    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 353.8k Views 71 Watching
      The face must lie FLAT.
      I'll sort this eventually !!! ๐Ÿค“
      • X Offline
        xrok1
        appears to be the same
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          Aaargh!
          The group isn't getting made or kept...
          I'll send you a PM version with lots of intermediate prompts and progress/error messages in the console...
          It'll take me a while to make it... please be patient... ๐Ÿ˜’
          • X Offline
            xrok1
            i guess i should note that my problem was caused by a sketchy physics conflict, i changed my version of sketchy physics and now everything is great! ๐Ÿ˜„
              arjunmax09
              does anyone know this plugin's video tutorial link..... ๐Ÿ˜’ ??
              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                arjunmax09
                does anyone know this plugin's video tutorial link?? or any pdf file giving tutorials in this plugin
                • U Offline
                  Ultimatez 32
                  TIG, I confirm this. Sketchyphysics is the plugin that's clashing with EEbyRails
                  ultimatez
                  Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                    Thanks TIG.
                    • O Offline
                      oskadoska
                      Having some difficulty with this plugin (in Extrusion Tools).
                      It will not let me select the profile in the attached file (the narrow ends) - will let me select the long edges OK (my intended rails) but this is not much use. Have no idea what the issue is - have also updated SketchyPhysics as there was a comment that earlier versions of this caused a problem.
                      Any thoughts appreciated, its driving me nuts!
                      Off_the_Rails.skp
                        First the shape is very small and has many facets [bottom profile is ~5mm and with 30 segment some faces would be tiny] - there is a limitation on making very small faces with SUp/OpenGL - Scale it up x10 EEbyRails then Scale x0.1 if you want it to be so small - small faces will be kept on scaling down, you just can't make them that small in the first place.
                        The skp you supplied has all of the parts as edges in separate bits.
                        Use weld.rb to make the 2 profiles and 2 rails into their own curves.
                        The short top melding-profile is a lone edge. EEbyRails needs its profiles/rails' edges in a "curve" form.
                        You can't make a single edge curve with weld BUT remember that it's best to match you two profiles' [and rails'] segment count anyway - it will be interpolated but making both with 30 forces what you want.
                        To set the short top profile to a 30 segment 'straight' curve, select the edge, right-click Divide, type 30, the bits remain highlighted now 'weld' - you now have both profiles with 30 segments.Capture.PNG
                        • O Offline
                          oskadoska
                          Hooray! Extrusion now realized.
                          Thanks for your advice TIG, much appreciated.
                          Summarising:
                          1. All Profiles and Rails must be welded curves - even straight lines must be converted.
                          2. Use plugin weld.rb to weld
                          3. Convert a straight line to a welded curve by select > divide > segments ~30 > weld
                          4. For small objects best to scale up > process/extrude > scale down.
                          • I Offline
                            InterArchi
                            @tig said:
                            If anyone else is having similar problems or has a fix then please share !
                            ๐Ÿ˜• ๐Ÿ˜• ๐Ÿ˜•
                            Can you please upload for us a video tutoriel ? I think It will be more practical If you please of course
                            I will be very happy if you do, I couldnt even do a single work with the scripts
                              Rip Tanion
                              Below is a W.I.P. made with TIG's extrude plugins. I drink a toast to you and your genius, TIG. (Sorry that the cup is empty, but I already drank the toast. ๐Ÿ˜„ )
                              [attachment=2:3w44uwco]<!-- ia2 -->chalice1.png<!-- ia2 -->[/attachment:3w44uwco]
                              [attachment=1:3w44uwco]<!-- ia1 -->chalice2.png<!-- ia1 -->[/attachment:3w44uwco]
                              [attachment=0:3w44uwco]<!-- ia0 -->chalice3.png<!-- ia0 -->[/attachment:3w44uwco]
                              • H Offline
                                h_Rvn10
                                Just here to say thanks ๐Ÿ‘
                                this plugin is amazing,like a magic
                                  solodown
                                  Bonjour,
                                  Pourrais-je avoir une explication sur le fonctionnement de ce plugin
                                    @Solodown
                                    Il y en a plein dans la version franรงaise ๐Ÿ˜‰
                                    (9 pages ๐Ÿ’š
                                      TIG, thank you for this most excellent tool. It made these twisted spindles absolutely trivial to draw. And lightweight at 47 Kb, too.
                                      http://farm4.static.flickr.com/3207/5819092833_b558ffdda7_z.jpg
                                        Possible?
                                          That'd make it the Bezier-surface-editor that ThomThom's working on ?
                                          You could add a central 'spine' curve scaled/adjusted as desired and make the mesh in two halves that you recombine later on - erasing coplanar edges etc... To quickly make the spine-rail divide the profile into two equal parts and weld back, then use EEbyRailsToLattice > Rails only - then adjust the central spine-rail as desired and use that curve as a rail twice to make the two meshes you'll later combine....
                                            I just want to be able to place Cpoints here and there as anchors for the mesh. It's not possible? [under one tool]
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
