    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 130.0k Views 16 Watching
    • simon le bonS Offline
      simon le bon
      @Pilou
      I had not search to have a perfect round form
      but this is the exercise! ๐Ÿ˜•
      But as said previous you can deform it for approch the Sphere as your just previous post
      ๐Ÿ‘ ๐Ÿ˜‰
      @Myself
      60x60=3600 ! I must be wrong somewhere ๐Ÿ˜ณ
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_012_th.jpg
      (picture coming from a study of TaffGoch model)
      I don't understand everything but i get an element of answer:
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_013_th.jpg
      *s
        simon le bon
        Dear Pilou,
        thanks for this Jean Pierre Petit's link. ๐Ÿ˜„
        (When I was young, I was a wild and rebel, and bad student. I don't know why I want to understand everything like I do by now) โ“ ๐Ÿ˜’
        First a trick concerning a problem I have met: When I wanted to reconstruct the complex set of spirals by copy/rotate the basic section, that produced here and there some micro-cuts in the continuity of the lines.
        I have used StrayLines to locate and label them ๐Ÿ‘
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_014_th.jpg
        Repair,
        http://i274.photobucket.com/albums/jj245/Spendauballet/videos/StrayLIneRepair.gif
        >I want to understand better how the spiral works:
        1)taking back my model
        24 sided circle; 32 segmented face shape; each segment is 24 subdivided.
        Each 360ยฐ turn of the shape describes completely one of the 32 face's segments.
        24 single edges are necessary to achieve this single revolution.
        Consequently, the entire spiral is made by 32 turns and no edge is used two times.
        and we find effectively 32X24=768 edges
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_015_th.jpg
        1)taking back Taff's model
        Each 360ยฐ turn of the shape uses 60 edges (because of the 60 sided based circle).
        The entire spiral needs 3 complete turns of the shape to be totally described.
        3X60= 180 edges of the spiral.
        Each edge of the basic section (90 edges) is used two times.
        2X90= 180 edges of the spiral.
        As I can understand the law of this:
        1. the shape must make a number of entire 360ยฐ turns
        2. the complet set of edges(included into the basic section) must be used a complete number of times.
        3. the number of edges used in the number of complete turns must meet the number of edges constituting the basic section used to produce the spiral.
        here: 60X3=180=90x2
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_016_th.jpg
        to be verified!
        ๐Ÿค“ simon
          I believe that is the same problem for what Tig had made his True Tangents plug
          Circles or helix ar not real circle, just polysegments aproximation , so in the 3D space there are some losses of precision after some turns ๐Ÿ˜‰
          I have remarked that with my previous try above, I had must corrected by hand the join continuity! ๐Ÿ˜’ ๐Ÿ˜‰
          • ely862meE Offline
            ely862me
            Hmm so much theory ..what i did was simple,make a spring,make a copy of it,take a spring and adjust it with ffd(remember to let the top and bottom points untouched) in order to make from it the inside part of the spiral, after this take the other one and flip it along in order to continue(descend on the outside) the first one,then play with ffd on it in order to make the exterior part of the spiral(remember to let the top and the bottom points untouched).Then i used lines to tube plugin. And that s kind of it!
            Ah..and before working them with ffd i flattened(with ffd) the top and bottom spires of the springs to make a smooth transition from a spire to another.
            infinite spiral a.skp
            Elisei (sketchupper)
            Come and See EliseiDesign
            • TaffGochT Offline
              TaffGoch
              Colors help identify the six separate (yet identical) loop components:
              -Taff
              "Information is not knowledge." -- Albert Einstein
                simon le bon
                @Ely,
                Hi Ely, I like your way: searching for simple and quick processes ๐Ÿ˜Ž your solutions are refreshing ๐Ÿ‘
                SketchyFFD (Free Form Deformation) is a good deal for sure ๐Ÿ‘ ๐Ÿ‘
                [Plugin] SketchyFFD (Updated Aug 22, 2009) by CPhillips
                SketchyFFD (Updated 9 Feb 2010) revisited by gbabcock
                Making springs:
                How to make spiral 02 by SketchUp
                SketchUp: KitoRaupp_Pottery
                (May be you can do a little more effort to explain in few several steps in your Skp rather than just show the result ๐Ÿ˜„ )
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ElySoluce.jpg
                ๐Ÿ‘
                @Taff
                Hi Taff (I have noticed you are from the early morning, and I'm waiting my own awakening to read your posts ๐Ÿ˜‰ ) Thank you for your colored exemples. I guess the same treatment as you've done with your Geodesic Weave Ball should be also very great ๐Ÿ˜‰
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Weave_chipped.jpg
                Additionally, I would invite people to visit carefully your warehouse collections they are mines ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                • and don't forget the "Help Group Discussion" ๐Ÿ˜‰
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_TaffGochWareh.jpg
                โ˜€ simon
                re: what a great thread!!
                • TaffGochT Offline
                  TaffGoch
                  More torus segments produce results that better approximate the original images.
                  (Well, duh!) ๐Ÿ˜†
                  Model available at 3D Warehouse
                  -Taff
                  • TaffGochT Offline
                    TaffGoch
                    Simon,
                    I tried the chipped-paint texture, but it was too "busy," and was a visual distraction.
                    A simple texture looks good though, when rendered:
                    -Taff
                      simon le bon
                      Dear Taff,
                      Simple is the best; it is a "rรฉussite" . I see it in 2D, spirit relaxing.
                      (But is it so simple? I mean about the discrete raw of light)
                      'Cause you seem also from late in the night, I wish U a good one.
                      ๐Ÿ˜‰ simon
                        simon le bon
                        and
                        4)the number of entire 360ยฐ turns of the shape must be the minimum one (sorry for bad explanation. I think it is the meaning of :"Least common multiple" )
                        (It doesn't make sens for the basic shape to go around more than the necessary number!)
                        to be verified!!!!
                        I take back Taff's model to make a try to validate my thoughts
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_017_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_018_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_019_th.jpg
                        Not bad what do you think! ๐Ÿ˜Ž slb
                        • TaffGochT Offline
                          TaffGoch
                          Simon,
                          I didn't pursue the precise defining of the calculations, but I sensed the general concept of the relationships.
                          When I started on my second model, I roughly estimated a "longitude-to-latitude" ratio that should (might) produce a more-complex, tighter spiral with less slope, and six loops.
                          As an intellectual pursuit, yours is a good mental exercise. (Perhaps, if it were mid-winter, and I was snowed-in, then I would have time to wrestle with a precise definition.) ๐Ÿ˜†
                          -Taff
                            simon le bon
                            ๐Ÿ˜†
                            End of the exercise I suppose ๐Ÿ˜‰
                            simon!
                              simon le bon
                              by Cosycat
                              http://www.webdesignmash.com/trial/wp-content/uploads/2010/02/davidope10.gif
                              ๐Ÿ‘ ๐Ÿ˜‰ sim
                              • TaffGochT Offline
                                TaffGoch
                                Cosycat's animated image is inspiring. I thought I'd give it a try, too:
                                http://i579.photobucket.com/albums/ss233/taffgoch/Torus_Spiral.gif
                                -Taff
                                [ EDIT: I see that Cosycat's image is a creation of David Ope. ]
                                http://www.adaptcreative.co.uk/...
                                http://dvdp.tumblr.com/...
                                  simon le bon
                                  Hi Taff! impressive***
                                  Can you say a little about your technique and the softs you're using? Please!
                                  (and very nice links ๐Ÿ˜‰ )
                                  • ely862meE Offline
                                    ely862me
                                    Looks like sketchup physics and a screen recorder(camstudio maybe).
                                    Taff if u used Camstudio,please let me know ur settings ,i can t make it record that smoother.
                                      Roger
                                      Do not, I repeat "DO NOT" stare at these images for 15 minutes and then try to walk down the stairs!
                                      http://www.azcreative.com
                                      • TaffGochT Offline
                                        TaffGoch
                                        ๐Ÿ˜† Not to mention just walking across the room, without losing your lunch! ๐Ÿ˜†
                                        -Taff
                                        • TaffGochT Offline
                                          TaffGoch
                                          Simon & Elisei,
                                          I tried using Camstudio, initially, but the results were poor. Camstudio is easy, but doesn't always provide quality results. It's great, for what it is intended, but there is a better option for a "looped" animation of limited frames -- GIF animation software. (This animation is composed of only 15 frames.)
                                          I created the frames from SketchUp 2D exports, rotating the torus 2ยฐ each interval, producing 30ยฐ total rotation. (This matches the model component rotation of one spiral "tube" to the next.)
                                          I kept the SketchUp viewpoint constant, and rotated the torus, to avoid any camera positioning problems. I could have established 15 camera locations, to produce 15 scenes, but the way I did it was quicker. (Creating 15 camera/scene postions, however, does have the advantage that they can be saved in the model file, for subsequent use.)
                                          I assembled the 15 frames into a GIF animation, using JASC "Animation Shop," which I bought (cheap) over ten years ago. It's my understanding that COREL bought-out JASC. The older "Animation Shop" (vs 3) can be downloaded from several online sites, or you can use one of the MANY other freeware GIF animators, available online.
                                          [NOTE: I used the same technique to create my avatar.]
                                          -Taff
                                            Simon B
                                            Well, it works for me.
                                            More inspiration here
                                            ๐Ÿ˜‰
                                            • 5 / 6
