    The problem with Sketchup...still
    18 Posts 12 Posters 2.9k Views 12 Watching
      Roger
      Has anyone tried using topo maps and raising the terrain from those in sketchUp then running the subsmooth plugin on the result? I have not but I am tempted to try it as an exercise.
      Or, how about Fredo's newly released "loft by spline." Just set up each contour as a separate spline.
      http://www.azcreative.com
      • aadbuildA
        aadbuild
        If you have survey of the job"loft by spline." will save those painful hours.
        Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
        https://www.plusspec.com
          Roger
          Terrain with Subsmooth
          About two hours using subsmooth and a topo map. Wasn't sure what I was doing, but thought I would give it a test and then I got carried away.
          • brookefoxB
            brookefox
            I've found this to be a bit of an eye-opener for helpful methods, especially for setting easily drawn vertical and horizontal controls to act as contours from which to quickly generate terrain.
            http://www.youtube.com/watch?v=NHCEXlEZlo4&feature=player_embedded#!
            Though it looks like you've gotten good responses, adding the something about terrain modeling to the thread title might bring more.
            ~ Brooke
            • O
              otb designworks
              To generate terrains, I use the following workflow.
              Trace over the topo map in a vector software (Illustrator for me). Use a control point edit function to downsize the number of vertices to a reasonable number. Export out as a DXF.
              Import the DXF into Sketchup and move each topo loop to its correct height. Draw over one of the lines of each loop to close the face and ensure a connected loop. Delete each face. Group the whole thing, make a copy and save as a backup.
              With the original, explode the group, select all, and run the sandbox tool to generate mesh from contours.
              Import a satellite image, or one image cut into 2048x2048 pieces and project it onto the mesh and that should do it.
              Cheers, Chuck
              Cheers, Chuck
              OTB Designworks is on Youtube
                Roger
                Actually a topo map would be a fine starting point. Just draw regularly spaced parallel line over the topo. Make tickmarks where each of your lines crosses a contour and note the distance between tick marks. Then draw a vertical from each tickmark to the height of the contour being crossed. Connect the tops of these lines and you will have a spline. Once your have a full set of splines for your terrain, run the result through Fredo's "Loft by Spline."
                • honoluludesktopH
                  honoluludesktop
                  Not accurate, or elegant, but just in time for a quick presentation. How about Chris's simple loft tool. Import the topo as line segments at the correct height. Select with his tool, and loft (example with 4 topographic lines split into 2 segments each pair). Too simple?
                  • Chris FullmerC
                    I think you should look at the loft tool they suggested above Honolulu. Mine was the first, but it is VERY weak compared to Fredo's. His does anything mine does, but does it faster, more accurately, and is much more robust. Its really a better solution now.
                    • C
                      cadmunkey
                      How accurate are the levels on Google earth imagery? Is there anywhere that documents this?
                      • bmikeB
                        bmike
                        not as accurate as a site survey... i think it is based on topo data, which can vary depending on source, date, etc.
                        • broomstickB
                          broomstick
                          You are touching an open nerve, for me. I do not have time now, but later I'll try to post a case study of mine!
                          • K
                            kilgo
                            Heres some images from the project.
                            Front View
                            Rear Slope
