    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 237.5k Views 51 Watching
    • BoxB Offline
      Yes I was using a cube of grouped faces, and at first I was getting a bug spat every time, now it is random.
      I have rebooted and added updates and a few other bits and pieces since then, sorry that's not a very useful bit of diagnostic information but I've been doing too many things at once.
      So to put it simply, It does work for me but it is unstable and I have yet to work out what, if any, conditions cause the bug splat.
        c.plassais
        Two versions of the plugin that can be corrected bug
        I've written a 3.0.2 version and also a rewritten version by the genius Fredo. Thanks Fredo ๐Ÿ‘
        Sorry I can not insert in the original post ...
        The limitation of this plugin is that it does not take into account the size of groups or components.
        It moves only the elements from their center. Perhaps a future version
        Christophe
        Eclate_Deplace english version 3.0.2
        version 3.0.2 rewritten by fredo ChrisP_RadialMove
          Added to the first post ๐Ÿ˜‰
            c.plassais
            Thank Pilou ๐Ÿ‘
              dedmin
              • V Offline
                vidy
                dear guys,
                is there any possibility of this plugin have crashed with other plugin?
                ok, here is what i did:
                1. i copy the newest version 3.0.2
                2. then rename it so its just Eclate_Deplace.rb
                3. i create simple cube, and then group it
                4. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                http://a.imageshack.us/img829/1341/eclatedeplaceprob01.jpg
                please,somebody help me to solved this issue, thank you.. โ“
                regards,
                still so much to learn..
                  Finally it's back working ๐Ÿ‘
                  Thanks Pilou....C.Plassais....TIG....Thomthom....Chris Fullmer....Fredo!
                  Hope i left no one out?
                    Maybe cats and dogs and birds...
                    It's a big familly ๐Ÿ˜†
                      About
                      Facegroup by Gavvy (seems there a is little problem with this facegroup plugin) Thomthom is look it! and seems found the error โ˜€
                      And I have found another one who works ๐Ÿ˜‰
                      Make_components by Matt666 at Crai Ruby depot!
                      And a third solution by Tig! (face selected ---> groups)
                      Put this in the Ruby console! โ˜€
                      m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face}
                      • V Offline
                        vidy
                        thanks pilou for the fast reply, i will try it and report it soon..
                        regards,
                          With newest version 3.0.2
                          I don't believe that
                          1. i create simple cube, and then group it
                          2. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                          Normal : a simple cube must be composed of a 6 faces themself a group!!!
                          (so for a cube: 6 faces who are each a group) !
                          in this image i have selected one face for you show that is a group
                          (each face is a group)
                          Select them then call the plug!
                          If you want transform automatically each 6 faces of a simple cube on 6 groups maybe exist a plug ๐Ÿ˜‰
                          (or any faces selected)
                          Facegroup by Gavvy (seems there a little problem with this facegroup plugin) Thomthom is look it!
                          Make_components by Matt666 at Crai Ruby depot! โ˜€
                          Ps Menu of "Radial Move" or "Eclate_displace" Appear by Right Click on the selection of the groups or components!
                          • Y Offline
                            yvan79
                            How do you use the ChrisP_RadialMove_EN.rb plugin? can anyone show an example?
                              No problem ๐Ÿ˜„
                                I don't see your images ๐Ÿ˜ฎ
                                Verify that your object is composed of groups or components!!!
                                A simple cube grouped will not works if each face is not a group!!!
                                • Y Offline
                                  yvan79
                                  Hi pilou...thanks for the instructions but i have an error of saying 'No effective transformation - nothing has been created'.
                                  • Y Offline
                                    yvan79
                                    sorry for the image error....it's there now....
                                      Ok I see it now ๐Ÿ˜„
                                      Your result is normal
                                      you have Enter 0 as X,Y,Z Translation !!! ๐Ÿ˜‰
                                      Try with 10 as X,Y,Z Translation
                                      and make a Zoom extend if translation is biggest between groups for see result ๐Ÿ˜„
                                        Ps : And better than an image, post your SKP file ๐Ÿ˜‰
                                        • Y Offline
                                          yvan79
                                          Ok...now i understand it. thank you very much, pilou....
                                          • V Offline
                                            vidy
                                            thanks pilou,
                                            its work in sketchup 7.. ๐Ÿ˜„
                                            somehow it can't on sketchup 6.. ๐Ÿ˜ž it even not showing the dialog box
                                            on ruby console, it show this:
                                            Error: #<ArgumentError: wrong number of arguments(2 for 1)>
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:30:in start_operation' C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:30:in pilou_explose'
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:132
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:132:in `call'
                                            • 3 / 9
