    Seamless texture techniques
    35 Posts 29 Posters 15.4k Views 29 Watching
      Don't forget that many of the 'PhotoShop' plugins [like Red-Field's] also work with free 'Gimp' if you have the Gimp 'pspi.exe' plug-in tool, and you put them into the correct folders etc...
      • Chris FullmerC
        Does Paintshop have an "offset" feature built into it? I just do the standard Photoshop trick of offsetting an image in the x and y directions, so that the seams then are showing in the middle of the image. Then I carefully go through and clean up the seam with clone stamp tool or whatever tool I need. Can you do it like that? I could explain it better if that makes no sense.
          dedmin
          http://www.mediachance.com/pseam/index.html
          http://www.mediachance.com/patternstudio/index.html
          • EdsonE
            Edson
            a short tutorial would be great, chris.
            http://www.mahfuz.arq.br
            • Chris FullmerC
              I like the brightness level correction ideas there Jan. I have not done that before, but I like how it sounds. I'll give it a shot next seamless texture I make.
              I'll try to do a quick video on this process.
              • L
                linea
                Have to say if you haven't tried Make Seamless in Gimp it is worth a look.
                  Aerilius
                  I often use the same technique with the brightness correction. I always thought it is a bit unprofessional and Photoshop owners would surely have a real tool for that, but it's great to see that others are doing it the same way.
                  I have already tried some texture programs or plugins and wasn't satisfied as they often created just a blurry cross-fading without considering fine details like grooves of a wall.
                  Here are two ways how I do it (PaintshopPro tutorial for Edson πŸ˜„)
                  and the "sleazy" way
                  • PixeroP
                    Pixero
                    There is no process that works for every image. Thats why plugins rarly does a good job. You have to adopt and try different paths.
                    Sometimes several passes of the above mentioned technique might be needed.
                    Another way is to use Image->Adjustments->Shadows/highlights with advanced settings.
                    The best way is to photograph with 50 to 100 mm with even diffuse lighting on a cloudy day and photographing several different shots of the same texture which then can be made into a large texture to further reduce tiling.
                    • PixeroP
                      Pixero
                      Argh! 😠
                      I wrote a whole tutorial and when pressing Submit something went wrong and it didnt get posted. Well well I'll try to rewrite it AGAIN...
                      Short Photoshop tutorial:
                      First make sure the image is somewhat evenly lit. Otherwise it will be impossible to make it tileable.
                      If it isnt, do this: Make a duplicate layer of the image and turn down saturation to grayscale and invert it.
                      Increase contrast with Levels if needed. Then gaussian blur the image quite much as we just want to correct over all lighting. Now set that layers blend mode to overlay and turn down opacity until the image looks more evenly lit.
                      What "overlay" does is that it darkens the bright parts and lightens the dark parts so we hopefully ends up with a more evenly lit image.
                      Now make duplicates of both layers and flatten then. This way you have the original layers there for any future editing.
                      With the two layers flattened go to Filters->Other->Offset and set horisontal and vertical offset to half the image width.
                      Make sure you have "wrap around" choosen.
                      Now clone away the edges and use several different clone sources so it's not obvious its a cloned image.
                      For images that need much editing it can be a good idea to have a copy of the un offset image underneath and use a layermask on the top layer to paint away the edges and show the image underneat.
                      A good practice is also to remove any too obvious part of the texture as these things makes tileing more visible.
                      Another good rule is to use textures that are quadratic with sizes such as 256x256, 512x512, 1024x1024 and so on since they use the least amount of memory compared to their size.
                      Hope this helps!
                      • N
                        notareal
                        I often use this method. For good result it requires that image has even illumination on edge areas.
                          dtrarch
                          Here is another freebee that works OK with a little post edit.
                          sTile
                          http://www.harmware.net/stile.htm
                          dtr
                            john.warburton
                            I use the Simple Filters Half-Wrap plug in. This lets you wrap the image left-right, top-bottom, or both directions by 50%. You can then use editing tools (Clone for example) to deal with the adjoining edges. Similar to the offset command in Photoshop, but only works at 50% offset.
                            Life's a reach, and then you gybe.
                            • B
                              blair
                              Pete
                              Which tool or method did you finally choose?
                              • EarthMoverE
                                EarthMover
                                I use Pixplant to make seamless textures from photos I take. I'll go as far as I can with the plugin and then usually do some further tweaking using the offset filter in photoshop until it is reasonably accurate. Then back to Pixplant for the 3D maps. Never tried the Redfield plugin, but it looks interesting. Thanks for the heads up.
                                Also great tutorial on color and light balancing. Thanks!!!! πŸ‘
                                Content Creator at Skapeup
                                • urgenU
                                  urgen
                                  ....brilliant old tutorial(If you remember πŸ˜‰ ) ...thank you to Jon again πŸ‘ ...
                                  http://forums.sketchucation.com/viewtopic.php?f=18&t=10694
                                  --pupil forever...------
                                  • Bob JamesB
                                    Bob James
                                    This works especially well with the new PhotoShop CS5 clone tool that assimilates the surrounding area and gives great
                                    This works especially well with the new PhotoShop CS5 clone tool that assimilates the surrounding area and gives great results.
                                    • unclebimU
                                      unclebim
                                      I use GIMP and the Low Frequency Even filter (http://registry.gimp.org/node/24636) when needed, followed by the Texturize filter (http://gimp-texturize.sourceforge.net/). Most of the time it gives good results although the texturizer tends to crash at more the 500x500px.
                                      • dereiD
                                        derei
                                        Ahh, this is why I never could use that plugin πŸ˜„ ... I tried again and it was a first ! πŸ˜„
                                        -but this means that my image must be less than 250x250 px 😞
                                        DESIGNER AND ARTIST DEREI.UK
                                          Argh! 😠
                                          It's always a cool habit in case of post of more 3 lines
                                          to copy past in the NoteBook before any Submit πŸ˜‰
                                          You don't know how many time this little trick can be save!
                                          It's very usefull too when you write an answer on a Net Mail πŸ˜’
                                          • EdsonE
                                            Edson
                                            thanks, aerilius.
