    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 424.8k Views 71 Watching
      Good... that's what I expected... ๐Ÿ˜„
      I assume no geometry or guide-points got made ?
      Narrowing down the little blighter ๐Ÿ˜‰
      Throw away that temporary version as it's not sustainable...
      I'll get you another version to try soon...
      [tomorrow?]
      • X
        xrok1
        thanks! ๐Ÿ˜„
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          See here http://forums.sketchucation.com/viewtopic.php?p=236493#p236493 for a link to the an update that I hope [against hope] resolves your problem - feedback please...
          • X
            xrok1
            errr!@ ๐Ÿ˜ข
            • X
              xrok1
              edges by rail by face gives this!
                The face must lie FLAT.
                I'll sort this eventually !!! ๐Ÿค“
                • X
                  xrok1
                  appears to be the same
                    Aaargh!
                    The group isn't getting made or kept...
                    I'll send you a PM version with lots of intermediate prompts and progress/error messages in the console...
                    It'll take me a while to make it... please be patient... ๐Ÿ˜’
                    • X
                      xrok1
                      i guess i should note that my problem was caused by a sketchy physics conflict, i changed my version of sketchy physics and now everything is great! ๐Ÿ˜„
                        arjunmax09
                        does anyone know this plugin's video tutorial link..... ๐Ÿ˜’ ??
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          arjunmax09
                          does anyone know this plugin's video tutorial link?? or any pdf file giving tutorials in this plugin
                          • U
                            Ultimatez 32
                            TIG, I confirm this. Sketchyphysics is the plugin that's clashing with EEbyRails
                            ultimatez
                            Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                              Thanks TIG.
                              • O
                                oskadoska
                                Having some difficulty with this plugin (in Extrusion Tools).
                                It will not let me select the profile in the attached file (the narrow ends) - will let me select the long edges OK (my intended rails) but this is not much use. Have no idea what the issue is - have also updated SketchyPhysics as there was a comment that earlier versions of this caused a problem.
                                Any thoughts appreciated, its driving me nuts!
                                Off_the_Rails.skp
                                  First the shape is very small and has many facets [bottom profile is ~5mm and with 30 segment some faces would be tiny] - there is a limitation on making very small faces with SUp/OpenGL - Scale it up x10 EEbyRails then Scale x0.1 if you want it to be so small - small faces will be kept on scaling down, you just can't make them that small in the first place.
                                  The skp you supplied has all of the parts as edges in separate bits.
                                  Use weld.rb to make the 2 profiles and 2 rails into their own curves.
                                  The short top melding-profile is a lone edge. EEbyRails needs its profiles/rails' edges in a "curve" form.
                                  You can't make a single edge curve with weld BUT remember that it's best to match you two profiles' [and rails'] segment count anyway - it will be interpolated but making both with 30 forces what you want.
                                  To set the short top profile to a 30 segment 'straight' curve, select the edge, right-click Divide, type 30, the bits remain highlighted now 'weld' - you now have both profiles with 30 segments.Capture.PNG
                                  • O
                                    oskadoska
                                    Hooray! Extrusion now realized.
                                    Thanks for your advice TIG, much appreciated.
                                    Summarising:
                                    1. All Profiles and Rails must be welded curves - even straight lines must be converted.
                                    2. Use plugin weld.rb to weld
                                    3. Convert a straight line to a welded curve by select > divide > segments ~30 > weld
                                    4. For small objects best to scale up > process/extrude > scale down.
                                    • I
                                      InterArchi
                                      @tig said:
                                      If anyone else is having similar problems or has a fix then please share !
                                      ๐Ÿ˜• ๐Ÿ˜• ๐Ÿ˜•
                                      Can you please upload for us a video tutoriel ? I think It will be more practical If you please of course
                                      I will be very happy if you do, I couldnt even do a single work with the scripts
                                        Rip Tanion
                                        Below is a W.I.P. made with TIG's extrude plugins. I drink a toast to you and your genius, TIG. (Sorry that the cup is empty, but I already drank the toast. ๐Ÿ˜„ )
                                        [attachment=2:3w44uwco]<!-- ia2 -->chalice1.png<!-- ia2 -->[/attachment:3w44uwco]
                                        [attachment=1:3w44uwco]<!-- ia1 -->chalice2.png<!-- ia1 -->[/attachment:3w44uwco]
                                        [attachment=0:3w44uwco]<!-- ia0 -->chalice3.png<!-- ia0 -->[/attachment:3w44uwco]
                                        • H
                                          h_Rvn10
                                          Just here to say thanks ๐Ÿ‘
                                          this plugin is amazing,like a magic
                                            solodown
                                            Bonjour,
                                            Pourrais-je avoir une explication sur le fonctionnement de ce plugin
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 18 / 20
