6F Offline
        @mariocha said:
        Testing the beta, the skin command cannot complete this file, attached.
        EEbyrails does it well tought.
        Mariocha,
        I think I know what it is and why it is specific to Mac. I'll publish a fix soon with a new release.
        By the way, you can adjust the density of meshing by using the Interpoland OverSamplingboxes. If you deactivate both, then you get a mesh strictly built on the original contour vertices.
        • mariochaM Offline
          mariocha
          A new relase ? Great !! πŸ‘ πŸ‘ πŸ‘
          And Oversampling & Interpol will be so usefull for designing !
          C'est vraiment super !
          as I'm working on a tensile structure these days.
          %(#008000)[Mario C.
          • cmeedC Offline
            cmeed
            help.
            I see skinning videos posted within this thread but i can't get this shape to work. it seems so simple.....
            I click contours, click space, i then repeat until all three lines are coloured and click the tick button or open space. i get a PLEASE WAIT then nothing happens.
            Am I doing something wrong, is it Because i'm on a mac?
            the last picture is tig's rails but i have to make a 4th rail for it to work.
              Should work with the 3 curves in either Fredo's or mine. With EEbyRails Pick the curve as the profile then the 2 side rails and then re-pick the profile again as the melding-profile - it will end with a point and triangular faces opposite the profile's end, as desired...Capture.PNG
              • cmeedC Offline
                cmeed
                Thank you for your speedy reply. Tig your plugin is working great (i didn't know about going back to my first curve to make three curves work, cheers)
                what i'm making is a field of 800 tents - the ones you can put up in 3 seconds. So i need a way of using the contours and keeping the the polys down.
                see pic tent - I used the loft by spline to get this but its not that great, Skinning didn't work.
                i wanted to used fredos to get the polys down.
                  Reduce the number of segments in the arcs for the profiles/rails for EEbyRails with Entity Info [before scaling or making a 'non-arc'] ?
                  • cmeedC Offline
                    cmeed
                    Thank you Tig. damn ! i knew that.... mmmm
                    • fredo6F Offline
                      @cmeed said:
                      help.
                      COuld you please post your model so that I can have a look and see what is going wrong.
                      fredo
                      • cmeedC Offline
                        cmeed
                        Here you go...Thanks for looking...
                        I am almost sure it will work for you. Its so simple a shape.
                        tent1.skp
                        • fredo6F Offline
                          This bug, specific to Mac, has been corrected, but I did not publish the fix yet (due to work on the Loft Along Path). I'll do soon.
                          It was already mentioned by Mariocha (see http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&start=210#p262564)
                          • fredo6F Offline
                            By the way, I forgot to mention that, when Skinning shapes, you can swap rails and profiles, which may be useful when the surface to generate is made from 3 contours.
                            • utilerU Offline
                              utiler
                              Fredo, this tool is quite incredible! I just haven't had time to play with it yet but have been following with much interest!! You really have 'user operation' high on your list.
                              Incredibly well done!!
                              Just Curious...
                              • fredo6F Offline
                                New Beta version of Curviloft 1.0c and LibFredo6 3.5c - 20 Aug 10
                                see Main Post for download
                                This is an interim version whose purpose is to fix some bugs signaled by users and to prepare a next release which will be more functional. Again, thanks to all users for their help and contribution.
                                1. Skinning: Bug on Mac preventing to Skin even simple shapes. Thanks to Mariocha and to Cmeed for signaling
                                2. Skinning: Pre-selection mode should work with more shapes. Thanks to Daniel S. for providing some good examples.
                                3. Loft Along Path: Still not finished. At least I have tried to improve the single-contour mode (kind of Follow Me, but accepting contours even non perpendicualr to the rail).
                                  By the way, I noticed some differences with the native SU FollowMe tool.
                                  Thank You Fredo, great update πŸ‘
                                  • EarthMoverE Offline
                                    EarthMover
                                    Awesome. Thanks Fredo!
                                    Content Creator at Skapeup
                                    • mariochaM Offline
                                      mariocha
                                      Soon as I heard the good news, I gave a quick try to the new 1.0c
                                      It worked just great on the file causing problems before (on Mac). πŸ‘
                                      I will give it a more thorough spin tomorow.
                                      and find the donation menu ...
                                      mille merci !!
                                      %(#008000)[Mario C.
                                        grim
                                        fredo and Danial s
                                        i have installed the latest uptate and tested it on the tangent at vertex skp and the tent1 skp
                                        in chosing on of the tangent at vertex outlines and the skinning command the programe runs and then flashes between thick line to thin line with the green tick floating after 2 hrs it said it was done in 2 second and showed no meshing i tryed this on all shapes in the file and no luck in getting a skin,
                                        what might the problem be here.
                                        in testing it in the tent1 skp i se no change in the result from the previous version and get a better result in using tigs rail plug in.
                                        not sure if it is just me or has anyone else had a similar result
                                        regards
                                        grim
                                          Daniel S
                                          This new beta is amazing!!!
                                          The skin works with all the shapes that I tried... only one not work... Seems that there is a problem when you put arcs with tangent ar vertex..
                                          I have no idea how to explain this.. so I take the definition from the sketchup help:
                                          "Tangent at Vertex: The Tangent at Vertex inference indicates an arc whose vertex is tangent to a previously drawn arc's vertex. The Tangent at Vertex inference is represented by a cyan arc"
                                          Also I include quick shapes that I made to recreate and show this.
                                          Thank you Fredo!!!
                                          Daniel S
                                          EDIT: I delete the attachment because it can cause confusion.
                                            Daniel S
                                            @grim said:
                                            i have installed the latest uptate and tested it on the tangent at vertex skp (...)
                                            Hi grim...
                                            The "tangent at vertex.skp" is a file that I upload to show that is not working for this kind of shapes...
                                            It can cause confusion so I remove it.
                                            In the latest version... Fredo fix some issues and now is working for more shapes...
                                            Try skin with this ones to see if it is working for you.
                                            Daniel S
                                            PS. I think it will be a good idea to add a test .skp file next to the download link of the plugin... so people download and can test the plugin inmediately.
                                            There are a lot of good examples on this posts, but perhaps not everyone wants to read all the pages.
                                            skin working.skp
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 65
                                            • 66
                                            • 15 / 66
