    [Plugin] Superellipse 1.2
    26 Posts 13 Posters 23.8k Views 13 Watching
      remus
      Why replace one arbitrary scale with another? they'll both serve the same purpose, and as long as the user understands 'big n = more square' you cant go too far wrong.
        Regular Polygon
        @su reviewer said:
        As of now its pretty much a shot in the dark as to how square the superellipse will come out. Perhaps having a scale of 1-100 (100 being a perfect square) the plugin would be more manageable?
        Otherwise great plugin!
        Thanks for your review!
        I can see your point. It is not real intuitive to me either how square the superellipse will be for a given exponent value.
        We could replace the exponent with a scale that runs from 1-100. If 1 represents a completely round shape, then we would associate it with an ellipse. At the other end, 100 represents a completely square shape, so we associate it with a rectangle. But it is not so obvious to me what the numbers in the middle represent. Which superellispe should correspond to a scale factor of say 50?
        My SketchUp Plugins
        • boofredlayB Offline
          boofredlay
          Oh man, I could have used this about 4 days ago. This is one of those quick scripts I imagine using quite often.
          Thank you very much. โ—
            Ben Ritter
            Thank you Regular Polygon.
              Is "Regular Polygon" a reference to Flat Land?
                Thank you for this plugin. It is very nice.
                I think the exponent makes sense. After all, it's a logical input considering the formula you're solving. Length and width are a and b so why not define n? I would prefer that to some arbitrary 1-100 scale.
                http://upload.wikimedia.org/math/1/7/1/171490937fc13b93677c00b8c80ffb76.png
                • brookefoxB Offline
                  brookefox
                  Silly me thought you figured that formula out for yourself, Dave.
                  Since I have no sense at this point where the exponent variable will take me, though I guess that comes with practice, the 1-100 option has some appeal. I should hold my tongue until I practice, but I won't.
                  Thanks for the contribution, rp, and for adding the loci to the ellipse.
                  ~ Brooke
                    remus
                    A quick question about using values of n<1 if i may: how do you handle it, because surely you'll end up trying to take roots of negative numbers which'll give you imaginary numbers, unless you just take the imaginary part and use that?
                      Regular Polygon
                      @remus said:
                      A quick question about using values of n<1 if i may: how do you handle it, because surely you'll end up trying to take roots of negative numbers.
                      Here is the code that computes the coordinates.
                      def sgn(num)
                        return  0  if num.zero?
                        return +1  if ( num > 0 )
                        return -1
                      # Compute the points for the vertices of the superellipse
                      def points
                        e = 2.0 / @exp
                        pts = []
                        delta = 2 * Math;;PI / @edges
                        for i in 0...@edges do
                          phi = i * delta
                          x = @a * sgn(Math.cos(phi)) * Math.cos(phi).abs**e
                          y = @b * sgn(Math.sin(phi)) * Math.sin(phi).abs**e
                          pts.push([x, y, 0])
                        pts.push(pts[0])  # close the loop
                        pts
                      The only trick is to take the absolute value before you raise a number to a fractional power. After that, multiply it by +1 or -1, depending on the sign the original number had.
                      My SketchUp Plugins
                        remus
                        That makes sense, cheers.
                          Regular Polygon
                          No, not really.
                          "Regular Polygon" is kind of a play on words. It could mean an ordinary, everyday, run-of-the-mill polygon (i.e. the basic element of 3D graphics). But, in the mathematical sense, it means a symmetrical polygon whose angles and edges are all equal.
                          My SketchUp Plugins
                            Regular Polygon
                            I have just released a new version 1.1 of the Superellipse plugin. This version allows you to specify the "squareness" of a superellipse using a scale. The exact association between the scale and the squareness is spelled out in gory detail in the post on my blog. But a picture is probably worth a 1000 words.
                            Basically, 0 corresponds to an ellipse, 100 corresponds to a rectangle, and a scale factor of 50 corresponds to a superellipse that stretches 50% of the way in between. I think this makes assigning a squareness value fairly intuitive.
                            You can run both versions (1.0 and 1.1) at the same time to compare them. To download the plugin, or read more about it, please visit my blog at http://regularpolygon.blogspot.com/
                            Thanks.
                            My SketchUp Plugins
                            • olisheaO Offline
                              olishea
                              thanks for sharing ๐Ÿ‘
                              oli
                              • simon le bonS Offline
                                simon le bon
                                we will see, but it would prove itself often useful in time
                                ++simon
                                  Regular Polygon
                                  Hey, thanks everyone for the big welcome, and your show of support, for this first -- albeit simple -- plugin.
                                  My SketchUp Plugins
                                  • pyrolunaP Offline
                                    pyroluna
                                    Really nice... but it reminds me... I used to use POV-Ray some years ago, in which it was possible to create a 3d-superellipsoid.
                                    Could you make that??? ๐Ÿ˜„ would be so awesome, I used to use it a lot!
                                    Perhaps in SU it would need a variable for level of detail, though...
                                    The superellipsoid object creates a shape known as a superquadric ellipsoid object. It is an extension of the quadric ellipsoid. It can be used to create boxes and cylinders with round edges and other interesting shapes. Mathematically it is given by the equation:
                                    The values of e and n, called the east-west and north-south exponent, determine the shape of the superquadric ellipsoid. Both have to be greater than zero. The sphere is given by e = 1 and n = 1.
                                    The syntax of the superquadric ellipsoid is:
                                    SUPERELLIPSOID:
                                    superellipsoid
                                    <Value_E, Value_N>
                                    [OBJECT_MODIFIERS...]
                                    The 2-D vector specifies the e and n values in the equation above. The object sits at the origin and occupies a space about the size of a box{<-1,-1,-1>,<1,1,1>}.
                                    Two useful objects are the rounded box and the rounded cylinder. These are declared in the following way.
                                    #declare Rounded_Box = superellipsoid { <Round, Round> }
                                    #declare Rounded_Cylinder = superellipsoid { <1, Round> }
                                    The roundedness value Round determines the roundedness of the edges and has to be greater than zero and smaller than one. The smaller you choose the values, the smaller and sharper the edges will get.
                                    Very small values of e and n might cause problems with the root solver (the Sturmian root solver cannot be used).
                                      Regular Polygon
                                      Thanks, glad you like it. Funny you should ask because, in fact, I do have a superellipsoid plugin. It lets the user enter the number of lines of latitude and longitude to control the level of detail.
                                      It was interesting to see how POV-Ray is dealing with the exponents in the formula. They let the user specify a Roundedness value, whereas I came up with a Squareness value. I'll have to try out both approaches to see which I like better.
                                      Anyway, I should get the superellipsoid plugin polished up, and posted on my blog, sometime next week. Stay tuned!
                                      My SketchUp Plugins
                                        SU Reviewer
                                        Looking good! Definitely works better, will update the review. ๐Ÿ‘
                                        Living Einstein's dream through SketchUp.
                                        "Imagination is a preview of life's coming attractions" - Albert Einstein
                                        Joe Simhon ~ SketchUp Plugin Reviews
                                          Regular Polygon
                                          That is +1 vote for the new squareness scale in version 1.1. I think it improved the plugin, thanks for the suggestion.
                                          My SketchUp Plugins
                                            Regular Polygon
                                            Update to version 1.2
                                            Previous versions started off each session with arbitrary default values in the dialog box for the Superellipse parameters. This version remembers your last dialog box values between sessions.
                                            My SketchUp Plugins
