    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 133.6k Views 16 Watching
    • simon le bonS
      simon le bon
      Hi Taff! impressive***
      Can you say a little about your technique and the softs you're using? Please!
      (and very nice links 😉 )
      • ely862meE
        ely862me
        Looks like sketchup physics and a screen recorder(camstudio maybe).
        Taff if u used Camstudio,please let me know ur settings ,i can t make it record that smoother.
        Elisei (sketchupper)
        Come and See EliseiDesign
          Roger
          Do not, I repeat "DO NOT" stare at these images for 15 minutes and then try to walk down the stairs!
          http://www.azcreative.com
          • TaffGochT
            TaffGoch
            😆 Not to mention just walking across the room, without losing your lunch! 😆
            -Taff
            "Information is not knowledge." -- Albert Einstein
            • TaffGochT
              TaffGoch
              Simon & Elisei,
              I tried using Camstudio, initially, but the results were poor. Camstudio is easy, but doesn't always provide quality results. It's great, for what it is intended, but there is a better option for a "looped" animation of limited frames -- GIF animation software. (This animation is composed of only 15 frames.)
              I created the frames from SketchUp 2D exports, rotating the torus 2° each interval, producing 30° total rotation. (This matches the model component rotation of one spiral "tube" to the next.)
              I kept the SketchUp viewpoint constant, and rotated the torus, to avoid any camera positioning problems. I could have established 15 camera locations, to produce 15 scenes, but the way I did it was quicker. (Creating 15 camera/scene postions, however, does have the advantage that they can be saved in the model file, for subsequent use.)
              I assembled the 15 frames into a GIF animation, using JASC "Animation Shop," which I bought (cheap) over ten years ago. It's my understanding that COREL bought-out JASC. The older "Animation Shop" (vs 3) can be downloaded from several online sites, or you can use one of the MANY other freeware GIF animators, available online.
              [NOTE: I used the same technique to create my avatar.]
              -Taff
                Simon B
                Well, it works for me.
                More inspiration here
                • ArcA
                  Arc
                  Play with tours and component stringer.
                  • simon le bonS
                    simon le bon
                    Can I believe it !!! another Simon B!? 😎 + 😎 = 😆
                    Hi Arc ( you have found the link of "your" animated picture in this thread I guess 😉 ) You like to play with Component Stringer; me too. 👍 nice result.
                    I have made my own try with animation on this spiral cone . Dear Taff I don't know why I don't reach the smoothness of yours ~~
                    http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SC04_cropped.gif
                    *simon
                    • TaffGochT
                      TaffGoch
                      @simon le bon said:
                      "...Taff I don't know why I don't reach the smoothness of yours..."
                      Simon,
                      The first and last frame appear to be the same, which looks like a pause, or stutter, in the animation. I deleted the last frame, and it's somewhat better:
                      Edited
                      However, now there's a slight "jump" in the animation. 😕 I can only guess that there must have been a variation in the degree-of-rotation for one of the frames.
                      -Taff
                      • simon le bonS
                        simon le bon
                        Hi Taff,
                        Thank you to watch and dissect 😉
                        I thought the problem was coming from a visual bip due to the duplication of the loop..
                        In fact I had made mistakes. It is very difficult for me to maintain 15 times the same process. My mind goes away;.
                        To make it easy and unmistaken, this time, I had rotated copied the SpiralCone 2°x14 (the 15th is the same than the first)
                        and had placed each copy in its own layer ( 01;02;etc..) and had make them visible one by one.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SpiralCone5.gif
                        This time it seems working good 😮
                        ++simon
                        • BoxB
                          Just to help possibly simplify the animations for you.
                          Use scenes, create one scene at front one scene at back( or side to side, whichever works best for you) and export the animation as JPGs.
                          You can specify how many Frames per second in the export and resolution then combine in the gif program of your choice.
                          • simon le bonS
                            simon le bon
                            very easy indeed dear Box
                            Here is my "BoxCube" 😉 made in a minute with 41 pics 320X240 = 283 Ko
                            http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/BoxCube.gif
                            ++simon
                            • BoxB
                              Happy to help.
                              You can use this method for any number of scenes, so the cube can roll over or zoom in and out or even fly off the screen.
                              And reducing the number of colours in the gif will bring the file size down, I make a lot of animated avatars for people on another site and the file limit there 19.5 kb, so you learn to get everything out of each pixel.
                              • TaffGochT
                                TaffGoch
                                I found, online, this drawing from an old book...
                                ...and wanted to produce the center "coil" in SketchUp. After trial-and-error with the torus "grid" spacing, I finally was able to model (and render) this:
                                -Taff
                                Model available in the Google 3D Warehouse:
                                http://sketchup.google.com/3dwarehouse/details?mid=c7113517b4de5d982137e32e8ebf2b1
                                http://sketchup.google.com/3dwarehouse/download?mid=c7113517b4de5d982137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1281117295000
                                • simon le bonS
                                  simon le bon
                                  Dear Taff,
                                  Seems to be an interesting variation of our exercise.
                                  I'm actually a bit too much out of the game to participate actively. You know, holidays, taking some rest, and big business with my garden etc..
                                  first dissection 😉 :
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence032_th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence033_th.jpg
                                  friendly, simon
                                  • TaffGochT
                                    TaffGoch
                                    I didn't think there were enough colors & shadow details in the first render... 😆
                                    -Taff
                                      d12dozr
                                      😲 TaffGoch,
                                      that's psychedelic! Can you pleasetell how you made the color gradients? ...is that done in Kerkythea? The coloring especially is super neat 👍
                                      http://goo.gl/f7ooYh
                                      • TaffGochT
                                        TaffGoch
                                        @d12dozr said:
                                        ...Can you pleasetell how you made the color gradients? ...is that done in Kerkythea? The coloring especially is super neat 👍
                                        Marcus,
                                        I created, in Photoshop, three radial gradients...
                                        ...for use as projected textures in SketchUp. I scaled and positioned the projected textures, while in SketchUp...
                                        ...and, when exported to Kerkythea, the materials are retained as "Diffuse" reflectance bitmaps (with their proper rotated/projected positions):
                                        In the "Material Editor", I added "Specular" and "Fresnel-ramp"(procedural) settings, to give the surfaces a mild metallic appearance.
                                        -Taff
                                          d12dozr
                                          TaffGoch,
                                          Thank you for the explanation, you're like a magician with Sketchup, except that you will share your 'tricks' 😆
                                          • TaffGochT
                                            TaffGoch
                                            Marcus (and any other interested parties,)
                                            I've attached the Kerkythea "scene" file, so you can examine the material settings for the metallized colors.
                                            I "jazzed" the color/specular settings a bit more:
                                            Metallized colors
                                            I used MLT, and let the render run overnight (about 350 passes.) The above is a 50% scaled jpeg. The original is 1100x1100 pixels.
                                            -Taff
                                            • 5 / 6
