    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 126.1k Views 16 Watching
      Simon B
      Well, it works for me.
      More inspiration here
      • ArcA Offline
        Arc
        Play with tours and component stringer.
        • simon le bonS Offline
          simon le bon
          Can I believe it !!! another Simon B!? 😎 + 😎 = 😆
          Hi Arc ( you have found the link of "your" animated picture in this thread I guess 😉 ) You like to play with Component Stringer; me too. 👍 nice result.
          I have made my own try with animation on this spiral cone . Dear Taff I don't know why I don't reach the smoothness of yours ~~
          http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SC04_cropped.gif
          *simon
          • TaffGochT Offline
            TaffGoch
            @simon le bon said:
            "...Taff I don't know why I don't reach the smoothness of yours..."
            Simon,
            The first and last frame appear to be the same, which looks like a pause, or stutter, in the animation. I deleted the last frame, and it's somewhat better:
            Edited
            However, now there's a slight "jump" in the animation. 😕 I can only guess that there must have been a variation in the degree-of-rotation for one of the frames.
            -Taff
            "Information is not knowledge." -- Albert Einstein
              simon le bon
              Hi Taff,
              Thank you to watch and dissect 😉
              I thought the problem was coming from a visual bip due to the duplication of the loop..
              In fact I had made mistakes. It is very difficult for me to maintain 15 times the same process. My mind goes away;.
              To make it easy and unmistaken, this time, I had rotated copied the SpiralCone 2°x14 (the 15th is the same than the first)
              and had placed each copy in its own layer ( 01;02;etc..) and had make them visible one by one.
              http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SpiralCone5.gif
              This time it seems working good 😮
              ++simon
              • BoxB Offline
                Just to help possibly simplify the animations for you.
                Use scenes, create one scene at front one scene at back( or side to side, whichever works best for you) and export the animation as JPGs.
                You can specify how many Frames per second in the export and resolution then combine in the gif program of your choice.
                  simon le bon
                  very easy indeed dear Box
                  Here is my "BoxCube" 😉 made in a minute with 41 pics 320X240 = 283 Ko
                  http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/BoxCube.gif
                  ++simon
                  • BoxB Offline
                    Happy to help.
                    You can use this method for any number of scenes, so the cube can roll over or zoom in and out or even fly off the screen.
                    And reducing the number of colours in the gif will bring the file size down, I make a lot of animated avatars for people on another site and the file limit there 19.5 kb, so you learn to get everything out of each pixel.
                    • TaffGochT Offline
                      TaffGoch
                      I found, online, this drawing from an old book...
                      ...and wanted to produce the center "coil" in SketchUp. After trial-and-error with the torus "grid" spacing, I finally was able to model (and render) this:
                      -Taff
                      Model available in the Google 3D Warehouse:
                      http://sketchup.google.com/3dwarehouse/details?mid=c7113517b4de5d982137e32e8ebf2b1
                      http://sketchup.google.com/3dwarehouse/download?mid=c7113517b4de5d982137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1281117295000
                        simon le bon
                        Dear Taff,
                        Seems to be an interesting variation of our exercise.
                        I'm actually a bit too much out of the game to participate actively. You know, holidays, taking some rest, and big business with my garden etc..
                        first dissection 😉 :
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence032_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence033_th.jpg
                        friendly, simon
                        • TaffGochT Offline
                          TaffGoch
                          I didn't think there were enough colors & shadow details in the first render... 😆
                          -Taff
                            d12dozr
                            😲 TaffGoch,
                            that's psychedelic! Can you pleasetell how you made the color gradients? ...is that done in Kerkythea? The coloring especially is super neat 👍
                            http://goo.gl/f7ooYh
                            • TaffGochT Offline
                              TaffGoch
                              @d12dozr said:
                              ...Can you pleasetell how you made the color gradients? ...is that done in Kerkythea? The coloring especially is super neat 👍
                              Marcus,
                              I created, in Photoshop, three radial gradients...
                              ...for use as projected textures in SketchUp. I scaled and positioned the projected textures, while in SketchUp...
                              ...and, when exported to Kerkythea, the materials are retained as "Diffuse" reflectance bitmaps (with their proper rotated/projected positions):
                              In the "Material Editor", I added "Specular" and "Fresnel-ramp"(procedural) settings, to give the surfaces a mild metallic appearance.
                              -Taff
                                d12dozr
                                TaffGoch,
                                Thank you for the explanation, you're like a magician with Sketchup, except that you will share your 'tricks' 😆
                                • TaffGochT Offline
                                  TaffGoch
                                  Marcus (and any other interested parties,)
                                  I've attached the Kerkythea "scene" file, so you can examine the material settings for the metallized colors.
                                  I "jazzed" the color/specular settings a bit more:
                                  Metallized colors
                                  I used MLT, and let the render run overnight (about 350 passes.) The above is a 50% scaled jpeg. The original is 1100x1100 pixels.
                                  -Taff
                                  • TaffGochT Offline
                                    TaffGoch
                                    Before "metallizing;" rendered, straight from SketchUp (no material editing in KT):
                                    ![Before "metallizing"](/uploads/imported_attachments/QWjy_Color3.jpg "Before "metallizing"")
                                    -Taff
                                      d12dozr
                                      Thank you Taff.
                                        August
                                        Please forgive me reviving an old thread but this entire thread is definitely one of my all time SketchUcation favorites. The depth of tutorial information in this thread is just awesome.
                                        AND, there is new and hopefully relevant information to add. The GIF that by Cosycat that was posted by simon le bon on Sun Jul 25, 2010 has now officially gone viral.
                                        I have seen it as the Profile image on Facebook by someone who had never heard of SketchUp. It is also regularly used by "vsauce" as a background in many of his videos, as seen here starting at 0:25.
                                        Just FYI.
                                        August
                                        “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                                        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                          August
                                          Page 3 of this thread, near the bottom, has a post
                                          by simon le bon » Sun Jul 25, 2010,
                                          with an image that seems to be making its way into the pop culture.
                                          Today Lady Gaga's Facebook page featured this image:
                                          https://littlemonsters.com/post/52d986cec214e4e4488b4c27
                                          https://d2g892zuoe3k49.cloudfront.net/4fc06d51c64dfcba5500b268/584976895_700.jpg
                                            Very similar to this one by Viralata 😄
                                            (a specialist Blender / Architecture)
                                            http://www.viralata.fr/wp-content/gallery/displacement/2rondscouleur.jpg
                                            • 5 / 6
