    [Request] - Component's options report
    27 Posts 8 Posters 5.4k Views 8 Watching
      dedmin
      SketchUP's Generate Report freezes the program just at 1 components
      But this script is working fine so far!!
        dedmin
        Now, that at least we can extract some data is there a way to filtered it. For instance to get components quantity and
          dedmin
          Up.
            dedmin
            I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report? 😒
              dedmin
              Still hoping... 👊
                Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
                You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...
                ss=model.selection
                ents=ss.to_a
                ### OR ents=model.entities
                ### OR ents=model.active_entities
                defns=[] ### to become a list of used definitions
                ents.each{|e|
                  if e.class==Sketchup;;ComponentInstance
                    defns<< e.definition if not defns.include?(e.definition)
                  end#if
                counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string]
                defns.each[|d|
                  counts<< [d.name, d.instances.length.to_s]
                • note it's untested!
                  You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
                  So to output it to the Ruby Console use something like...
                counts.each{|e|
                  puts e[0]+"\t"+e[1]
                I'll leave the formating of the csv / html lines etc to you or others............. 🤓
                  dedmin
                  Thanks so much! I made a component in English to show what I mean:
                  The report is a real mess and in inches, but I managed to clean it up in Excel.
                    So you are almost sorted 😄
                      Cjoenck
                      I did need a plugin to creat a simple list of components with: LenX, LenZ, LenY, Material, and Name
                      Not the boundinbox, because sometime in the draw the component could stay in angle different that axes.
                      Please need help, Could give a good Cookie to your jar.
                      Will use this to report list of furniture components to outside software that will calculate price.
                      Need SAP!
                      Best Regards
                      😕 Celio
                        Garry K
                        I'm thinking of creating a report writer that allows you to pick, choose and specify the order of columns in a csv report. The report definition can then be given a name that you can choose from a pick list when running subsequent reports.
                        Any one interested?
                          katalikammello
                          I'm really interested in this!
                          I would like to help as well but I'm a complete beginner 😞
                            Garry K
                            If there is enough interest then I would jump into it -- otherwise this is on a back burner.
                            • JQLJ Offline
                              JQL
                              Any one interested?
                              Would it also allow us to convert the columns names?
                              I mean, my contractors aren't much interested in LenZ, but they could very well relate to height.
                              Could we also Combine values?
                              LenX | LenY | LenZ columns, could be merged into a single Dimensions Column and each LenX, LenY and LenZ value would then turn into something like 1.5m X 2.0m X 0.005m?
                              EDIT: Oh and if unit conversion would be there too...
                              www.casca.pt
                              Visit us on facebook!
                                Garry K
                                Column names would be handled by my translation layer.
                                You could convert English translation (which is normally just a template) to what ever you want.
                                Normally with my plugins I try to honor the units that the user has set up for the model.
                                Yes - Sketchup stores data a certain way. BUT I Am a big fan of metric - so I honor it and convert into mm.
                                • JQLJ Offline
                                  JQL
                                  I'm sure you'd pull off something very good...
                                  www.casca.pt
                                  • 2 / 2
