    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 403.0k Views 71 Watching
      That error message is because you say 'Yes' to untwist a mesh BUT it is already erased - for some unknown reason.
      For some reason your version is failing to make the mesh, or erasing it immediately after it's made...
      Here is a specially doctored version of EEbyRails - try it and answer 'No' to all closing dialog prompts, report what happens and any Ruby Console messages...
      This file is for temporary use only ! Attachment removed following resolution.
      • X Offline
        xrok1
        i tried it. i got EEE about 20 times. like this
        EEE
        EEE
        EEE
        EEE
        EEE
        EEE
        EEE
          eeek! 😲
            Good... that's what I expected... πŸ˜„
            I assume no geometry or guide-points got made ?
            Narrowing down the little blighter πŸ˜‰
            Throw away that temporary version as it's not sustainable...
            I'll get you another version to try soon...
            [tomorrow?]
            • X Offline
              xrok1
              thanks! πŸ˜„
                See here http://forums.sketchucation.com/viewtopic.php?p=236493#p236493 for a link to the an update that I hope [against hope] resolves your problem - feedback please...
                • X Offline
                  xrok1
                  errr!@ 😒
                  • X Offline
                    xrok1
                    edges by rail by face gives this!
                      The face must lie FLAT.
                      I'll sort this eventually !!! πŸ€“
                      • X Offline
                        xrok1
                        appears to be the same
                          Aaargh!
                          The group isn't getting made or kept...
                          I'll send you a PM version with lots of intermediate prompts and progress/error messages in the console...
                          It'll take me a while to make it... please be patient... πŸ˜’
                          • X Offline
                            xrok1
                            i guess i should note that my problem was caused by a sketchy physics conflict, i changed my version of sketchy physics and now everything is great! πŸ˜„
                              arjunmax09
                              does anyone know this plugin's video tutorial link..... πŸ˜’ ??
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                arjunmax09
                                does anyone know this plugin's video tutorial link?? or any pdf file giving tutorials in this plugin
                                • U Offline
                                  Ultimatez 32
                                  TIG, I confirm this. Sketchyphysics is the plugin that's clashing with EEbyRails
                                  ultimatez
                                  Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                                    Thanks TIG.
                                    • O Offline
                                      oskadoska
                                      Having some difficulty with this plugin (in Extrusion Tools).
                                      It will not let me select the profile in the attached file (the narrow ends) - will let me select the long edges OK (my intended rails) but this is not much use. Have no idea what the issue is - have also updated SketchyPhysics as there was a comment that earlier versions of this caused a problem.
                                      Any thoughts appreciated, its driving me nuts!
                                      Off_the_Rails.skp
                                        First the shape is very small and has many facets [bottom profile is ~5mm and with 30 segment some faces would be tiny] - there is a limitation on making very small faces with SUp/OpenGL - Scale it up x10 EEbyRails then Scale x0.1 if you want it to be so small - small faces will be kept on scaling down, you just can't make them that small in the first place.
                                        The skp you supplied has all of the parts as edges in separate bits.
                                        Use weld.rb to make the 2 profiles and 2 rails into their own curves.
                                        The short top melding-profile is a lone edge. EEbyRails needs its profiles/rails' edges in a "curve" form.
                                        You can't make a single edge curve with weld BUT remember that it's best to match you two profiles' [and rails'] segment count anyway - it will be interpolated but making both with 30 forces what you want.
                                        To set the short top profile to a 30 segment 'straight' curve, select the edge, right-click Divide, type 30, the bits remain highlighted now 'weld' - you now have both profiles with 30 segments.Capture.PNG
                                        • O Offline
                                          oskadoska
                                          Hooray! Extrusion now realized.
                                          Thanks for your advice TIG, much appreciated.
                                          Summarising:
                                          1. All Profiles and Rails must be welded curves - even straight lines must be converted.
                                          2. Use plugin weld.rb to weld
                                          3. Convert a straight line to a welded curve by select > divide > segments ~30 > weld
                                          4. For small objects best to scale up > process/extrude > scale down.
                                          • I Offline
                                            InterArchi
                                            @tig said:
                                            If anyone else is having similar problems or has a fix then please share !
                                            πŸ˜• πŸ˜• πŸ˜•
                                            Can you please upload for us a video tutoriel ? I think It will be more practical If you please of course
                                            I will be very happy if you do, I couldnt even do a single work with the scripts
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
