    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • W Offline
      wyatt
      I figured out what was happening regarding the errors I was getting last week. The problem was organizer.rb. For the LibFredo6 plugins to work, both LIBFREDO6_Dir_34 and FREDOSCALE_Dir_20 must be added to the SmustardOrganizerExcludeFolders.txt file. As far as I can tell that does not effect the functionality of Fredo's scripts. Not sure if anyone else uses Organizer, but now you know.
      Wyatt
        bobbybobbob
        @exodiaangel said:
        do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused πŸ˜• ❓
        HELP PLEASE!!
        its not you, its this site... if there was just a "DOWNLOADS" section....
        I'm trying as well. still haven't found it....i registered, but now the spot that previously said that files are only for members is nowhere to be found.
        also confusing which topic is the "top" topic. fear not, just keep searching this site, and hopefully i'll find it before i loose interest in rounding my corners...funny thing is, i had this plugin last year, but lost it some how...so i guess i went through all this before! sheesh.
        but at least i'm begininning to see that Fredo6 is "the one".
          Hi guys,
          The plugins are regularly posted in (attached to) the first post in their respective topic when the author first "published" his plugin. I cannot really say it more clear. To search for a certain plugin, best is to start here:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
          (This is a "sticky" post at the top of this subforum).
            agamemnus
            Hi Fredo,
            Thanks a lot for fixing the greying-out issue!
              Mia
              NEW VERSION 3.1c
              Needed for for FreeScale 2.0c
              see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
              Hi!
              I've just doanloaded the 3.4 and extracted the zip to the Plugins folder as advised, but the settings do not show up in the Window menu. Should this extracting to folder be the "installation" or do I miss something?
              • fredo6F Offline
                @mia said:
                Hi!
                Can you check if you have the correct footprint, with just 2 elements in the Sketchup Plugins directory:
                • LibFredo6.rb
                • LIBFREDO6_Dir_34 folder
                PS: you also need to install at least one of my plugins (FredoScale, RoundCorner, ...) to see something in the menus (LibFredo6 does not load otherwise)
                  maruthi
                  i am not able download ...please help me out... 😞
                    What happens when you want to download? Can you see the link at all?
                    • N Offline
                      nirve08
                      ei guys, im still a new at using sketch-up, i search out for plugins, and i find this one interesting, i downloaded it, followed the instructions, but it didnt work, i have installed also the freescale 2.0..how do you install this one? i need a detail instruction like what folder or which folder to paste or install...many thanks
                        http://forums.sketchucation.com/viewtopic.php?p=144180#p144180 is the download page for the tool it has quite clear instructions ?
                        What is the exact problem ? πŸ˜•
                          jboyza
                          Glad to hear its working
                            baldaman
                            I upgraded my OS to WINDOWS 7 ultimate 64 and now I have constant crash each time I try to use FREDOSCALE.
                            Am I the only one on earth?
                            Best regards to all Sketchup users.
                              Dali_
                              Eventually got roundCorner to work... You have to register first, to be able to download LibFredo6 3.4c...
                              But, now it works, it's good – c'est bon – bravo!
                              Merci
                                tonywilton
                                This has got to be the most frustrating site I have been on in a long time,
                                I see all you guys talking about plugins but can never find where to download the damn things. There should be an obvoius download link through the discussion. I just wasted an hour looking, Bloody useless and certainly not up to the usual google clarity and intuitive standard.
                                  At the end of the first post there is a ZIP file. Download that (or click on the image below).
                                  Every site (forum) needs to get used to. This is such a forum, too. And this is not a Google site - that is here. The only difference (in functions) I guess is that you cannot attach anything there.
                                  And bloody welcome to SCF by the way.
                                  πŸ˜‰
                                    πŸ˜†
                                      πŸ˜’
                                      • soloS Offline
                                        WTF? πŸ˜•
                                        I'm sorry the FREE plugins are not on a golden platter, and may take some initiative (like going to first post) to download them.
                                        Hope you found them, and you are enjoying them, and please do not forget to thank the author for his/her hard work in creating them.
                                          tonywilton
                                          [attachment=0:1owgzszm]<!-- ia0 -->Download.png<!-- ia0 -->[/attachment:1owgzszm]
                                          πŸ˜‰
                                          Thanks for the link, I downloaded and installed it OK to get RoundCorner working, what a brilliant plugin that is! I still reckon a specific download area on Sketchucation would be a very welcome addition.
                                          Don't tell me there is one already and I have missed it πŸ˜„
                                          Admire the calm response to my rant bye the way, thanks again
                                            There has been various talks about repositories. But no concrete results yet. Still high up there on our wish list.
                                            And we have been talking about the visibility of the download links in the threads. Some authors have begun to add a Download button graphic by the link. I still have that on my to-do list. πŸ˜‰
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 108
                                            • 109
                                            • 18 / 109
