    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 130.0k Views 16 Watching
    • TaffGochT Offline
      TaffGoch
      Cosycat's animated image is inspiring. I thought I'd give it a try, too:
      http://i579.photobucket.com/albums/ss233/taffgoch/Torus_Spiral.gif
      -Taff
      [ EDIT: I see that Cosycat's image is a creation of David Ope. ]
      http://www.adaptcreative.co.uk/...
      http://dvdp.tumblr.com/...
      "Information is not knowledge." -- Albert Einstein
      • simon le bonS Offline
        simon le bon
        Hi Taff! impressive***
        Can you say a little about your technique and the softs you're using? Please!
        (and very nice links 😉 )
        • ely862meE Offline
          ely862me
          Looks like sketchup physics and a screen recorder(camstudio maybe).
          Taff if u used Camstudio,please let me know ur settings ,i can t make it record that smoother.
          Elisei (sketchupper)
          Come and See EliseiDesign
            Roger
            Do not, I repeat "DO NOT" stare at these images for 15 minutes and then try to walk down the stairs!
            http://www.azcreative.com
            • TaffGochT Offline
              TaffGoch
              😆 Not to mention just walking across the room, without losing your lunch! 😆
              -Taff
              • TaffGochT Offline
                TaffGoch
                Simon & Elisei,
                I tried using Camstudio, initially, but the results were poor. Camstudio is easy, but doesn't always provide quality results. It's great, for what it is intended, but there is a better option for a "looped" animation of limited frames -- GIF animation software. (This animation is composed of only 15 frames.)
                I created the frames from SketchUp 2D exports, rotating the torus 2° each interval, producing 30° total rotation. (This matches the model component rotation of one spiral "tube" to the next.)
                I kept the SketchUp viewpoint constant, and rotated the torus, to avoid any camera positioning problems. I could have established 15 camera locations, to produce 15 scenes, but the way I did it was quicker. (Creating 15 camera/scene postions, however, does have the advantage that they can be saved in the model file, for subsequent use.)
                I assembled the 15 frames into a GIF animation, using JASC "Animation Shop," which I bought (cheap) over ten years ago. It's my understanding that COREL bought-out JASC. The older "Animation Shop" (vs 3) can be downloaded from several online sites, or you can use one of the MANY other freeware GIF animators, available online.
                [NOTE: I used the same technique to create my avatar.]
                -Taff
                  Simon B
                  Well, it works for me.
                  More inspiration here
                  • ArcA Offline
                    Arc
                    Play with tours and component stringer.
                      simon le bon
                      Can I believe it !!! another Simon B!? 😎 + 😎 = 😆
                      Hi Arc ( you have found the link of "your" animated picture in this thread I guess 😉 ) You like to play with Component Stringer; me too. 👍 nice result.
                      I have made my own try with animation on this spiral cone . Dear Taff I don't know why I don't reach the smoothness of yours ~~
                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SC04_cropped.gif
                      *simon
                      • TaffGochT Offline
                        TaffGoch
                        @simon le bon said:
                        "...Taff I don't know why I don't reach the smoothness of yours..."
                        Simon,
                        The first and last frame appear to be the same, which looks like a pause, or stutter, in the animation. I deleted the last frame, and it's somewhat better:
                        Edited
                        However, now there's a slight "jump" in the animation. 😕 I can only guess that there must have been a variation in the degree-of-rotation for one of the frames.
                        -Taff
                          simon le bon
                          Hi Taff,
                          Thank you to watch and dissect 😉
                          I thought the problem was coming from a visual bip due to the duplication of the loop..
                          In fact I had made mistakes. It is very difficult for me to maintain 15 times the same process. My mind goes away;.
                          To make it easy and unmistaken, this time, I had rotated copied the SpiralCone 2°x14 (the 15th is the same than the first)
                          and had placed each copy in its own layer ( 01;02;etc..) and had make them visible one by one.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SpiralCone5.gif
                          This time it seems working good 😮
                          ++simon
                          • BoxB Offline
                            Just to help possibly simplify the animations for you.
                            Use scenes, create one scene at front one scene at back( or side to side, whichever works best for you) and export the animation as JPGs.
                            You can specify how many Frames per second in the export and resolution then combine in the gif program of your choice.
                              simon le bon
                              very easy indeed dear Box
                              Here is my "BoxCube" 😉 made in a minute with 41 pics 320X240 = 283 Ko
                              http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/BoxCube.gif
                              ++simon
                              • BoxB Offline
                                Happy to help.
                                You can use this method for any number of scenes, so the cube can roll over or zoom in and out or even fly off the screen.
                                And reducing the number of colours in the gif will bring the file size down, I make a lot of animated avatars for people on another site and the file limit there 19.5 kb, so you learn to get everything out of each pixel.
                                • TaffGochT Offline
                                  TaffGoch
                                  I found, online, this drawing from an old book...
                                  ...and wanted to produce the center "coil" in SketchUp. After trial-and-error with the torus "grid" spacing, I finally was able to model (and render) this:
                                  -Taff
                                  Model available in the Google 3D Warehouse:
                                  http://sketchup.google.com/3dwarehouse/details?mid=c7113517b4de5d982137e32e8ebf2b1
                                  http://sketchup.google.com/3dwarehouse/download?mid=c7113517b4de5d982137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1281117295000
                                    simon le bon
                                    Dear Taff,
                                    Seems to be an interesting variation of our exercise.
                                    I'm actually a bit too much out of the game to participate actively. You know, holidays, taking some rest, and big business with my garden etc..
                                    first dissection 😉 :
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence032_th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence033_th.jpg
                                    friendly, simon
                                    • TaffGochT Offline
                                      TaffGoch
                                      I didn't think there were enough colors & shadow details in the first render... 😆
                                      -Taff
                                        d12dozr
                                        😲 TaffGoch,
                                        that's psychedelic! Can you pleasetell how you made the color gradients? ...is that done in Kerkythea? The coloring especially is super neat 👍
                                        http://goo.gl/f7ooYh
                                        • TaffGochT Offline
                                          TaffGoch
                                          @d12dozr said:
                                          ...Can you pleasetell how you made the color gradients? ...is that done in Kerkythea? The coloring especially is super neat 👍
                                          Marcus,
                                          I created, in Photoshop, three radial gradients...
                                          ...for use as projected textures in SketchUp. I scaled and positioned the projected textures, while in SketchUp...
                                          ...and, when exported to Kerkythea, the materials are retained as "Diffuse" reflectance bitmaps (with their proper rotated/projected positions):
                                          In the "Material Editor", I added "Specular" and "Fresnel-ramp"(procedural) settings, to give the surfaces a mild metallic appearance.
                                          -Taff
                                            d12dozr
                                            TaffGoch,
                                            Thank you for the explanation, you're like a magician with Sketchup, except that you will share your 'tricks' 😆
                                            • 5 / 6
