    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 135.3k Views 16 Watching
    • TaffGochT
      TaffGoch
      Simon,
      I tried the chipped-paint texture, but it was too "busy," and was a visual distraction.
      A simple texture looks good though, when rendered:
      -Taff
      "Information is not knowledge." -- Albert Einstein
      • simon le bonS
        simon le bon
        Dear Taff,
        Simple is the best; it is a "réussite" . I see it in 2D, spirit relaxing.
        (But is it so simple? I mean about the discrete raw of light)
        'Cause you seem also from late in the night, I wish U a good one.
        😉 simon
        • simon le bonS
          simon le bon
          @simon le bon said:
          As I can understand the law of this:
          1. the shape must make a number of entire 360° turns
          2. the complet set of edges(included into the basic section) must be used a complete number of times.
          3. the number of edges used in the number of complete turns must meet the number of edges constituting the basic section used to produce the spiral.
          and
          4)the number of entire 360° turns of the shape must be the minimum one (sorry for bad explanation. I think it is the meaning of :"Least common multiple" )
          (It doesn't make sens for the basic shape to go around more than the necessary number!)
          to be verified!!!!
          I take back Taff's model to make a try to validate my thoughts
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_017_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_018_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_019_th.jpg
          Not bad what do you think! 😎 slb
          • TaffGochT
            TaffGoch
            Simon,
            I didn't pursue the precise defining of the calculations, but I sensed the general concept of the relationships.
            When I started on my second model, I roughly estimated a "longitude-to-latitude" ratio that should (might) produce a more-complex, tighter spiral with less slope, and six loops.
            As an intellectual pursuit, yours is a good mental exercise. (Perhaps, if it were mid-winter, and I was snowed-in, then I would have time to wrestle with a precise definition.) 😆
            -Taff
            • simon le bonS
              simon le bon
              End of the exercise I suppose 😉
              simon!
              • simon le bonS
                simon le bon
                by Cosycat
                http://www.webdesignmash.com/trial/wp-content/uploads/2010/02/davidope10.gif
                👍 😉 sim
                • TaffGochT
                  TaffGoch
                  Cosycat's animated image is inspiring. I thought I'd give it a try, too:
                  http://i579.photobucket.com/albums/ss233/taffgoch/Torus_Spiral.gif
                  -Taff
                  [ EDIT: I see that Cosycat's image is a creation of David Ope. ]
                  http://www.adaptcreative.co.uk/...
                  http://dvdp.tumblr.com/...
                  • simon le bonS
                    simon le bon
                    Hi Taff! impressive***
                    Can you say a little about your technique and the softs you're using? Please!
                    (and very nice links 😉 )
                    • ely862meE
                      ely862me
                      Looks like sketchup physics and a screen recorder(camstudio maybe).
                      Taff if u used Camstudio,please let me know ur settings ,i can t make it record that smoother.
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                        Roger
                        Do not, I repeat "DO NOT" stare at these images for 15 minutes and then try to walk down the stairs!
                        http://www.azcreative.com
                        • TaffGochT
                          TaffGoch
                          😆 Not to mention just walking across the room, without losing your lunch! 😆
                          -Taff
                          • TaffGochT
                            TaffGoch
                            Simon & Elisei,
                            I tried using Camstudio, initially, but the results were poor. Camstudio is easy, but doesn't always provide quality results. It's great, for what it is intended, but there is a better option for a "looped" animation of limited frames -- GIF animation software. (This animation is composed of only 15 frames.)
                            I created the frames from SketchUp 2D exports, rotating the torus 2° each interval, producing 30° total rotation. (This matches the model component rotation of one spiral "tube" to the next.)
                            I kept the SketchUp viewpoint constant, and rotated the torus, to avoid any camera positioning problems. I could have established 15 camera locations, to produce 15 scenes, but the way I did it was quicker. (Creating 15 camera/scene postions, however, does have the advantage that they can be saved in the model file, for subsequent use.)
                            I assembled the 15 frames into a GIF animation, using JASC "Animation Shop," which I bought (cheap) over ten years ago. It's my understanding that COREL bought-out JASC. The older "Animation Shop" (vs 3) can be downloaded from several online sites, or you can use one of the MANY other freeware GIF animators, available online.
                            [NOTE: I used the same technique to create my avatar.]
                            -Taff
                              Simon B
                              Well, it works for me.
                              More inspiration here
                              • ArcA
                                Arc
                                Play with tours and component stringer.
                                • simon le bonS
                                  simon le bon
                                  Can I believe it !!! another Simon B!? 😎 + 😎 = 😆
                                  Hi Arc ( you have found the link of "your" animated picture in this thread I guess 😉 ) You like to play with Component Stringer; me too. 👍 nice result.
                                  I have made my own try with animation on this spiral cone . Dear Taff I don't know why I don't reach the smoothness of yours ~~
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SC04_cropped.gif
                                  *simon
                                  • TaffGochT
                                    TaffGoch
                                    @simon le bon said:
                                    "...Taff I don't know why I don't reach the smoothness of yours..."
                                    Simon,
                                    The first and last frame appear to be the same, which looks like a pause, or stutter, in the animation. I deleted the last frame, and it's somewhat better:
                                    Edited
                                    However, now there's a slight "jump" in the animation. 😕 I can only guess that there must have been a variation in the degree-of-rotation for one of the frames.
                                    -Taff
                                    • simon le bonS
                                      simon le bon
                                      Hi Taff,
                                      Thank you to watch and dissect 😉
                                      I thought the problem was coming from a visual bip due to the duplication of the loop..
                                      In fact I had made mistakes. It is very difficult for me to maintain 15 times the same process. My mind goes away;.
                                      To make it easy and unmistaken, this time, I had rotated copied the SpiralCone 2°x14 (the 15th is the same than the first)
                                      and had placed each copy in its own layer ( 01;02;etc..) and had make them visible one by one.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/SpiralCone5.gif
                                      This time it seems working good 😮
                                      ++simon
                                      • BoxB
                                        Just to help possibly simplify the animations for you.
                                        Use scenes, create one scene at front one scene at back( or side to side, whichever works best for you) and export the animation as JPGs.
                                        You can specify how many Frames per second in the export and resolution then combine in the gif program of your choice.
                                        • simon le bonS
                                          simon le bon
                                          very easy indeed dear Box
                                          Here is my "BoxCube" 😉 made in a minute with 41 pics 320X240 = 283 Ko
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/BoxCube.gif
                                          ++simon
                                          • BoxB
                                            Happy to help.
                                            You can use this method for any number of scenes, so the cube can roll over or zoom in and out or even fly off the screen.
                                            And reducing the number of colours in the gif will bring the file size down, I make a lot of animated avatars for people on another site and the file limit there 19.5 kb, so you learn to get everything out of each pixel.
                                            • 5 / 6
