    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      rogueparker
      Im getting the same error message as above, but on a vista pc, I've tried the install 3 times. any ideas?
        Are the files installed as described in the first post?
        • P
          prismcnd
          Well I would really like to thank you Tom and Tig, after a couple of days i found the culprit, apparently i had a couple of older versions of the LibFredo6 filefolder in my plugins directory and after removing them everything is back to normal. Stupid mistake and thank you for your help.
          β€œWhatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
          • T
            thmnka84
            Could someone please give me more detailed info about how to install lebfredo6 34 c?
            Can get it running...
            all the best
            AA
              all the best
              AA
              Did you look at the screenshot of the first post? Are your files located like that?
              • C
                chouaibcl65
                thank youu
                • T
                  thebestvip84
                  thks alot ,u r my hero πŸ˜„
                  • W
                    wyatt
                    I figured out what was happening regarding the errors I was getting last week. The problem was organizer.rb. For the LibFredo6 plugins to work, both LIBFREDO6_Dir_34 and FREDOSCALE_Dir_20 must be added to the SmustardOrganizerExcludeFolders.txt file. As far as I can tell that does not effect the functionality of Fredo's scripts. Not sure if anyone else uses Organizer, but now you know.
                    Wyatt
                    • B
                      bobbybobbob
                      @exodiaangel said:
                      do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused πŸ˜• ❓
                      HELP PLEASE!!
                      its not you, its this site... if there was just a "DOWNLOADS" section....
                      I'm trying as well. still haven't found it....i registered, but now the spot that previously said that files are only for members is nowhere to be found.
                      also confusing which topic is the "top" topic. fear not, just keep searching this site, and hopefully i'll find it before i loose interest in rounding my corners...funny thing is, i had this plugin last year, but lost it some how...so i guess i went through all this before! sheesh.
                      but at least i'm begininning to see that Fredo6 is "the one".
                      • GaieusG
                        Hi guys,
                        The plugins are regularly posted in (attached to) the first post in their respective topic when the author first "published" his plugin. I cannot really say it more clear. To search for a certain plugin, best is to start here:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
                        (This is a "sticky" post at the top of this subforum).
                          agamemnus
                          Hi Fredo,
                          Thanks a lot for fixing the greying-out issue!
                            Mia
                            NEW VERSION 3.1c
                            Needed for for FreeScale 2.0c
                            see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                            Hi!
                            I've just doanloaded the 3.4 and extracted the zip to the Plugins folder as advised, but the settings do not show up in the Window menu. Should this extracting to folder be the "installation" or do I miss something?
                            • fredo6F
                              @mia said:
                              Hi!
                              Can you check if you have the correct footprint, with just 2 elements in the Sketchup Plugins directory:
                              • LibFredo6.rb
                              • LIBFREDO6_Dir_34 folder
                              PS: you also need to install at least one of my plugins (FredoScale, RoundCorner, ...) to see something in the menus (LibFredo6 does not load otherwise)
                                maruthi
                                i am not able download ...please help me out... 😞
                                • GaieusG
                                  What happens when you want to download? Can you see the link at all?
                                  • N
                                    nirve08
                                    ei guys, im still a new at using sketch-up, i search out for plugins, and i find this one interesting, i downloaded it, followed the instructions, but it didnt work, i have installed also the freescale 2.0..how do you install this one? i need a detail instruction like what folder or which folder to paste or install...many thanks
                                      http://forums.sketchucation.com/viewtopic.php?p=144180#p144180 is the download page for the tool it has quite clear instructions ?
                                      What is the exact problem ? πŸ˜•
                                        jboyza
                                        Glad to hear its working
                                        • B
                                          baldaman
                                          I upgraded my OS to WINDOWS 7 ultimate 64 and now I have constant crash each time I try to use FREDOSCALE.
                                          Am I the only one on earth?
                                          Best regards to all Sketchup users.
                                            Dali_
                                            Eventually got roundCorner to work... You have to register first, to be able to download LibFredo6 3.4c...
                                            But, now it works, it's good – c'est bon – bravo!
                                            Merci
                                            • 11
                                            • 115
                                            • 116
                                            • 9 / 116
